Lucky Phil
    268
  1. The "message" is changing all the time as far as I can see. Phil
  2. I bought it from TLM about 5 or 6 years ago John when they were clearing out all their MGS parts. You can convert a standard one to the MGS ball bearing supported version as it's derived from that. You also need to provide a backstop to the ball bearing in the front bearing bore and seal off the old rear bearing oil feed as well. Phil
  3. No, no pressure feed to the jackshaft rolling element bearings and yes no thermostat to the oil cooler because the MGS engine was never made for road use. Same as it also went back to the smaller and slower driven V11 oil pump. Last thing this engine needs is an oil pump that delivers less oil at low rpm around town. Phil
  4. These arrived a few days ago from Joe. The latest timing gears and oil pump. The pump now uses a bronze bushing for the main drive gear to minimise oil loss through the needle bearing type. I had Joe make my Jackshaft gear 16mm wide as opposed to the alloy gears 18mm width. I don't see a reason for a wider gear if it's now steel instead of aluminium. Pumps L to R....Joes pump, a std Daytona pump and another brand aftermarket pump. The Jackshaft is an MGS-01 shaft. The MGS got rid of the long jackshaft with the additional plain bearing at the flywheel end of the crankcases. That was a carry over from the 2 valve engine which needed the rear bearing as in that engine it was a camshaft and needed the rear support. The MGS shaft is supported by a ball bearing instead of the plain bearing at the front of the crankcase for less friction but it means the oil supply to the heads and oil pressure switch is now blocked so those are fed from the oil cooler connection. I'm seriously toying with the idea of just chopping the rear bearing and shaft off the jackshaft and running just the front plain bearing. I can't see why this wouldn't work and so preserve the integral oil feed to the heads and oil pressure switch. A bit more friction is all I can see as the result. Details from Joe Oil Pump gears are Helical Case Hardened and polished and should give a Hardness around 55-60 R The Bronze bushes have a 1mm shoulder like a top hat to prevent the bush moving towards the crankcase. The large 56 teeth Steel belt pulley large gear is 16mm in gear width compared to the original of 18mm. All the gears are made from en36 or 655m13 which is an upgrade from before as I was trying out this new supplier and so these are shiny and not the usual black Tuftride finish. These are Case Hardened gears which are then polished and so have a harder surface wear finish . The black gears are classed as through hardened in the heat treatment and so not suitable for the polishing process. The case hardened gears have an increase of around 10 Rockwell over the Tuftride gears and so I think they might sound different too.
  5. Lucky Phil
    From the album: V10 Engine
  6. Not as mean as Phillip Island naming a corner after Jack Miller instead of Remy Gardner. I like Jack but he's never won a world title or anything super special except crash a lot. Remy on the other hand has been a Moto2 World Champion at least. Makes me wonder about those that make these PR decisions. Phil
  7. I've heard many opinions on advertising over the years but "concise" has never been one of them. Phil
  8. Well not quite. I dont believe their carts will fit the early silver 40mm forks. 99-2000. Phil
  9. I think Kiwiroy did a diagram years ago. That's where I got the idea. Phil
  10. Lucky Phil
  11. People miss the point of cruise control, it's an anti fatigue device not a motorcycle or car driving/control device. Let me explain. I've been dealing with aircraft autopilots all my working life and the reason they exist is to relieve the pilot of the mental fatigue caused by hours of stick and rudder flying. There's minimal skill required on a commercial jet to hand fly the plane but it does fatigue mentally over hours of doing it. So the concept is to relieve the pilot of that low level mental fatigue that accumulates so he has more resources to focus on the important things like navigation and the upcoming landing. Keep the pilot as mentally fresh as possible. In the commercial aviation world the restrictions of flying a jet with inop autopilots is very severe indeed to the point where we never did it. We just fixed the issue. Commercial pilots don't consider the autopilot system as some sort of slur on their flying abilities which a lot of car drivers do with active cruise control. So car/bike cruise control is exactly the same concept. It's mentally draining over medium to long drives/rides keeping the vehicle on the speed limit or desired speed all the time and now with draconian speed limit tolerances and enforcement it's worse than ever. The cruise control is there to relieve the driver/rider of that mentally fatiguing process so he is free to focus on more important issues like the next corner or the road surface or surrounding riders/drivers. The best invention ever, well almost is Active cruise control. My auto cars have it. The car will hold a set speed up hill down dale apply the brakes if needed when it come up behind a slower car etc. All I need to do is worry about the surrounding drivers and dodging the road kill on the freeway and timing my lane changing. Brilliant. The difference in mental freshness on the regular 9 hour drives I do is dramatic. You get to your destination much less fatigued then before. It's not a system designed to insult the rider/drivers skill level which a lot of drivers seem to think it is but primarily an anti fatigue and therefore safety device. Other electronic aids such as lane keeping assist which is used to help mitigate inattentive drivers behind the wheel I'm not so thrilled about and I turn them off because they are generally too intrusive and not there for fatigue relief but to assist lazy bad drivers not focused on the task of driving the vehicle. Anti lock brakes are another great aid. Lets face it how many people practice their threshold braking to become or even keep proficient at it. Phil
