The governing factor in the case of a 90 degree V twin with regards to the exhaust scavenging is the point of cross section dia of the secondary pipe. So the first major cross sectional change is what generates the negative pressure pulse. In multi cylinder engines they combine this with the collector shape so the designated cylinders "talk to each other" as well. This is a Ducati Corse 888 "spaghetti" exhaust. The small short link pipes between the front and rear cylinders primary role is to create the large cross sectional change in pipe dia to generate the negative pressure wave to help with cylinder evacuation and subsequent filling. It's not there specifically for splitting the exhaust flow to both mufflers. Thats a secondary benefit. There are two link pipes and the second one is obscured but you can see it's retaining spring underneath. Phil
Think the top flow injectors are hard to remove try the Daytona/Centauro side flow injectors. Nightmare. Phil
My advice is don't try to separate the throttle bodies unless you have no other choice. Phil
Exactly, this is the way I do it. If you think about the geometry of it it makes sense that the angles and dimensions are what they need to be for the bodies in their mounted position not an inch further away when released from the rubber connectors. Remove the aluminium manifolds and connect them and the rubber sections to the throttle bodies and then move the manifolds back onto the head. Easy. I can't believe people muscle the whole assembly around by the other method. Phil
Yes John it's actually an MGS-01 shaft which is just a std jackshaft cut down and machined to accept a 6005 roller bearing for the front case instead of the plain bearing running in the case. I seriously might just remove the rear jackshaft bearing and run the std front plain bearing in the case. The roller is good for friction but you lose the internal oil feed to the heads. I can see no reason at all Guzzi didn't do this on production engines. The rear jackshaft bearing on an 8 valver does no support that I can see and just adds friction and another oil loss path. Phil
Yes I have a set of Joes new gear and his updated pump. I thought I posted an image here a little while back. I had him make my cam gear 4mm narrower the same width as the V11 gears because a steel gear can have a higher tooth loading than the cheesy aluminium one and we save weight. His latest pump has reverted back to a plain bronze bush for the drive gear to minimise oil loss through the original oem style needle bearing. The new gears also have a different surface finish due to the previous providers of this going out of business I believe. So they are now a silver low friction finish. EDIT.. Oil pumps L to R Joes new pump, std, some aftermarket version which was almost impossible to remove due to the alignment pins being oversize. New gears and MGS-01 jackshaft
EV/battery powered transportation trends
Lucky Phil replied to fotoguzzi's topic in Special place for banter and conversation
The Governments of the time were sold bullshit by the oil companies with regards to diesel powered cars because they make more money per barrel of oil from the far less refined diesel and the yield per barrel is higher so more profit. The rubbish they pedalled to European governments was better fuel economy (true) and "don't worry about the pollution we have future tech in the pipeline that will solve all that" (rubbish) The car manufacturers were on board because they could charge more for a given car because it used less fuel and the Bureaucrats bought it hook line and sinker. Does all this start sounding a bit familiar? Governments being sold bullshit by people with their own agendas. The diesel issue was a simple one, money and profits, easy to understand. The environmentalist agenda is a little more complex and is routed in politics itself and power. Don't kid yourselves into thinking it's because greater powers are trying to save your children's future. Phil -
Really? What sort of mechanical noise? Clatter or whine? I have 2 sets of joes gears in engines and a 3rd set on the bench to go into another engine. Phil
Up to probably the mid 80's when the KawasakiGPZ900 and the First GSXR750 Suzuki were released the Japanese were almost 100% focused on the US market and what was the US market focused on? Straight line acceleration. I remember those days where people would ditch their near new bike for a model that came out that was .1 seconds faster down the quarter and all every Japanese big bike owner could talk about was 1/4 mile times. Us European owners were like leapers there for a decade and a half or so, lol. Thankfully time have changed and now I'm surrounded by 25 year old wannabees in full racing leathers logoed up identical to their racing hero's on $80,000 sports bikes with one inch chicken strips on the tyres telling you how great the handling is. Oh hang on, can I go back to the mid 80's please. Phil
Surprise surprise the electricity to charge them is almost free and I'm guessing motoring in Norway isn't a popular pastime. Phil -
People need to forget the outliers like Norway who produce 88% of their electricity by Hydro and has a population of 5.5 million people and the land area of Montana. It also has extreme daylight hour fluctuation depending on the seasons. It's a unique country with unique conditions and location in regards to topics such as this. Like making arguments about power source generation with a location on top of thermal springs and using them as aspirational or solar generation in Saudi Arabia. Just distorts the real argument. -
ANSWERED Voltage regulator broken? Confirmed.
