The cam drive belts are a piece of piss scud, a man of your tallents will find it easy. The covers and stuff come off pretty easy after you get the F$#+_&îng fairing off. Just note the tension on the old belts before you remove the tension pully and set the same with the new belts. There is a special tensioning tool for the old engines and a fancy shmancy acoustic tool for the later bikes ( I kid you not, you tension the belt and give it a pluck and the tool measures the frequency) some use a guitar tuner but I still do it by feel. One way is to slide an allen wrench between the belt and tensioner bearing like a feeler gauge. a 6mm one with a moderate amount of drag for the ST2 from memory. Just line up the dot jackshaft pully with the groove on the clutch housing and then make your own markes on the cam pullies. Very easy. Ciao
No worries Pete, thanks. Ahh the smell of lanolin and rubber gumboots:) Ciao
Thanks 68C but you go ahead, I've managed to source a pair. Ciao
Hey thats the same expression I have when I talk to my ex wife:) Ciao
I'd love to Docc, feel a little like Richard Dreyfuss in Close Encounters, mysteriously drawn to Carlsbad, CA to see the great return spring descend from the sky Ciao
I assume you've never been over here? It's a BIG place. It is. After doing around 3 trips to the west coast over the years my wife and I had our honeymoon in the states a couple of years ago and travelled from LA to New York and back by plane. Yep just jump on the plane and 4 hours later your on the opposite coast. Then add the airport fiascos at both ends and, oh yeah, the timezone shifts and bugger we've lost 2 full days there and back. Doesnt seem too big until you go from one side to the other. Ciao You must have a faster plane than we take. It's 4 hours from Indiana to LA non stop. Ha, you're in a bug smasher though Chuck, you know one of those things with a fan on the front to keep the pilot cool:) I just rechecked the flight time LA to NYC and its actually around 5.5 hours. Sure go's quick in coach class with your knees under your chin and elbows digging into your ribs and a flight attendant scouling at you cause you troubled her for a bottle of water. I think i'd rather do it in your machine though Chuck. Ciao
When the new springs come in, I'll put one in the greenie and take a closer look. While the majority of the transmission is the same for the whole V11 series, I have personally seen 4 variations in the pre-selector: 2000 Red-Frame (my Greenie) - the preselector gears are cut-through in places and have teeth only about 270 degrees. 2002 First year of black frame (my Scura) - the preselector gears are solid and have 360-degree gears (many of which never get engaged). this one had the too-large boss, which caused spring-binding 2003 with internal fuel pump (my red LeMans) - same as the 2002, but now with smaller boss. Also has the second eccentric adjuster, where the earlier models had only fixed pins. 2004 (a spare tranny from a parted Nero Corsa that mysteriously arrived at my house one day) - this preselector was the same as the 2003, but added the "banana" reinforcement plate. I installed this one on the LeMans, which is off enjoying Arizona with her new owner. So... with all those changes, Moto Guzzi must have been trying to solve some sort of problem. Has Chuck finally solved it? Only time and aggressive shifting will tell. I'm trying to do my part. Maybe we can make that five variations Scud.My greenie has the early selector gears and small dia selector pawl boss,the late spring, the banana link and double eccentric black cover. Once I have the Chuck/Scud spring I've got it all covered:) Ciao
You forgat about the space needed for the selection of hammers needed to maintain a Guzzi Docc:) Ciao
Buggered if I know what the *Correct* name for them is but they aren't the same as the head gaskets, that's completely different function technology. PM me your address and I'll send you a pair for nix and you can explain it. I'm too old, tired and #@$&@#@.... Thanks Pete, you're the man. Nice to here from you again, seems to have been a while, or is it just me. Ciao
You know if we can ship some here to Aus I can distribute and probably fit them as well if needed. Ciao
Okay, so . . . I took the (moderator) liberty to add that image to LuckyPhil's post. I hope that is cool with LuckyPhil . . . This is sp838's V11. Here is his gallery: http://www.v11lemans.com/forums/index.php?app=gallery&user=9560 Everyone realize, we have some members that don't start threads, might not even post, but have amazing (AMAZING!) galleries. Do not miss exploring the V11LM Galleries! Yep perfect thanks docc Ciao
Thanks Pete, So are these MLS gaskets, you know the same as the latest head gaskets, multi layered steel with the viton black coating? Ducati changed over to them on their covers as well. If thats what you are refering to I'll use them anyway on the old covers as they are great. Ciao
Wouldnt mind using these if someone has a decent pair laying around. http://www.v11lemans.com/forums/index.php?app=gallery&image=1945 Ciao
Well I hate to disagree, but I disagree. After Chuck identified the reason for the original spring breakages and modified the design to mitigate I think the Chuck spring is the way to go. The pull spring mod lacks the elegance, simplicity and economy of componentry of the original design and introduces another potential leak point. No point reinventing the wheel in a more complicted fashion when a refinement, quality enhancement and product improvement of the original design works. BTW chaps I need 3, whatever they cost:) Ciao
