Lucky Phil
    257
  1. The 130 is probably the spring free length and one of the 50's may be the springs ID.. Phil
  2. It's the rebound adjuster. The reason the pre load collar is wound down so far is probably because the shock was originally fitted with an hydraulic per load adjuster that was removed, or another spring was fitted for use with the hydraulic pre load adjuster which are shorter or the wrong spring is fitted from another manufacturer. The spring probably doesn't have as much preload as you think because the spring is short to make space for the hydraulic pre load adjuster. Phil
  3. That is a Wilbers rear shock and appears to have a spring fitted to suit the optional hydraulic per load adjuster. Thats why it looks short. Phil
  4. I've seen a few interviews with these people over the last few years but nobody's listening for the reasons mentioned. People would rather listen to irrational teenagers. Does anyone know a rational teenager. Phil
  5. Read Dave Richardsons book "My Life in bikes" if you want an idea of the competency of Guzzi USA. Dave ran the Guzzi dealership Moto international for over 20 years and saw it all. Worth a read for sure if you're into Guzzis and the behind the scenes machinations of running a Guzzi dealership. Phil
  6. Inlet manifold rubbers leaking/cracked. Worse when at operating temp because the engine is off the cold enrichment trim and onto the normal fuel mapping and so the air leak makes it lean. The cold enrichment trim helps cover the leanness caused by the manifold leak. I was the first to fit cam gears and it didn't cure my 2800-3200 hick up. A Daytona engine cured that. Phil
  7. It think Mick if your mufflers are the std factory aluminium skinned units they started out black and then have faded through grey to violet. Phil
  8. Thread drift usually means the root of the thread has died or been answered. Phil
  9. Plug caps for plug threaded collar on and plug threaded collar off are two different designs. Collar on plug lead cap has a formed sheet metal internal split sleeve that clips over the spark plug collar and the type that is designed to be used with the plug collar removed uses a machined plug cap internal metal fitting with a spring wire designed to provide the connection and holding friction for the cap. The OP may have 2 different styles of caps fitted. Time to just replace them with some new ones. I have the P/N's somewhere. Phil
  10. So they kept the records of all the VIN's of bikes that had the update completed? Of course then there's the bike with the affected VIN thats had the update done but subsequently been fitted with another gearbox due to a housing crack etc. Or buying a second hand gearbox from the period. Phil
  11. There is no way of telling if your gearbox has been updated by viewing the components. It was a heat treatment and material issue. There's also the gearbox housing cracking and the recall for conrods as well. Now you're fully informed. Feel better now? Phil
  12. The "message" is changing all the time as far as I can see. Phil
  13. I bought it from TLM about 5 or 6 years ago John when they were clearing out all their MGS parts. You can convert a standard one to the MGS ball bearing supported version as it's derived from that. You also need to provide a backstop to the ball bearing in the front bearing bore and seal off the old rear bearing oil feed as well. Phil
  14. No, no pressure feed to the jackshaft rolling element bearings and yes no thermostat to the oil cooler because the MGS engine was never made for road use. Same as it also went back to the smaller and slower driven V11 oil pump. Last thing this engine needs is an oil pump that delivers less oil at low rpm around town. Phil
  15. These arrived a few days ago from Joe. The latest timing gears and oil pump. The pump now uses a bronze bushing for the main drive gear to minimise oil loss through the needle bearing type. I had Joe make my Jackshaft gear 16mm wide as opposed to the alloy gears 18mm width. I don't see a reason for a wider gear if it's now steel instead of aluminium. Pumps L to R....Joes pump, a std Daytona pump and another brand aftermarket pump. The Jackshaft is an MGS-01 shaft. The MGS got rid of the long jackshaft with the additional plain bearing at the flywheel end of the crankcases. That was a carry over from the 2 valve engine which needed the rear bearing as in that engine it was a camshaft and needed the rear support. The MGS shaft is supported by a ball bearing instead of the plain bearing at the front of the crankcase for less friction but it means the oil supply to the heads and oil pressure switch is now blocked so those are fed from the oil cooler connection. I'm seriously toying with the idea of just chopping the rear bearing and shaft off the jackshaft and running just the front plain bearing. I can't see why this wouldn't work and so preserve the integral oil feed to the heads and oil pressure switch. A bit more friction is all I can see as the result. Details from Joe Oil Pump gears are Helical Case Hardened and polished and should give a Hardness around 55-60 R The Bronze bushes have a 1mm shoulder like a top hat to prevent the bush moving towards the crankcase. The large 56 teeth Steel belt pulley large gear is 16mm in gear width compared to the original of 18mm. All the gears are made from en36 or 655m13 which is an upgrade from before as I was trying out this new supplier and so these are shiny and not the usual black Tuftride finish. These are Case Hardened gears which are then polished and so have a harder surface wear finish . The black gears are classed as through hardened in the heat treatment and so not suitable for the polishing process. The case hardened gears have an increase of around 10 Rockwell over the Tuftride gears and so I think they might sound different too.
