ANSWERED Acceleration Enrichment Map-2004 Rosso Corsa
Lucky Phil replied to Rob NZ's topic in Technical Topics
A few things. Lambda sensors were fitted to, well most injected vehicles for a few purposes and in V11 terms none of them were to make for a particularly better riding experience. They were installed for emission and to some extent fuel economy related reasons and for CAT considerations. So at "steady state throttle settings" and a certain rpm band the O2 sensor trimmed the fuel to stio correct or whatever it's target happened to be. Generally this area was what we would call the cruise area. Steady state rpm and throttle angle. Freeway cruising in the main. The other area Lambda sensors are advantageous is for Long and short term fuel trim applications to trim the fuel system as the name suggests. So the ecu can compensate for engine wear and various other mechanical degradation and trim the main fuel maps accordingly, LTFT. It can also adjust short term fuel trim STFT to compensate for things like dirty air filters etc and also general driving habits. The STFT can be " nulled" by pulling the ecu fuse or disconnecting the battery as it's a volatile memory. Commuting will in a lot of cases influence the STFT and affect the riding/driving experience in a slightly negative way. Pulling the ECU fuse will reset this and the STFT will revert to the original zero setting and improve the engine running slightly until the trim shifts it again. It's an arguable thing but lots of people do it. Wide band sensors work better than the cheap narrow band sensors that's been a fact for many years. So basically the LAMBDA system in the V11 context and most earlier generation motorcycle systems were for emission related reasons combined with fuel economy not for a better riding/driving experience and in car applications for the same reason plus the afore mentioned LTFT and STFT ability because cars do a lot more miles than motorcycles generally with a lot less attentions to keeping them tuned and serviced and running well. If you have a V11 with the later 15RC ecu and Lambda fitted then simply disconnecting the Lambda and mapping the ecu will give you a nice result without the Lambda system complexity. Maybe the fuel economy will be slightly worse, not sure but then again if it's nicely mapped it will be slightly better than stock probably. Phil -
Gigi has a history of liking to give riders he believes were treated unfairly, overlooked or considered has-beens a chance or second chance' Iannones signing is no surprise to me. Phil
What's my first rule about troubleshooting before you do anything else. Ask yourself the question "what was the last thing I did before the issue arose"? Wash the bike? fuel the bike? Have the seat off? replace the battery? You get the idea. Phil
MotoGP is fast disappearing up it's own arse like F1 has. Less and less relevant to the buying public and less and less about the riding and more and more about the tech and the "show". That's why WSB is so much better than Motogp these days. Aero and ride height devices have ruined MotoGP as smarter people close to racing predicted it would. It hasn't completely wrecked it but it's on the pathway. Now we have a situation where every rider is riding at 100% all the time and the difference in winning or not winning is down to the bike and what setting or tyre you chose or whether or not you got into a group and your front tyre overheated or you had a poor qualifying or someone got a tow from you in qualifying and although you were actually faster than them on a hot lap you towed them around and they gained 2 tenths on you thanks to your tow and you ended up two rows back on the grid to them because of it! When a rider can no longer "make the difference" in a race by shear determination and sticking his neck out to overcome a slight setting issue or tyre choice then it's going in the wrong direction. Speaking of qualifying we need to return to the one lap shootout system. Riders getting a tow off faster riders or riders getting shafted on their last "hot lap" because another rider has crashed and brought out the yellows is a joke. Now qualifying on the front two rows of the grid is mandatory for a decent race result because of the Aero and suspension issues you need to have a truer picture of who has the raw speed and award those riders accordingly. No point having a rider who should actually be on the 4th or 5th row on raw pace actually being on the front or second row because he used the faster rider for a "tow". The flag drops and he just gets in the way of the guy who's actually got the pace. Aero is the reason front tyres overheat and the reason overtaking is more difficult and it's totally a blind alley for road bikes. Same as squatting devices and front suspension launch devices. Because Dorna dumbed down the electronics and banned electronic on the fly suspension control which are a direct benefit and eminently transferrable to road bikes the MotoGP engineers turned their attention to Aero as another measure to claw back some of the loss. Problem is none of the Aero or manual squatting devices are useable on a road bike so the technical investment is a dead end to the manufacturers and the consumer. Don't confuse the aero on superbikes as useful they are almost entirely a decoration and a joke to the aesthetics of a road sports bike. Have you seen the ridiculous front wing on a BMW and they still can't win races with them. At the core of motorcycle racing is the rider NOT the tech. The further down the none relevant for the consumer tech road the less it becomes about the rider. It's what has always separated motorcycle racing from the joke F1 has become. If you are going to move ahead with the tech which is inevitable then at least direct it down the path that benefits and is relevant to the consumer. Speedway is one form of Motorcycle racing where the tech has deliberately been capped for 40 years or more to make it a "sport" about the racers NOT the motorcycle. Seems to have worked well. Not supporting those measures entirely but the current direction by Dorna is all about the "show" and not the sport. I see now the riders are forming a union so they have some say in the direction of MotoGP racing. Might be a good thing I think. Phil
If you load Meinolfs map it's done for you as is the fuel map. His advance is between 21-31 around the same area at 5.2 degrees T/A and 26-29 degrees at 36 degrees T/A @ 3200.That would be my suggestion. It's free to do. Phil
There is no limit to the adjustability of the mapping. You can make it anything you like in any region, both fuel and ignition. Phil
Thats a statement that can't be uttered until you have put a few thousand miles on the bike in all weather conditions. Out of interest I loaded and compared Meinolfs V11 fuel map to the std v11 Sport map and looked in that low throttle angle V 3000 rpm range and noted it's massively richer in that general area. Although Meinolf has messed about a bit with the throttle and RPM break points in some areas it's around 100% richer than the std v11 map. Interesting. Phil
I've never thought going to shows for the latest cars or bikes worth the time, effort or cost unless you are actually in the market for a new bike and use it as a practical means of comparing the bikes or cars you are interested in at one venue. For some strange reason there also seems to be a lot of posturing and ego displayed by the sales people at these events as well. Maybe that's just me. Phil
Apologies for that 6 minutes a fellow Aussie has stolen from your lives if you watched it through. The video starts off well when he can't actually get the name of the bike right (he called it a Mondello) On a positive note all the riding was done around my area of the world. The Black Spur and Reefton Spur are my local rides and the Guzzi Museum was built and is owned by Teo Lamers who retired to here and owns TLM Guzzi in the Netherlands. It's just over an hour away. Phil
The front Brembo rotors on my 1000SS were below min thickness in 13,000klms that's one reason I replaced them. The original owner used to do a lot of pillioning. The rear disk on my DucatiST2 I had to replace at 42,000klms of previous owner miles due to being under spec. Wouldn't pass a rego check.