  12. Here's something interesting. I was talking to my SIL's father a few months ago about this. He's a retired physicist thats spent a good deal of his career in the oil industry. Our long held beliefs and education of the origins of oil are quite possibly flawed. In the history of all forms of drilling for exploration nobody has ever found fossilised material below a drilling depth of 16,000 feet. So thats the maximum depth ever recorded for buried originally organic material, material that may under the correct conditions be turned into a hydrocarbon or crude oil. So why then is a large percentage of our oil derived from wells between 28 and 32,000 feet? This may be the answer and means that oil reserves are instead of being a finite resource are more like a continuing by product of the earths naturally occurring geological conditions. So oil is the product of dead forests under the influence of pressure and heat? Quite possibly not as it turns out. Saturn's larges moon Titan has also been speculated to have vast subsurface deposits of crude oil by both NASA and the European space agency after reviewing probe information. There's never been forests on Titan as the surface is a sea of Methane. https://www.intechopen.com/chapters/41889 As for the death of ICE vehicles, don't worry it ain't going to happen in my lifetime. Phil
  13. Usually the latter Mick. I once bought a Ducati ST2 off a friend as a "favour" to him. He needed the cash. It was out of rego, been dropped on the right side and the Termi can carbon cover was held on with cable ties, the rear disk was undersize and required replacement to get through rego, the LCD fuel gauge was broken and didn't work, the front wheel bearings were shot, the r/h fairing was cracked from the drop and he hadn't washed it in 18 months. He wanted $7200 for it when they were asking $7400 for a low mileage mint one, so probably get it for $7000. I offered him $6000 and I'd take care of the rego inspection and repairs and he didn't have the hassle of advertising it. It ended up costing me an extra $1800 to repair plus rego. So $8400 all up and lots of work to own a well used and unloved ST2 as a favour to a friend when I could have had a mint one for $7000 maybe $7200 tops and zero work. Outcome. I now owned a bike I never particularly wanted to own and he thought I'd taken financial advantage of him and he never spoke to me again. People, go figure. Phil
  14. Ha, just checked MCS and the last V11 year model listed is the 2003 Ballabio. Here's me thinking they made them until 2006. I told you I find the year model thing confusing. Phil
  15. What about later bikes post 2002 to the US like the Le Mans and all the other naked variants from 2002-2006? All 15M in the USA? Phil
  16. This reminds me the MGS01 came with the 15M and PF09. Next time I connect GD I'll select MGS01 from the drop down box. Phil
  17. Thats true Pete but mine and Gritmans use the 15M with PF09 TPS's. Although the images of the Sport IE I have seen uses the PF03 TPS Phil
  18. I know Mick I've done it a quite a few times. My question is probably better phrased, "What selection do you make for model from the initial drop down box". That would be weird as the PF09 never reached the V11 series, it was dumped with the Daytona and Centauro I think and didn't even make the 1100IE Sport either I don't think. Phil
  19. How old is the fuel? Does it have actual fuel pressure ( I know the plugs are wet but maybe the fuel pressure is low and that just causes fuel puddling worse than normal in the intake manifold and drowns the spark) how long since it's been previously run? Are you using std plugs or fine wire plugs? ( once FW plugs are fouled they are junk) Not sure about the GD issue. How do you select the model of bike from the drop down box? I use V11 Sport for my V10 Sport with the same ECU and TPS as you but I'm not sure if I get the IAW15M PF09 or IAW15M PF03C. I think the latter. The TPS identifier shouldn't matter as they are both non linier but what std model uses a 15M PF09 configuration? I can't think of any unless GD reads the actual TPS fitted. My bike used to be very hard to start and keep running during warm up before I re mapped the cranking enrichment map and revised the engine temp enrichment break points which were based on the V11 sport 2 valve engine in my original 8 valve maps. Now it's very good to start and warm up. There is a process however. Open the fast idle 90% and don't touch the throttle and it fires up withing a few seconds on the starter and goes to 1800 rpm. From there you can back off the fast idle to around 1500 rpm and after about 30 seconds you can use it to keep the rpm at that figure for a minute or two then ride it. Phil
  20. Yes a 180 on a 4.5 rim is wrong and I don't know anything about tyres. Phil
  21. My 1198 rear tyre. The bikes not even run in yet Phil
  22. Relays, Ignition switch, Connectors, earths, R.I.C.E. The V11 Sport electrical troubleshooting guide. Phil
  23. Umm, really. Don't know about others but once I've set up the preload and compression damping to my riding and road conditions I don't need a travel indicator again. Besides a slight smear of grease with your finger indicates just as well when the dust seal wipes it down under compression. Phil
