Lucky Phil
    266
  1. I have the 641 fitted to my V11 Sport.Adjustable comp (high and low)rebound and ride height as well.Really nice shock,just as nice as the Ohlins fitted to my 1198s. Ciao
  2. Fail.... Ciao
  3. Thats great Roy but no point posting this without details so we can learn something. Ciao
  4. Good color that green. Ciao
  5. You dont need to navigate anything,I supplied the direct link. Ciao
  6. The drive plates and flywheel/pressure plate are all held together as one unit when the clutch is engeged but the drive plates can still rattle on the gearbox input drive adaptor splines.This is where I believe the noise comes from.I think flicking the clutch causes the drive plates to misalign slightly with each other on the drive splines and take out the slop.Letting out the clutch slowly allows the drive plates to both align on the same side of the splines and creates a little play and it rattles. Ciao
  7. I think it is the cost-reduction. Parts same as on aprilias and etc (those with two wires on gas command) Also, later models of V11 has two wires instead of one. If it was twin cable throttle assy then the other cable position would be on the opposite side. Ciao
  8. Its the clutch and a little gearbox as well,but mainly the clutch.You will find if you dip the clutch quickly it will be almost entirely eliminated.This is the two friction and the intermediate plates realigning in the flywheel and taking out the slack so it doest rattle and clunk.If you dip the clutch slowly it will still tend to rattle/clunk at idle. I just give the clutch a flick if I'm warming it up so its quiet. Ciao
  9. Mine is a Stucchi luigi from MG cycles.Same as Bbennetts. Made to order painted and also available in Carbon.Nice piece fits well. http://www.mgcycle.com/product_info.php?products_id=2643 Ciao
  10. There are a few parts that would be worth buying, but other than that it seems pretty far gone. I've heard that even after fairly low speed crashes, spine frame Guzzis don't recover well. Pretty far gone???? That my friend from the photos is a very lightly damaged motorcycle.Please call me if you ever fall off your bike,I'll buy it off you for a song. It looks like some clown that doesnt know the trick to undoing the fuel couplings has used wire cutters to snip the fittings but apart from that most of the damage looks cosmetic and fairly minor. Me personally,I would ditch the fairing and replace the broken bits with good SH stuff off ebay and have a nice Naked version. Ciao
  11. Ok,soaked the large pinion ring nut in wd40 and managed to loosen it with a hammer and alloy drift a little.Just to get it moving.Couldnt get it to tighten any more than it was previously,so the original play still exists. Ciao
  12. Was checking the drive shaft on the V11 sport the other day and noticed some play/movement in the pinion shaft.I removed the bevel box/drive assy and I have approx .4mm total radial play and approx .075mm axial. Reading through some old posts I came across Peter Ropers thread on this from 2004 which was very interesting. I tried to tap/drift the large ring nut tighter and looser but it wouldnt move,so I guess I need to make a tool. Question is.....is the play/movement I have excessive for a 40,000klm old unit? I know in an ideal world it should be next to zero but I dont fancy pulling the whole unit apart to check bearings that may not be new but stll quite ok to continue in operation. I also drained the oil to check for metal contamination but the previous owner has obviously used some sort of Molly additive and the oil is as black as tar and its almost impossible to see anything in it.The mag plug came up fine with just some black paste I would expect to see.So apart from the noted pinion shaft play there is nothing else I am concerned about.....thoughts? Ciao
  13. First ones ok,the second 2 are pieces of sh*t. Ciao
  14. ... that's why they call it death-wobble I guess But no need to argue here. When I checked lorry wheel bearings on a weekly basis once this was the proper method. Screw in the bearings until you feel the wheel going locked, then loosen 45° and fix the nut. Easy thing. Some good time ago we discussed here what adjusting method the fellows down in Mandello would use for this task. Besides avoiding any grease in this process they obviously get the rest of it working astonishing well. One had the idea they might use a spring balance attached to one fork leg and then torque the bearing down until moving the fork shows the proper force (or responding hinge moment). I mean, you normaly can't tell a badly paid line worker "just make it right", they need some objective guideline. hubert There is a definite difference between the adjustment of a tapered bearing when used on a lorry or automotive wheel application and that of a steering head bearing on a motorcycle.When adjusting for a "wheel" application then slightly loose is preferable to slightly tight.This is because of the heat generated by the spinning bearing in that application. On a motorcycle steering head heat generation due to rotation is not an issue and the focus is on zero play or slack without to much drag or tightness. So to sum up tapered bearings....for automotive wheel....er on the side of play and for motorcycle steering heads......er on the side of zero play or slightly tight.Steering head bearings should be adjusted so they "never" have any play Ciao
