I've been banging on about how good these things are for years after Pete recommended them. If you also don't have a spare later front timing chain cover gasket of the same style then I've been wasting my time posting about them as well. Phil
This is a new interpretation on me Scud. Piston movement is pretty much irrelevant as the pads are only a few thousands of an inch away from the disks. When you grab the brakes the actual movement of the pistons is very small. Once the pads contact the disk it's about applied pressure over area. My understanding of the original reason for differential piston size was to provide even pad wear and pad performance. The leading end of the pad experiences quite different thermal and therefore frictional conditions to the trailing end hence the differential piston size and pressure applied to the shared pad to compensate. This later calliper design uses 4 separate pads to, I suspect mitigate the original issue. It also has a central bridge over the pad slot to increase rigidity. These were the last generation of road calliper from Brembo before the Radial style calliper took over. I've never seen a Brembo design in 50 years that was a step backwards. Anyway like the majority of upgrades they usually don't stand the scrutiny of "what's absolutely necessary". I'm channelling the "American" in me with my Guzzi in that a lot of it's about "individuality" and "nobody else having one like it" However I'm also mindful of maintaining the bikes place in "its time" so upgrades such as later USD forks with radial callipers and radial master cylinders etc are not really up for consideration. Phil
They are different callipers docc. Brembo p4 34/34 with 4 individual pads as opposed to the original( pictured) 30/34 callipers with 2 pads. Phil
Yes the brake lines need to be replaces as the orientation of the Banjo is 90 deg different. These as 34/34 pistons as opposed to the original 30/34 so about a 10% difference. The original M/C should be OK. I will also see if these will work. https://www.aliexpress.com/item/4000378552965.html phil
I thought it was obvious Phil
Try telling the spell check on this site. Both are acceptable apparently, US V British differences. Phil
In progress. Phil
No docc but the later engines that run the plug lead over the valve cover might be a tad short if you use the early cover on the later engine and then run the plug lead around the back of the cylinder like the v11 Sport. EDIT..... sorry docc I didn't see the "gasket" in your earlier post. Thought you were talking about the valve covers. All square fin 2 valve engine rocker cover gaskets are interchangeable as far as I know. Phil
Because the plug leads for the later valve covers come over the top of the valve cover under the black plastic cover/crash pad and the original ones come around the back of the head. Phil
Can't see why they wouldn't docc. You might need to lengthen the plug leads though. Phil
I can guarantee you they fit docc. Same as 1100 Griso valve covers fit a V11. Phil
The crimped stainless steel gasket with a pressure sensitive sealant coating is a leap forward in gasket sealing over the old style composite and it's variations in different materials. The "crimp" in the metal base acts like a spring to adapt to changes in the joint due to thermal expansion etc or in the case of an MLS head gasket variations in temps between say the bore bridge area and the outer circumference of the cylinder. They also adapt to the rigors of high stress engines that can sometimes suffer from "head lift" and still maintain a seal. The pressure sensitive coating function is self evident. Brilliant things and cheap to buy. A must fit to the BB front engine cover anytime you have it off.
It's ancient technology. These. https://www.valpolini.com/index.php/home-en/prodotto?&fID=1574 Phil
Back in the 80's docc I had a new GPZ900 Kawasaki. They used to run quite high engine temps, a little higher than what most people were used to. So the complaints came as did the traffic to the dealership mechanics. Kawasaki's response? They fitted a resistor to the gauge to bring the reading down a little. Complaints ceased. Phil
These are a sub optimal solution. The Gold standard are Valpolini metal core gaskets with integral sealer coating. Same style and principle as the late model BB front timing cover gaskets and every engine cover gaskets Ducati have used for the last 25 years. Bullet proof sealing and zero chance of squeeze failure. Phil
For general information to anyone reading this thread in the future this methodology is flawed and it's best to stick with the historically tried and tested oil pressure observations for troubleshooting. This LOP light on after the kill switch timing thing has way too many variables to be a troubleshooting tool. If the engine runs fine and has no unusual noises and the LOP stays off at idle in hot weather in traffic and the used oil has no concerning contamination then all is fine with the oil system. What do you do on a weekend trip or touring trip when you use this observation technique? Stop for fuel and for one of a dozen different reasons the LOP light illuminates without or with a reduced delay compared to usual observations? Pull up and start troubleshooting and have the engine apart? What would be an acceptable amount of delay? 1 second? 3 seconds? Sometimes people can go looking for issues and worries. Fitting an OPG every 30 or 40,000klms for an oil system evaluation would be reasonable but only for the oil pressure obsessed. It's the same as permanently fitted LOP gauges, a waste of time and added failure points and complexity. All you get is additional things to worry about and questions to observations you don't have the knowledge to understand. There's a good reason motorcycles in particular don't come standard with LOP gauges and only a light. It's just too cruel for the OCD riders out there. Even modern cars with LOP gauges dont use actual direct reading gauges anymore they use an indication derived and calculated from the ecu for the display and rely on a LOP switch and light for indication and warnings. If they used direct reading gauges that indicated the actual oil pressure the dealerships would be overflowing with owners with oil pressure issues. It's not just about the engineering but human psychology as well. Phil
OK, but the question is why would you do that? The time it takes to illuminate is of no empirical value. I don't know of anyone that monitors such things so answers might be hard to come by. Phil
Your description doesn't make sense for the 02 v11. You turn the ignition switch OFF and after a 3-6 second delay the LOP light comes ON? It comes on with the ignition switch OFF? Here's how it works or is supposed to work. Turn ignition ON, LOP light ON. Start engine, LOP light goes OFF. Mine goes OFF during cranking. Turn ignition OFF,LOP light goes off with engine shutdown along with everything else. Any variation on that and you have an issue. Phil
Do you have the injector plugs correctly installed? they take quite a lot of "push" sometimes to overcome the locking clip on the connector. The pump, injectors and coils feed from then same relay so if one works they all should. Is the ECU correctly grounded? Phil
I binned the EV today
Lucky Phil replied to LowRyter's topic in Special place for banter and conversation
It's the equivalent of someone hurting themselves and immediately getting up running away at full speed. The 'flight" response. If I can still run/ride away from the location of the trauma then I must be relatively ok and I leave behind the "danger zone" or trauma location. I'm surprised the Cops allowed him to ride away. Phil -
Bummer but glad your mostly ok. Sounds like that foreign object wrapped around the front wheel was the culprit. Phil -
https://www.v11lemans.com/forums/index.php?/topic/17183-how-to-color-match-the-guzzi-lime-green/&tab=comments#comment-183698