Lucky Phil replied to Tinus89's topic in Technical Topics
Problem with the direct to the battery style is the reg is always live and has a parasitic draw on the battery while parked. Combined with the ecu parasitic draw you def need to use a battery tender if parked for any length of time. Phil -
Email Agositins and ask them about the header dia they are good to deal with. My bike uses std V11 Sport headers, a Stucchi crossover and Agostini mufflers and I have no tapered pipes at the crossover. May just be they wanted larger dia at the crossover and secondary pipes. Phil
An unhappy Tesla owner and a comment on whatever generation she belongs to. Funny and sad at the same time. I didn't go looking for this honestly. It was posted on a car forum in the Funny and laughs section. -
Reminds me of the argument Harley Sportster or Indian FTR owners use for their 12 litre petrol tanks Chuck. Like a car a motorcycle ride where you are planning fuel stops is a PITA and not fun. I regularly do 900klm plus trips and the last thing I want to be even considering is where the next fuel stop is and when I do get there I'm fuelled up and out of the place asap. I fuel the car and the wife buys the coffees and pays the bill and we're gone. If we want a break it will be at a Cafe of our choice on route and not some horrid fuel stop fast food catastrophe complete with screaming kids and frustrated frazzled parents. Don't want to be there any longer than absolutely necessary. BTW it's the same everywhere in the world, Italy road stops are just as horrible. Truth is I'm not opposed to EV's per sei I'm opposed to having them forced upon me whether I like it or not under spurious claims about saving the planet and how they really are so practical. Phil -
Not sure if the SD clutch comes with the same friction disk. Ask SD if it has the MIBA friction disk and if it's the latest steel flywheel version. Make sure they do a physical check on the flywheel material, you know spare parts people. They know part numbers not actual things. Phil
- 30 replies
This is what rational people are are up against. This statement is total rubbish. Currently Solid State batteries have at best an energy density of 500-800 WH/KG while gasoline is 12,700 WH/KG and an efficient ICE engine is between 30-40 % efficiency. Same as Range claims that when tested in the real world fall not just a bit short but orders of magnitude short. Charging time? well headline charge times are to 80% battery capacity and that last bit they always leave out. It's in the fine print. It's the last 20% that takes the time and is what you need on a long trip. Phil -
A mate of mine bought one about 5 years ago in mint condition from Tassie. He also has a Rickman Kawasaki he's owned from new. Why he'd want a Mk111 Kawasaki I'll never know. Why anyone would want one I'll never know. I also know someone that raced one at Bathurst in a proddy race back in mid 70"s. There are some teenage memories I don't feel the need to re visit or repeat. Phil
2023 MkV Supra 6 spd Manual. 3 Litre Turbo inline BMW 6. 2023 CX5 GT SP 2.5 turbo AWD 2023 Kia Stonic GT line. I litre turbo 7 speed DCT. All Red. Phil
Just buy a 5 speed no flywheel pickup RAM kit from MGcycles in the states They are lightweight steel flywheel these days. The genuine RAM alloy units had no failure issues and I have one fitted to my bike. SD is too expensive. You will need to use your original gearbox input drive is all and check the pushrod details in the instructions on the MG website. Forget about converting to a dual plate clutch assy. Once you have ridden a bike with a single plater you'd never want to go back to a dual plate sidecar flywheel assembly. https://www.mgcycle.com/index.php?main_page=product_info&cPath=193&products_id=1698 Phil
- 30 replies
- 1
The truth is LiPo batteries are not evolving particularly fast at all from an energy storage perspective so anyone that thinks in 10 years time electric cars will be much more efficient is on the wrong path. LiPo batteries were invented back in the 70's and the tech was fairly dormant until Sony from memory picked it up in the early to mid 90's so they have had over 30 years of intensive development already. Any further gains are going to be incrementally small, there are no tech leaps on the horizon. It's mostly about reducing manufacturing costs now and reducing the faulty count. Naturally all the environmentally concerned people that buy them don't have any idea or solutions on how to dispose of or re manufacture them, same as old solar panels which go into land fill along with wind turbine blades which have a hard life as well. -
I actually had a Gpack LH Torana with a 327 Chev engine Saginaw 4 speed and a Ford 9" diff in it Mick. The car was bought as a stolen recovery and the 6 cylinder and M21 and std diff removed and the Chev engine etc installed. Full engineers certificate etc. The guy that built it was a work colleague that was a single guy of around 40 back then and did amateur drag racing for a hobby in a hotted up LJ Torana. He also drove an XU-1 to work as well as having a 4 speed split window maroon 427 Corvette in immaculate nick. I had a ride in the Corvette once. He also had a water brake dyno in his garage that was connected to his swimming pool that he never used. An old style car nut bachelor that inherited his moms house and put it to good use, lol. Anyway the Chev Gpack looked appalling in it's orange paint and blue side stripes/lettering but naturally before he sold it to me he did a street meeting in it. Can't remember the times he did in it but it was faster than an SLR5000 at the time. Phil
