Lucky Phil
    267
  1. All come pre charged these days Chuck that I have seen but you still need to vacuum them according to the install instructions. You need to purge the lines from the a/c unit to the header unit and they can be 5 or 6 meters long. You need to evacuate those lines. Phil
  2. Lucky Phil
    Help
    The early bikes had a black and the later bikes Violet from the wiring diagrams. The others look to be the same colour as is the orientation. Phil
  3. Yes Chuck a small split system is the way to go. If 2.5kw or under here they are simply plug and play so you don't need an electrician. Just install yourself using a vac pump to purge and you're golden. Phil
  4. Lucky Phil
    Help
    Now I think about it the manual fault was in a manual I have for the Daytona and 1100 Sport IE. One had the PF03 and the other the PF09 but the pins are not the same orientation. The manual didn't differentiate this which led to confusion for me making an adaptor cable as has my previous post. Phil
  5. Lucky Phil
    Help
    I suspect you have the wires connected to the wrong terminals. One of the manuals is wrong when it comes to the outer terminal to connect to. Try using the centre and the other outer terminal. Phil
  6. Yes a Ducati SS
  7. Me thinks MM got the inside info on Pramac maybe not staying with Ducati and didn't want to be stuck with a Yamaha and the rest of the handbags at 50 paces from Campinoti is just smoke and mirrors.
  8. Lucky Phil
    Help
    AS pointed out the MV setting is for a fully shut throttle blade on the RH cylinder with the idle stop backed out and the fast idle lever clear of the cam. I use a small tie wrap to hold the rh throttle blade fully shut to set the MVolts with the LH throttle blade disconnected via the circlip holding the linkage on the LH throttle actuating mechanism. Once the MV's are set I then confirm the connecting rod pin will slide through the l/h throttle blade bush with that blade fully bottomed in the throttle body bore then re connect the linkage. Phil
  9. You can buy a tester for 12 bucks Au Mick and I have brake fluid in sealed containers that are 10 years old and still zero water content. I've also bought new fluid that was 1.5% water contaminated out of a sealed bottle. Thats why I open it and test it at the counter in front of the staff before I pay for it these days. Phil
  10. I can't believer people still manual bleed brakes and clutches when you can use one of these. Dirt cheap and a million times more effective. I actually use a Motive products bleeder which was way more expensive at the time I bought it. Vevor sell good stuff. Phil https://www.vevor.com.au/fluid-evacuator-c_10350/vevor-car-brake-bleeding-clutch-fluid-bleeder-kit-vacuum-pump-3l-air-powered-p_010315405734
  11. Why? Phil
  12. Lucky Phil
    Speedo
    A speedo doesn't need to be accurate it just needs to be consistently inaccurate. Same as a timepiece for navigation doesn't need to be accurate just consistent in it's inaccuracy. In my 3 cars the speed indication varies at 100kph by 2, 4 and 6kph for each one. Over reading always. I know the inaccuracy and adjust my speed accordingly. Personally I'd just use my phone GPS speed for a short run on the bike, detect the speedo inaccuracy and then set your future riding speed accordingly. The last thing I personally would want on the bike is yet another instrument and wires and pickup all powered by a button battery to add clutter and complexity. PS the police in Victoria Australia will ping you for anything over 4kph over the limit. Thats under 2.4 mph so they are brutal here. Phil
  13. What does all this mean. I'll make my own nut and cut the thread myself on the lathe. Phil
  14. Doesn't rattle at idling at the lights docc, no good. Then again neither does a quality aftermarket Ducati Dry clutch. This is the EVR slipper unit on my 1198 track bike. The only noise you hear at idle is the straight cut primary gears clattering the clutch is quiet. Note Mick the vented cover....because it's cool and cooling https://www.desmo-racing.com/en/sliper-clutch-cts-racing-sbk-48-evr-ducati-xml-253_351-2812.html
  15. The thing weighed 321KG wet! Thats not a motorcycle it's a big fat wide horrid contraption of some sort. Any bike that weighs 321KG is a disgrace. Phil
  16. It is 1mm pitch. Phil
  17. Red frame. Smaller diameter. Phil
  18. Lucky Phil
    ECU talk
    Yes Pete. My RE 650 fuels perfectly, and I mean perfectly all the time. back in the late 90's I owned 2 Triumph Daytona triples a 98 and a 99 model. Both had Sagem injection and were a year apart in manufacture dates and in the 12 months Triumph had learned absolutely zero about how to get them to fuel nicely despite numerous map updates. Still stalled pulling up to traffic lights regularly etc. My mate had a customer Daytona race bike in the shop and retro fitted a Motec ECU to it and we went to the dyno to map it and Pete had it perfect in about 20 min on the dyno. Sagem and Triumph couldn't get them right for years. That dyno run was interesting in that Pete ran the bike up to redline in 4th or 5th gear and on the run down unplugged the original Sagem ECU and installed the Motec and it just continued running as it came back to idle. Then the fine tuning started.
  19. I know I'm a grumpy old man these days but there isn't a bike in that video I'd have any interest at all in owning. If I was the owner I'd sell all of them and buy 2 decent bikes with the money. Funny these days how people lust over motorcycle that we were all puking over back then.
  20. Mitsubishi or Dakin. I have both. Phil
  21. Because it's "cool" Mick and it's like a MotoGp bike clutch. Anyway dry clutches are the overwhelming majority out there in the Automotive world. An Aussie company is now making twin disk automotive clutches that are "universal" and don't rattle at idle like all other performance car twin disk clutches. https://uniclutch.com/about Phil
  22. I was thinking more of single point threading it and there is a larger ID visible on the outside of the nut that means you can thread all the way through. Phil
  23. I haven't been able to figure out how to take images of the future yet docc. I'm still busy figuring out how to take images of events that didn't occur Phil
