Lucky Phil
    268
  1. Yes Chuck thats true. Although lockwire for instance isnt to stop a bolt coming loose, its to stop it falling out of the hole and fowling other stuff if it does. The reasons a bolt in a clamping application loosens is because. A....it was undertorqued. B....it was of insufficient strength and stretched under load to its yield point but (not necessarily) to failure point thus losing its tension. C..it was subject to fretting of the threads usually due to resonant vibration and therefore lost its tension/stretch due to wearing threads. D..the bolt used was too short and had insufficient stretch for the applied torque. In all these cases lockwire wont prevent the bolt from losing its clamping force and so its basically useless even if its still in the hole. The previous flight control nut example doesnt apply to the axle nut as most flight control bolt and nut applications such as this are rod end and/or clevis and the bolts are primarily taking shear and rotational loads and sometimes adequate bolt stretch is hard to achieve so more elaborate locking requirements are needed such as nylock nuts, pinning, locking tabs or a combination. A correctly torqued axle nut doesnt require a locking facility in my opinion. I've never seen one come loose that was correctly torqued in over 50 years. Honda once said that the reason they lockwired bolts on their race bikes wasnt to do with bolt retention but because they believed no one would be stupid enough to lockwire a bolt that wasnt tightened up in the first place. Ciao
  2. My Greeny now has the adjustable small eccentric pin and the banana plate via the Guzzi upgrade kit. The banana plate doesnt make a difference worth the updating in my view. Dont know why they bothered really. Thats Guzzi though updating stuff that doesnt need to be and ignoring stuff that does. Bit like developing hydraulic lifters that dont require adjusting for an engine with the most easily adjustable valves clearances in piston engine history:) Ciao
  3. Axle "Locking" nuts are really not required. My bike is fitted with Titanium non locking nuts front and rear with no issues as have been a hell of a lot of production motorcycles over the years including every Ducati I've ever owned including race bikes that have competed in the IOM. Its just another analy retentitive Guzzi idea thats not really necessary. Ciao
  4. Docc as Chuck pointed out you can buy sleeves to press over the damaged surface to provide a new surface for the seal to run on. If the damage isnt too deep you may be able to get the nose ground and the seal still have enough tension to do its job. Seals of this size generally have a couple of mm interference on the sealing surface so a 10 or 15 thou regrind wont matter if thats what it takes to get the damage cleaned up. Ciao
  5. I think you'll find the inner seal runs on the nose of the crownwheel not the axle. As I mentioned its also important to use OEM directional seals in these applications where the seal is difficult to access and or requires a lot of disassembly to replace. Ciao
  6. Oh ok docc. Yes painfull. Ciao
  7. Docc we always go one of 2 ways, take the easy simple option or the most complicated one. The obvious option for oil leaks is the seal and the less obvious is the flange/spacer it runs on. This can be out of round, under or oversize ( oversize burns out the seal) or it can have a microscopic surface blemish which goes unnoticed unless you look at it with a glass or are specifically looking for it. The other issue is sometime a worn bearing with too much play asking the seal to do too much. Years ago a friend of mine had a persistent oil leak from the clutch seal on 1986 Ducati Hailwood replica since new. Dry clutch on these with a large seal even bigger than the Guzzi bevel box seal. He just kept putting in new seals and got frustrated with it. I asked him to show me the primary gear so I could inspect the seal flange and there on the flange was a tiny spiral mark from the original grinding operation at the factory. Chuck it up in the lathe and hit it with some 1200 emery and polish it up and issue solved. He just kept looking at the obvious and simple option. The other area is of course the seal housing and its surface condition and concentricity as well as the control of the seal depth. Have you been using the OEM directional seals? Might be time for a complete strip down, measure up and detailed inspection of the other stuff. Ciao
  8. But I am electrifying...boom tah:) Ciao
  9. Yes, but not all selectors have this, some have a roll pin that realistically cant be removed. Ciao
  10. How could it be a cable issue if the speedo needle still works? More likely an internal failure of the odo drive, tapping the instrument free'd up/disconnected the speedo from the odo. Ciao "Symptoms were slowing turn over on the dial and dancing speedometer needle." Just trying to go by what he said. My assumption was that the failing internal odo drive was effecting the speedo needle stability which seems to be the case as when the odo drive failed and disconnected the speedo needle returned to normal ops. Ciao
  11. With all due respect and exception to our own docc, I've yet to meet a doctor that approved of getting on a motorcycle even when you are feeling 100% Sometimes its about the mental wellbeing over the physical. A few times I've had very serious injuries and got on the bike and its been ok and I've thought, well if I can still ride the bike then I'm going to be fine. Ciao
