Lucky Phil
    268
  1. Some of it has to do with "brand placement" you know that perception strategy that your brand is funky,sexy,classy,urbane or whatever the "creatives" in the marketing department think it needs to be. They dictate what your shop layout and look needs to be etc and the demographic you're aiming at and if you dont comply they ditch you no matter how good your history as a brand representative has been . Sorry you're just not part of our overall brand strategy going forward kind of bullshit. Dont get me started, opps I already have,sorry. Ciao
  2. Yes its often more about the length of exposure time. I once had an engine that cracked a cylinder head through the cam feed oil gallery in the head and into the water jacket. Contaminated the cooling system with quite a lot of oil. A friend said to use sugar soap which is a liquid soap you mix with water to was down walls prior to painting. Worked perfectly and after a few brief stationary short runs of the engine and dumping and repeating the system was perfectly clean. I mentioned this to someone else though that pointed out that sugar soap had a component in it that rubber seals might not like which was fair enough but the exposure time was so short it never was an issue. Even if it had been the worst thing that was likely was a few new hoses and a water pump seal. I have no idea how I would have cleaned the system otherwise. Ciao
  3. Good to know Chuck. Of course you could always just pull it apart and clean it out. What else are you going to do with you're life thats more interesting than working on a Guzzi:) Of course the concept that many times this error has been made is a bit worrying. How many people out there think a gearbox fill point is sealed by a simple rubber plug you can pull off with your finger nail. Ciao
  4. What about the front subframe and gearbox mounts? Ones a six speeder and ones a five. The front subfame at the very least is different as the engine offset difference between the 5 and six speeds is 10mm. You will need a V11 front subframe or cut and weld the sport one and when Paul Minnaert did his Daytona 6 speed conversion I seem to remember a lot of rear frame modifications. Ciao
  5. If you invest in a Wilbers rear shock they will tailor the damping and spring to your specific weight and riding style and you can also adjust the ride height depending on the spec you choose. Some other brands can be done as well if you buy from a suspension specialist. I wouldn't bother messing around with the stock rear Sachs unit considering the propensity for the eye end to fail. Not worth even spending the money on a spring and fitting for. By the time you've bought the spring and paid someone to fit it you'll be 1/3 the way to a brand new quality rear shock anyway. Ciao
  6. Hmm, depending on how much 2 bottles is and where the level in the clutch housing came up too I'm not sure exposing the rear main and gearbox input seal to mineral spirits is totally without risk. Add to that washing lube off the gearbox input splines and I just dont know. Time will tell I guess and add to the accumulated knowledge here. I had the flap drive system apart on an Airbus A300 years ago and cleaned up one of the rubber boots that covered one of the drive shaft universal joints in some jet fuel ( basically refined kerosene) and was the horrified to see it had destroyed the boot. I've always been cautious with solvents on rubber products since. Ciao
  7. Bikes are so cheap in the US, I cant believe it. Ciao
  8. Well you could try tightening the clamp but its usually the hose thats split. As far as easy peasy goes I find them a total PITA to replace. Lots of wiring,cables, ignition coils etc to get around. Ciao
  9. I've done quite a few klms around southern Germany and the problem was always focusing on the road as the scenery was so magnificent. Ran into the back of a Carabinieri in Italy for much the same reason once. Ciao
  10. Great quality video, images and sound perfect. Well done you. Ciao
  11. Lucky Phil
    Scura clutch
    Well Pete, after I get the V11 up and running again I'll let you know what the single plate clutch feel like on a Daytona engine. I have no doubt i'll like the reduced mass as someone thats been riding and owning Ducatis for 35 years. Ciao