Nineteenth South'n Spine Raid 2023 Tennessee USA
Lucky Phil replied to docc's topic in Meetings, Clubs & Events
I've actually been stopped by them another time . This occasion in a French registered Renault Megane somewhere in Italy, Florence maybe, cant remember now. Not stopping for a pedestrian at a pedestrian crossing. The pedestrian was half way across the opposite side of the road and hadn't actually reached the middle of the road and my side of the street so as all Italians do I kept going. Italians don't stop at a crossing for pedestrians until they are about to cross your side of the road. The Carabinieri stopped me, thinking I was a French tourist, saw the Aussie passport and waved me away. The Aussie passport, ticket to do anything at the time. Oh and NOT being French or German. My wife spoke Italian which also helped. Phil -
I wonder if I'm the only one here that's been pulled over by the carabinieri? Maybe not but I bet I'm the only one that's run into the back of a Carabinieri 4WD full of them. Once they found out I was an Aussie and not a German like the Rego plates on my BMW indicated they didn't give a rats arse and were on their way again. Phil -
Just make sure you email them before you order. I bought and paid for a new Brembo calliper from them a few weeks ago and they informed me they aren't available anymore which I already knew. So they don't stock stuff. They refunded my payment promptly but I lost out on the exchange rate and charges and they had my funds for 5 or 6 days. I mentioned this scenario in a recent post. None of these sellers carry stock and they don't keep track of the availability from their suppliers. Personally I'd go for wave disks myself. Phil
You can use "Braking" disks or Galfer disks. I have used both. The part is as common a fit as mud. The Braking disks are mono directional so separate part numbers and the Galfer are Uni directional so same number. Same disk as my 2003 Ducati 1000SS and many other bikes. I can get the numbers if anyone needs them. I have the Braking disks on my 1000SS and the Galfers on the V11. Shopping around I think you can buy a pair new for around 550-600usd. Phil
Thats like treasure to me. I like the "discovery" aspect of a trove like that. Discovering just what treasures are in the boxes. I'll be interested in V11 parts for sure. Phil
The answer is in the thread drift I think. Phil
You haven't heard the half of it. Get Mick to relate the recent new noise laws in a particularly nice part of Germany frequented by a lot of weekend motorcyclists that are so draconian even the local Polices can't use their Ducati police bikes because their std mufflers are too loud. One of the German members on the Royal Enfield forum happened to mention how when he rides his 650 twin around he "just naturally" turns the engine off at every set of traffic lights or stop sign etc and restarts again to move off. "Just like modern cars do automatically!" Needless to say people were flabbergasted at this "environmentally concerned madness". Imagine on your V11 where every start irrespective of the engine temp or OAT the ECU gives you the start enrichment trim for 4000 revolutions. Your saving the planet shut the engine off at every set of lights is actually creating more pollution than leaving it running not to mention the engine oil cooking itself around the exhaust ports because the oil flow has stopped and the oil now heat soaks from the heads causing future engine issues. Crazy dumb stuff going on out there these days and I don't think it's a particularly a German issue more a Europe/EU issue. Unfortunately we are getting dragged down the same path by politicians. Phil
I know you were serious Mick, I know the draconian German rules I was just joking with you. NSW had yearly registration inspection requirements for cars over 3 years old and it was sold as a way of improving safety. Victoria has never had yearly inspections and the mechanical quality of Victorian cars is no worse than NSW cars. It's not like here there is a noticeable percentage of heaps of shit driving around our roads, nope. No headlines about tragedies caused by mechanical failures. So after living in NSW for 45 years and Victoria for 20 it's obvious the yearly inspection requirements are just another draconian way to cost the motorist money and impose nanny state rules on people. The Germans take it to another level though and I seriously don't know how the average earning Motorcycle or car enthusiast tolerates it. All the high end enthusiasts are fine because they can afford the massively expensive "TUV approved" accessories although I don't know how some of them can be approved when you hear them here on the roads. I'm now beginning to like the Harley riders getting around with straight pipes and riding flat out everywhere. They make the rest of us with sensible although illegal mufflers on their bikes fly under the radar. It's a finger up to the authorities. The cops never bother them anyway. None of the bikes I own now and very few in the past have ever had std mufflers and as for other mods well I'd be here all day. Can you imagine riding a Bevel drive Ducati around with the std Lafranconi mufflers the later ones were approved with? First thing that went on the shelf were those and the Contis fitted rules or no rules, EPA roadside inspection or not I wasn't riding my Hailwood Ducati around with the original shit Lafranconis on it. We have proud history here of fighting stupid rules like the mandatory headlights ON, the front number plate rule they tried to impose, the illegality of bikes with dual headlights like the Ducati 916 the list goes on. Proudly recalcitrant me. Phil
You're kidding aren't you Mick Phil