  12. When I was going through the Sport upon it's arrival, I found the airbox full of tar, and it took 4-5 times of very serious chemical assault to clean the mung out of the TBs and throttle plates. I used an entire can of carburetor cleaner, and nearly an entire can of TB/intake specific cleaner to get 95% of it out. I've never seen anything like it. The odometer showed only ~20k miles, but the bike's obviously been down so it's possible it isn't the original. Can I suggest you buy a small ultrasonic cleaner off ebay ( they are very affordable) to make this job and many others very quick and easy. Ciao you mean as in *take it apart*? I'll apply the 80/20 rule any time 80% is 100% serviceable and invisible. Not sure I understand but yes, take the TB's off and ultrasonic them. No need to disassemble them just clean them as a pair. Removal and refitting is therapeutic, its shed time, mans time,red wine and musing time, reflection time. Time well spent:) Ciao
  13. When I was going through the Sport upon it's arrival, I found the airbox full of tar, and it took 4-5 times of very serious chemical assault to clean the mung out of the TBs and throttle plates. I used an entire can of carburetor cleaner, and nearly an entire can of TB/intake specific cleaner to get 95% of it out. I've never seen anything like it. The odometer showed only ~20k miles, but the bike's obviously been down so it's possible it isn't the original. Can I suggest you buy a small ultrasonic cleaner off ebay ( they are very affordable) to make this job and many others very quick and easy. Ciao
  14. Biggest breather tank you can fit in the space ( with an oil seperator if possible ) available with a drain back line and the tank vented via a tube out the back of the bike. Ciao
  15. Nice, the silver bikes always photograph really well. Ciao
  16. How could it be a cable issue if the speedo needle still works? More likely an internal failure of the odo drive, tapping the instrument free'd up/disconnected the speedo from the odo. Ciao
  17. I was confused reading all the Thruxton references in these last couple of posts and compairing to a V11. I kept thinking of my friends Velocette Thruxton that I've ridden and thinking it was never a match for a V11. Then I remembered there's a modern version....doh Ciao
  18. A Scura with lipstic. Ciao
  19. You actually don’t want negative pressure because of that. Ideally you shoot for neutral pressure. Sent from my iPhone using Tapatalk Actually, there are reasons you want negative pressure in the crank cases. Not a lot, but negative pressure none the less. There is actual horsepower to be had there. But that is not very feasible with a V11, and I am not sure it is worth the effort. On a big V8 it can be a fairly significant amount of horsepower. But on a V11 I doubt you would be able to feel the difference. Running slightly negative pressure in the crankcases improves ring sealing and reduces pumping losses. Ducati think its worth the effort on the Panagale engine. It employs a gear driven vacuum pump to pull the crankcase pressure down which helps with oil leaks and pumping losses. Ciao
  20. Sounds more like fuel to me Chuck. I had a Ducati do this to me once due to a lean chip in the ecu. I had modified the engine for racing and installed a different chip that was too lean. It was all good when the engine was cold and on the enrichening map and idle and reving in neutral was fine when warm but as soon as you opened the throttle under load when riding and it called for genuine fuel flow it stopped dead as well. No missing or hicupping, just stopped. I'd re check all the fuel stuff you pulled and also whether any of the hoses has collapsed internally. Have a look at the fuel pressure when it happens. I only mention it because it feels for the world like ignition when they stop dead like this but it can still be fuel and thats what you've had apart. Ciao
  21. Its a drain back hose from the frame spine. The crankcase breathes into the spine and from there into the airbox. Any oil that accumulates in the spine can drain back into the cases. No check valve involved. All V11 versions are the same. From the photos of your bike I'm not sure if the catch tank is large enough (if thats it between the carb inlet trumpets) although a Guzzi doesnt have a crankcase breather read valve assembly like a Ducati which helps create a depression in the cases during running. Might be worth considering. If the catch tank has a lot of oil in it then you will probably need a drain back tube. On My TT2 Ducati ( 1980's ópen bell mouth 600 Vtwin) the catch tank vent from the cases also allowed drain back of oil into the cases due to its location on the tank. On big twin you can never have a too large a catch tank. I would also dump the breather filter thing and run a pipe to the rear of the bike uphill with a simple rubber flapper valve on the end. Ciao
  22. I've not actually been to Dayton but I have seen a lot of it on TV and I've had friends that have been there as tuners. I have been a mechanic/pitcrew at the IOM a few times though and I dont see Daytona as a great yardstick to the IOM although its probably the best that can be done in the circumstances. Just dont put too much emphasis on the Daytona banking being some sort of shakedown for the IOM or you will be in for a shock. The IOM is totally unique in its demands on the machinery both in set-up and endurance. Sulby straight for example is 3 miles WOT but what kills the engine is the bumps and the loading/unloading of the engine as the tyre breaks traction skipping off the bumps. You get issues at the IOM that you have never had in years of racing at short circuits. Might be worth checking that the oil on boot issue you had at Daytona wasnt related to crankcase breathing not coping with the continuious hight speed because at the IOM it will be a lot worse if that is the case. Ciao
  23. Thats all you need on there docc. Also a light application of moly spray instead of the grease works fine. I apply it by spraying it onto a plastic lid or some other clean surface and applying with a 1/2" stiff short bristle paint brush in locations where I dont want any overspray. Or sprayed directly out of the can when it doesnt matter about the over spray. Let the solvents flash off for a nice dry, even thin coat and assemble. Works well on clutch splines. Stays where its supposed to and doesnt attract cluch plate dust. Ciao
