Amazing to think Pete that Guzzi used alloy oil pump and cam drive gears as standard fitment to the Daytona and Centauro engines. I have a couple of sets that I dont particularly want to re use hence the Joe steel gear set for this engine as well. Ciao
As the supply of original pumps dries up the gap has been filled with aftermarket pumps some are fine and others of poor quality. I have a German made DAS pump which is very nice quality but availability is poor. Joes pumps will use the Ducati design for the secondary gear mentioned previously which is superior as well as a better drive gear bushin/bearing and higher quality with hopefully better availability. Ciao
The first thing that comes to mind when I look at the 650 is Centre of Gravity. Ciao
No docc didnt mention the V11 cover. Are they still available new? The original Daytona/Centauro covers were plastic and tended to crack at the mount points I'm told. Ciao
I've mentioned before Joe is still doing his timing gears but he is also going to produce replacement oil pumps as well Ther have been some pumps available for a while and while some were excellent some were suspect quality wise. A mate of mine building a short stroke Guzzi race engine with roller rear mains and roller supported cams with a set of Joes gears in it showed me one of these pumps and 1 out of the 4 mount holes doesnt line up. HMB has also suspended selling a version due to quality problems. Joes pumps will obviously be of high quality but will also use the Ducati type design for the secondary gear where the gear will run on a steel pin pressed into the pump housing rather than the inferior Guzzi version where the secondary gear and its integeral shaft run in the pump housing. Joe is also making some very nice Dayton/Centauro alloy front alternator covers. Just for the record I have no financial interest here just an interest in supporting a quality engineer that makes great stuff for Guzzi's and making you guys aware. Drop him a line if you need anything, he's always helpful. joe.caruso@ntworld.com Ciao
Ha there's always 1 out there I guess. Unfortunately the real world doesnt agree. If a MotoGP or Superbike with the massive amount of heat they shed via the radiator and engine with the fuel tank sitting basically right behind the engine getting the full effect dont neeed fuel cooling then nothing will. Still I love the fringe people, they make life interesting:) Ciao
I love spoke wheels but for some reason I dont think they suit the V11 aesthetically. Ciao
Real Gaskets Tennessee, silicone gaskets, any experience?
Lucky Phil replied to al_roethlisberger's topic in Technical Topics
Gotcha.. it's silk thread. Red is hard to find.. I was counting on you Chuck to fill in the fine details:) I learned a long time ago that I dint need to be very smart to survive, just had to know smart people. Ciao -
These are the best......Valpollini, Pete Roper sent me a set and they are perfect. Some kind of metal hybrid gasket with a coating. Dont get too carried away with aircraft piston engine technology as a lot of it is from the dark ages. Conti and lycomings use cotton thread to seal the case joint for goodness sake. Ciao -
Timing Gear Set - Replacing timing chain
Lucky Phil replied to FalcoLion's topic in Technical Topics
I wouldnt even venture an estimate and I cant even remember what I paid for mine around 6 years ago. Drop Joe a line and ask about the current price. He did mention to me he's in Italy this week so he may take a few days to reply. Ciao -
I have a steel set for the V11 and also for the Daytona engine from Joe Caruso in England but not an email address anymore. He is on linked in though.I dont think he's made them for years but if enough people get together he may run a batch. EDIT Try this... no garantees though. Sent him an email to say Hi and it didnt bounce so far. joe.caruso@ntlworld.com Edit 2....Joe got back to me and he's still making gears, so if anyone is interested drop him a line. Imagine these bad boys in your timing chest. Better than that agricultural chain:) Ciao -
Same as mine. I did the mesh mod as well.Bonded mine and its been fine for years. Same as my Ducatis with the mesh mods. Ciao
Spray paint or vinyl wrap gas tank preparation.
Lucky Phil replied to Walterg's topic in Technical Topics
I don't think you need to remove the paint or damaged clear coat to wrap the tank. Yes true you can wrap over the paint, this is how the car guys do it. Personally I'd get it painted as I dont know how the wrap stands up to fuel spillage over time and most wraps only have around a 4 or 5 year lifespan anyway. Ciao -
ANSWERED Modifying stock cartridge on '99 V11 Sport?
Lucky Phil replied to Drewteague's topic in 24/7 V11
This is true docc so what I do when I pull any suspension component down is I measure the viscosity of what came out for comparative purposes. All you need is a syringe body and a watch to time the measured amount of oil into a container. The actual numbers dont mean anything but the comparison does. So if your happy with the damping as it is you measure the original oil and compare it to the fresh stuff you're putting in. Prevents the frustration of replacing your original brand of 5W with a different brand of 5W only to find the new stuff is more like 7.5W and the damping isnt to your liking anymore. Ciao -
In the many trailers I've owned I've never seen one with suspension worth a damn. Live axle on short stiff leaf springs that are virtually solid. My track bikes are strapped down these days with a rear wheel strap and the front is held in a wheel chock. Roll the bike onto the trailer and into the wheel chock which holds it securely while you fit the rear wheel strap with the straps angled forward to pull the bike into the chock and the bike rides along on its suspension on the trailer. Pulling bikes down hard on their suspensions has long been given up on by those that care about the bikes suspension. Ciao -
Transparent plastic coating? Its a painted clear coat as far as I'm aware. Best way to remove paint from a plastic tank is to media blast it. Ciao -
Clearly half the foot is missing, a simple toenail wouldnt warrant an internet post surely. Ciao
Is there a diagram of where best to put the relay? I'm searching now through the archives and have found some. Do you know which one you used? Like docc I mounted my mini relays in the headlight shell. Ciao
Believe me they are sturdy enought to hold more than 2 lbs. Maybe that figure is more to do with Guzzi covering it arse with regard to weight balance and distribution and directional stability of the bike than the actual load bearing capacity of the rack. They are by far the best quality and niceset looking rack I've seen for a V11 and are a great hand hold for a pillion. Ciao
I wired my headlight circuit seperately via a pair of mini relays so now the regulator reference voltage stays constant and the handlebar switches dont carry the headlight current. Ciao
I love those old covered bridges. Ciao
Before we get too tied down to reg outputs its important to indicate whether or not the headlights are on or off during the measuring. Headlights on with the Guzzi system pulls the voltage reg sensing circuit down as much as 1 volt resulting in overcharging. Ciao
Must be like me visiting the states and not seeing Jeeps. I swear I see a million more Jeeps here than over there. Maybe Americans are smarter than us. Ciao
Color code satin-finished black motor paint?
Lucky Phil replied to biesel's topic in Technical Topics
Biesel is not refering to the wrinkle finish paint but the satin black of later models. Ciao