  15. They sound nice apart from a slight tendency to whistle at some points on the over run like an old Norton Commando.Just fitted a set of Mistral Titanium cans and they sound quieter and more mellow with no whistle at times.(see recent thread) Prefer the sound of the Ti cans and the look of the Megaphones. Ciao
  16. No they are standard.I'd actually like them a little higher and back,right about the spot the swingarm pivot is.Looks like I will have to make my own solution for this. Ciao
  17. Got a great deal on these Mistral Ti pipes just recently.They sound nicer than the Mistral megaphone style I usually have fitted but I dont like the "look" as much.Bike seems to fuel slightly better with these as well. Ciao
  18. I'd rather stick to the 90mm cylinders.Power isn't the priority and boring cases is a lot of hassle.Yes I'm waiting with you for the pump and gears from Joe.I'm talking to Dynotec now.Thanks for the leads. Ciao Phil
  19. front jackshaft flange wear and cam drive gear wear.
  20. Well as promised here is an update on the conversion so far.The Centauro engine has just arrived and I've stripped it down to the crank.It has a few issue to deal with. All lifters are shot and need replacing. One rocker pad worn where it bears on the lifter and will need rework or replacement. Cam drive gear is heavily worn Oil pump is actually not to bad and could could be reused,but I have a new aftermarket one on the way along with a set of Joe Caruso gears both cams scuffed but probably saveable.Why do Guzzi NOT have the cam oiling hole on the base circle of each cam lobe.Totally silly design. Cam tensioner pulleys both worn and req replacing The timing wheel has for some reason tried to chew its way through the cam retainer flange,requires replacement. Both cylinders worn,pistons are actually in good condition,ring end gaps around .42mm.Could run a flex hone through the bores and re ring it but would rather renew.Problem is getting piston/cylinder assy's.A business close to me will re nickasil the cylinders but its not cheap.Any contacts and options for cylinder and piston kits would be appreciated. Havent yet checked the valves for guide wear or pulled the crank.Will of course renew all the main and bigend bearings as a matter of course.Will also lighten and balance the crank significantly. The fun has just begun,this could take a while. Ciao
  21. Looks like the std cans may be just a carbon skin over a SS body. I've never seen this before.All the carbon cans I've ever worked on are a perforated tube surrounded by fibreglass packing and a carbon sleeve only.Works well but you have to be dilligent with the assembling and maintaining of the glass packing because any direct leakage internally onto the carbon skin will burn it in a short time.Some carbon skins have a type of metal flame spray on the inner surface to help with this.You will see this by brown marks and eventually it will burn through. Ciao
  22. Something people may have overlooked is that wrapping the headers also makes life hard on the mufflers as it puts a LOT more heat into them.Probably not an issue with general road riding with Ti or alloy cans but if you have carbon skin cans then I'd recommend you stay away from the wrap. Wrapping the headers on a Ducati 996 superbike a friend used to race back in the 90's saw the carbon cans last about 10 laps before failing in spectacular fashion. Didn't just happen once and they were new cans. All that insulated heat has to now go out the mufflers and at the very least even on a road bike it will make life a lot harder on the carbon skins and glass packing if thats what you have. The other factor is that the Guzzi is an air cooled engine and in most cases needs all the cooling help it can get.Why would you add to the impost on its marginal ability to cool by wrapping the headers with no real benefit to performance? Add to that the fact that it will eventually look tatty and require replacement and it starts to look more like the "i'm bored and need a cheap project" thing to me,or a conversation starter at the pub. Ciao
  23. Thats because every time you cycle the ignition switch on with the kill switch in the run position the fuel pump runs and the ECU fires a shot of fuel into the inlet manifolds.Its a pre charge to help starting. Ciao
  24. Seems like cracking a walnut with a sledge hammer to me. Ciao
