Thanks Docc, I got both the size and material wrong, doh Ciao
Ok cool, looks like I was wrong about the size and material of the original plate, sorry. Ciao
Clutch not fully releasing - and shifting problem
Lucky Phil replied to Scud's topic in Technical Topics
As I mentioned in my selector rework thread I would never attempt to adjust the excentric on the bike,its way too sensitive for that.Try pulling it off and adjusting it on the bench. It adjusts the relationship between the shift stop and gear selector travel. I found that you can actually adjust it so that in some gears it will underselect the gear and conversly overselect another and fully select the gear and then start to actually pull it out of gear before detenting. It's then up to the gear dogs to drag it fully back into engagement.Try pulling it off the trans, put it on the bench and run through the selecting and you will see the relationship I'm talking about and see how it is in the 3rd to 4th selection. If its not great then adjust the eccentric to optimise this pair even if it compromises another pair a little. I actually added some weld to the stops on one of my transmissions. Hows it up shift 3rd to 4th without the clutch Scud? Ciao -
8MM is within a couple of thousandths of 5/16" I've found 5/16"X 4" so far.. 5/16 would work over 8mm I guess. I came to the 8mm decision only by guesstimation based on the original looking like it's 4mm steel and the ally because it's easier to work. From all accounts its tight working in there and I wouldnt like to make a bunch of them without proving the 8mm concept first. How many would be interested in a plate like this? Ciao
It "may" be but the sport used the 5 speed gearbox and the 6 speed engine trans is offset a little in the frame ( 10mm from memory) Ciao
Ok yep, I'm just so time poor at the moment was looking for a quick couple of hours in the shed solution. Dont feel like the complexity of modding the gearbox case for the seperate subframe of the later bikes. Guess I can always make one from 8mm alloy plate if I can ever get this bathroom construction finished. Calling Chuck, 8mm ally plate with a nice relief machined in the visable face? how many are we going to need to make it viable? Ciao
Sorry no the one Docc showed on post 36 of this thread. Ciao
Anyone got one of these transmission plates they could sell me or know where I can get one before I hassle around making one? Not available anymore from my parts supplier. Ciao
Very good, look forward to the pictures. Ciao
Yep, they look perfect. Ciao
Ok whats happened here is due to the gasket not making contact at all the oil hasnt been able to push open the filter reverse flow rubber diaphram and due to the oil flow being from the outer to inner of the filter it would remain empty. Ciao
Yes it could also have another one on the other side of the ball but I didn't have one in my oring box. I use the same on my Ducati1000ss which has a horizontally mounted Ohlins steering damper which due to the changing angles during steering needs to rotate radially as well. Due to the horizontal fitment at straight ahead it can flop about so I fit an oring on both sides of the ball which holds it firm but also allows it to compress the orings a little as it moves radially maintaining function. Its all of course totally optional but if you can limit the unnecessary movement the bearing life will be improved. Ciao
This float is present on the 2 gearboxes I have, the one in service and my good spare. This output drive shaft float wont have any effect on the shifting as its simply a spur gear driven shaft with a shock absorbing coupling. Ciao -
So, if I understand correctly, those spacers are free to turn? Strange.. They shouldnt rotate Chuck. I've had a Rossopuro arm on my bike for years and when I installed it I shimmed the spacers to the bearing inner ball so when the bolt was torqued up it wasnt trying to flex the two brackets together. clearly flexing of the cast brackets isn't desireable but as we know you need to "fettle" a Guzzi. Even aftermarket specific stuff needs "fitting". I also fitted an Oring of just the right size to one side of the ball that bears on the spacer to put a little resistance on the radial rotation of the arm, just to stop the tendence for it to rock around when there's no need to. I'll get a picture when I get a chance. Ok so working from L to R ( top to bottom) is the bracket the spacer then a thin steel shim to eliminate the squeeze,then the inner ball then on the other side the ball again with an oring that sits on the spherical face of the ball to control rod radial rotation a little and cushion the bearing if it does rotate around to its limit then the spacer and the mount bracket. My advice to anyone that needs a new arm is to buy yourself a Rossopuro one or go to the local machine shop with a piece of say 18mm ally rod and get them to chuck it up drill and thread each end for male rod end bearings go and buy youself a pair and fit it up. The machining process will take about 15 minutes, job done. Ciao
Sometimes the system just gets an air lock and wont prime. As a last resort if you're too worried about 15 or 20 seconds of light on before you shut it down you can pull the front cover off the engine take the oil pump drive gear off and use a piece of rubber FI hose on the pump shaft and a battery drill to spin the pump and prime the system. Lot of work though. Ciao
Received my new gearbox OEM seals the other day and they are apart from looking like they've been on a dusyt shelf for 50 years identical to Scuds in design. Now to get some time to remove the generic one and install the oem. Hopefully to last longer than a couple of thousand K's. Ciao