  12. Anyone out there know where I can get some of these. They are a thin shim usually zink plated with industrial diamonds embeded in the plating. They are used these days between cam sprockets and crank cam drive sprockets for the modern engine system that uses friction drive for these components and deletes the keyways. What I need are 8mm ID and around 18mm od although the od isnt that critical. They go under the name of EKagrip or 3M friction drive shims. 3M have bought out EKagip I think. They're one of those things where you need to know the application they are used in and order accordingly as it seems no one stocks them as loose items by dimension. https://www.alibaba.com/product-detail/TIGER-TIGHT-FRICTION-WASHERS_110359856.html http://rosten-performance.com/products/engineparts-gasoline/rotating-assy-and-block-engineparts-gasoline/frictionshims/1-6-1-8-2-0-8v-ekagrip-crankshaft-shim/ https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Friction-Shims/?N=5002385+3290920153&rt=rud Ciao
  13. Lucky Phil
    Scura clutch
    Oh OK Pete, I re read your post and see my mistake. Sorry. Ciao
  14. Lucky Phil
    Scura clutch
    Here's a twin plate 6 speed assy. the single plate one looks the same except for the depth of the splined section front to rear. Here's the single plater Ciao
  15. Lucky Phil
    Scura clutch
    I didnt remove mine from the gearbox Pete but it looks like its the same as the single plater and I cant see any reason for it to be different. Famous last words of course. To me it looks like the single plater is just a shorter version of the twin with all the material taken off the front face. Ciao
  16. Lucky Phil
    Scura clutch
    The only difference I can see between the twin plate and single plate gearbox input spline drive that bolts to the gearbox input shaft is the depth (front to back dimension) twin plate looks like maybe 25mm of spline that interfaces with the clutch friction plates and the single plater maybe 20mm. So why not just surface grind that additional 5mm off the fwd face and bring the splined length fwd to aft doen to the single plate dimension. If it was softer material you could just chuck it up in the lathe and face it off but it will be too hard for that. Ciao
  17. Lucky Phil
    Scura clutch
    Why not just grind down the twin plate gearbox input spline? Now I've had my twin plate gearbox off the engine it looks to me like its a fairly simple task to surface grind it back to the dimensions of the single plate unit. Ciao
  18. In the very early days of the Ducati 851 used to connect the intake manifold to the reg but they quickly dropped the practice. It was obviously designed to regulate fuel pressure to manifold intake pressure and bikes that used the reg sense port had different chips. I suspect in the end it didn't have enough impact on the fuelling to persist with. When I upgraded my 888 race bike to the quad injectors I also went to the vented reg. Ciao
  19. I bought my first pair in 1986 for a DB1 Bimota. Catch up with Sandy who owns Staintune one or twice a year, last time was a just few months ago. Ciao
  20. Riding schools,sheez. I've heard of this technique they pedal and wondered. So they want you to stop at the traffic lights/intersection in gear looking in your mirrors and if it looks like you're going to get rear ended then accelerate through the red light or stop sign into the middle of a busy intersection to avoid getting rear ended. Sounds totally illogical to me and relies on you being the first vehicle at the lights/intersection of course. Cant say I'm a fan of the stop and re start the engine technique either. Engines like to stay running unless its going to be idling for an extended period of time in a traffic jam. Ciao
  21. You shouldn't be doing this with any clutch, wet,dry, car or motorcycle. It's a bad habit you should rid yourself of. Unnecessarily wears the throw out bearing, the engine thrust bearing, the pilot bearing( automotive) the clutch friction plate and flywheel faces/steel plates. Not good under any circumstances. Ciao
  22. 3 bar, around 45 psi Ciao
  23. The only parts that can be removed are the filter screen the attaching nut and the circlip on the end, you cant access the internals without machining/removing the crimped over top edge of the alloy operating knob. I have one of these pieces of total rubbish on the bench at the moment. I have 2 of these,one failed ( wouldnt shut off even with pliers) so I fitted the spare and its crap also. One issue is the crimped edge of the operating nut rubs on the tap body, this I rectified on the failed unit and it works much more smoothly. The major issue seems to be the seals actually swell when they contact fuel as the failed unit now its dried out for months seems to be smoother in operation and does actually close off fully now. Long story short they are rubbish quality. Ciao