While installing new chain and sprockets on my Ducati ST3, I thought I'd weigh the rear wheel. With at least 50% left on a 180/55-17 tire it comes in at 33.1 pounds - which is about 2 pounds less than Docc's V11 wheel with a 160/60-17 tire. So the V11 rear wheel itself doesn't seem excessively heavy. Of course, the Duc only needs to count, as unsprung weight, 1/2 the weight of the chain and 1/2 of what appears to be a much lighter swingarm than the V11. That surprises me Scudd, I thought the ST wheel tire assy would be quite a bit lighter than the V11. You cant escape the bevel box though, its a heavy incontinent mother:) Ciao
So you rushed it then Chuck:) That would take me a lifetime and I'd still mess it up. Ciao
Motratech (or other) dropped pegs likes/dislikes
Lucky Phil replied to Gmc28's topic in Technical Topics
Frank, if those pegs were any further forward they would qualify as footboards:) Ciao -
Joey, Yer marn. I met him at the TT in 86. Although a Factory Honda rider he also competed the smaller classes on his own privateer bike and was wandering around the paddock looking to borrow a fuel funnel. He approached me, and well what are you going to do? Say no to a legend? Had a quick chat, lovely modest down to earth man. Still made me go and ask for it back though,LOL. I think that was the year that the fishing boat he and another racer transported their privateer bikes over on from Ireland sank and they managed to salvage the bikes and still make the TT. Sadly missed. Ciao
Half the swingarm counts as unsprung weight, as does half the drive shaft and chain. Just thought I'd keep the comparison and example simple. I'm sure if you went with a light weight rear wheel it would be a really noticeable improvement. Cant see any reason for such a weighty rear wheel, its almost as if they went out of their way to make it extra heavy. You cant really do much about the bevel box of course except machine off the outer flange as some have done. Ciao
That was me docc, I guessed/estimated 25KG's. Pretty close considering my bike has the 5.5" rear wheel I'd say i was spot on:) So after we have established my amazing ability to estimate these things, I would say my 1198 rear wheel/tire/ sprocket combo would weight around 10KG's. So you see the massive work the V11 shock has to do even before you load it up and ride on shite roads. No point skimping on a repalcement rear shock, you need a high quality unit. Ciao
I think I recall guzzimoto's fork rework with pictures from a few years ago now, might be worth considering or a second hand set of Ohlins production forks would be a lot better than the std V11. Others have used USD forks off a GSXR750 I think it was and the swap wasnt that hard from memory. I have never seen any aftermarket gold valve kit or anything for the std early V11 fork and as I said in my earlier post there is a bespoke manufacturer in the states who's name escapes me at present that can completely replace the internals with their own adjustable cartridges. Ciao
Well it just means that if you spill a little fuel when pulling the nozzle out filling the tank and when the tank cap breather vents that fuel and vapor will go straight onto the frame spine and probably between the cylinders and sit on the crankcases. Did someone say fire risk? The hoses are designed to route this onto the ground when the inevitable occurs. Ciao That was my thinking and that's why I have exiting behind the engine. My question, is there a specific place where it supposed to be fastened? I've got it wedged beside the engine and to the back towards the swingarm. Sorry thought you hadnt connected the hoses at the tank. My bad. Ciao
I think you paid a fairish price, my Wilbers rear shock custom built for me and my riding style with adjustable high and low speed damping and hyd preload adjuster cost me around $800USD about 4 years ago and is better quality than the "production" Ohlins. My GSXR1000 track bike is also fitted with a Wilbers.I've worked on the Wilbers, Ohlins ( production shock and forks and TTX/FGRT shock/forks) Penski, the std Jap and italian stuff Marzzocchi over the years and the std production Ohlins is pretty over rated. It was better than the std stuff on the V11 when it came out but its nothing to get excited about. Its the name as much as anything. My 1198 is fitted with the road and track Ohlins stuff (TTX shock and FGRT 8030 forks) and they are light years ahead of the road stuff. The rear shock on a V11 has a real man sized job to do, just pull the rear wheel and bevel box and feel the weight of that combination. The poor shock has all that mass to try and control plus the road conditions and rider and pillion weight. The rear wheel and bevel box must weigh 25KG on their own. Its rear shock shocker:) The forks on the V11 are pretty rubbish and the only option I found a few years ago was a place in the US that make bespoke internals for just about everything but the cost was going to be around $1200US plus shipping.I passed on that one....its on my win the lottery list:) The std production Ohlins would certainly be a better option here. Personally For anyone out there with the dollars I'd go for a Wilbers again even if its not the all singing dancing version mine is. The quality is very nice and they work. Ciao