Nothing needs to have "been through the engine" to cause an issue, it may have been oil starvation. Having said that the big end shells do look to have some signs of particle contamination in them, maybe from poor assembly. A 25-50mm micrometer to measure the crank pin is cheap as chips, get one off ebay and measure up the pin. Plastigauge is also cheap as chips and an acceptable way to measure big end clearance without the need for a set bore gauges, which are also fairly cheap BTW. Also look at the internal faces of the oil pump housing where the gear teeth tips run for grooving and scoring. If the pump bearings are really bad its probably worn the housing as well. How deep is that radial groove in the front cam journal in line with the oil gallery? That journal isnt terribley critical clearance wise. Ciao
No this isnt the case, it just dumps back into the bottom of the tank. The head pressure even with a full tank would be very small. From memory 1 ft of water is around 0.4psi and fuel has a lower SG than water. Ciao
This MAY work but will add extra plumbing and complexity to an already messy area of the bike. So a balance pipe between the sides of the tank with the return plummed into it and some sort of mount arrangement for the regulator. Also you will be recirculating a proportion of heated fuel which may or may not be a problem in hot climates in traffic. Early Ducati 851's suffered from vapourisation issues in hot traffic until they revised the return plumbing layout. The issue is not whether it can be done its about doing it in an elegant way. Having plumbing running everwhere with additional possible external leakage points is not acceptable to me. I spent quite a while a few years back thinking this issue through and looking at the physical issues and decided it wasnt worth the effort. Big problems are the original tank fittings are very compact and the internal access in the old tanks is very difficult, so any internal mods or possible connection points for modified fittings is very very difficult. No one way valve fitted in the petcock. Ciao
One thing, your lower sidestand bolts wont have anywhere to bolt to. The other is if you still want to run the oil cooler then you need quite a messy oil filter adaptor plate, custom lines and run the stubby short filter. Forget about running a lower chin spoiler also if thats something you like. Ciao
I like the internal pump system because it keeps the external plumbing way tidier and neater. Ciao I looked at it once, it seemed to me adding an internal pipe from the regulator nozzle to send the gas over the hump would be the way to go, It woudnt solve the issue Roy as when you filled the tank you would still have unuseable fel in the right side. Ciao
Only because Roy, its a little bulky and also just one more thing that can fail and if it does its a show stopper. I spent quite a bit of time looking at the old style tank ( I have a couple of spares) and trying to dream up a solution to the hiding fuel in the r/h side but the tank fittings are so compact and the area around them so tight that I put it in the too hard basket. Maybe you could run a syphon hose over the tank hump internally but you would need to locate it and prime it initially and if you ever ran out of fuel. I like the internal pump system because it keeps the external plumbing way tidier and neater. Ciao
Whats the history of this engine? It looks like its run a big end at some point and been rebuilt with new shells and no work on the crank pin. I know the images alway look worse than real but the shells look semi ok, I mean I've seen far worse, down to the copper etc. ( I wouldnt re use them) but there is interesting marks on the pin which dont seem like normal wear. Is the pin round? any ovality? The pump I'd say is toast, I just measured up my Daytona pump ( which I would be happy to reuse even though they have a bad rep) and it has a shaft to body clearance of 0.003" and a wobble at the end of about 0.004". Bearing in mind the V11 pump has a rolling element bearing it seems too much in your case. New pumps aren't super expensive, better to be safe. Ciao
Yes thought of this a few years ago after running out of petrol a few times but its just to hard with the current plumbing set up and the external pump engines have far to much fuel plumbing externally as it is. The electric petcock is a stupid idea and only there for US regulations that insist that the fuel system has an automatic shutoff of some sort in case the tank is torn off the bike in an accident you wont have fuel spilling everywhere. I have fitted a manual petcock ( as many of you law breakers have) an it stays in the open position at all times, never touch it, why would you bother. Ciao
True, and thats why I tap the last bearing in the last 1/2mm with a hammer and small drift carefully until the spacer clearance is nil. It doesnt matter if the bearing outer race is a few thou off the shoulder in the bore as there is very little actual pure side thrust on the bearings. Ciao Thanks for this, guys. It explains a problem I had recently on my BMW's front wheel. There must have been too much pressure on the inner races and the wheel wouldn't spin freely. I used a socket for that. Since then I bought some bearing drivers that apply pressure across the whole bearing - inner and outer races. Or yes Scud, you could do it the easy way:) I was just saying to my wife yesterday that if there's 2 ways to do something I'll naturally opt for the harder way,sigh. My only defence is that most of the time it's also the better way. The aim of course is to make sure the axial or thrust load between the inner and outer race is minimal and the amount of axial/thrust load you can generate with 60 or so foot/lbs of torque on an axle nut is considerable if the spacer is too short. Ciao