  16. Lucky Phil
    From the album: V10 Engine
  17. Not as mean as Phillip Island naming a corner after Jack Miller instead of Remy Gardner. I like Jack but he's never won a world title or anything super special except crash a lot. Remy on the other hand has been a Moto2 World Champion at least. Makes me wonder about those that make these PR decisions. Phil
  18. I've heard many opinions on advertising over the years but "concise" has never been one of them. Phil
  19. Well not quite. I dont believe their carts will fit the early silver 40mm forks. 99-2000. Phil
  20. I think Kiwiroy did a diagram years ago. That's where I got the idea. Phil
  21. Lucky Phil
  22. People miss the point of cruise control, it's an anti fatigue device not a motorcycle or car driving/control device. Let me explain. I've been dealing with aircraft autopilots all my working life and the reason they exist is to relieve the pilot of the mental fatigue caused by hours of stick and rudder flying. There's minimal skill required on a commercial jet to hand fly the plane but it does fatigue mentally over hours of doing it. So the concept is to relieve the pilot of that low level mental fatigue that accumulates so he has more resources to focus on the important things like navigation and the upcoming landing. Keep the pilot as mentally fresh as possible. In the commercial aviation world the restrictions of flying a jet with inop autopilots is very severe indeed to the point where we never did it. We just fixed the issue. Commercial pilots don't consider the autopilot system as some sort of slur on their flying abilities which a lot of car drivers do with active cruise control. So car/bike cruise control is exactly the same concept. It's mentally draining over medium to long drives/rides keeping the vehicle on the speed limit or desired speed all the time and now with draconian speed limit tolerances and enforcement it's worse than ever. The cruise control is there to relieve the driver/rider of that mentally fatiguing process so he is free to focus on more important issues like the next corner or the road surface or surrounding riders/drivers. The best invention ever, well almost is Active cruise control. My auto cars have it. The car will hold a set speed up hill down dale apply the brakes if needed when it come up behind a slower car etc. All I need to do is worry about the surrounding drivers and dodging the road kill on the freeway and timing my lane changing. Brilliant. The difference in mental freshness on the regular 9 hour drives I do is dramatic. You get to your destination much less fatigued then before. It's not a system designed to insult the rider/drivers skill level which a lot of drivers seem to think it is but primarily an anti fatigue and therefore safety device. Other electronic aids such as lane keeping assist which is used to help mitigate inattentive drivers behind the wheel I'm not so thrilled about and I turn them off because they are generally too intrusive and not there for fatigue relief but to assist lazy bad drivers not focused on the task of driving the vehicle. Anti lock brakes are another great aid. Lets face it how many people practice their threshold braking to become or even keep proficient at it. Phil
  23. Here's something interesting. I was talking to my SIL's father a few months ago about this. He's a retired physicist thats spent a good deal of his career in the oil industry. Our long held beliefs and education of the origins of oil are quite possibly flawed. In the history of all forms of drilling for exploration nobody has ever found fossilised material below a drilling depth of 16,000 feet. So thats the maximum depth ever recorded for buried originally organic material, material that may under the correct conditions be turned into a hydrocarbon or crude oil. So why then is a large percentage of our oil derived from wells between 28 and 32,000 feet? This may be the answer and means that oil reserves are instead of being a finite resource are more like a continuing by product of the earths naturally occurring geological conditions. So oil is the product of dead forests under the influence of pressure and heat? Quite possibly not as it turns out. Saturn's larges moon Titan has also been speculated to have vast subsurface deposits of crude oil by both NASA and the European space agency after reviewing probe information. There's never been forests on Titan as the surface is a sea of Methane. https://www.intechopen.com/chapters/41889 As for the death of ICE vehicles, don't worry it ain't going to happen in my lifetime. Phil
