Ghezzi-Brian ECU for the V11 - anyone knows "Centraline Rapid-Bike"?
Lucky Phil replied to p6x's topic in Technical Topics
You seem to be all over it then so you won't have any issues. Ciao -
Some current automotive systems do have octane sensing devices for the ecu. You can even buy stand alone octane measuring devices that indicate via a display in the car what the current octane rating is. Ciao -
The V11 ecu does not have these capabilities. No knock sensor and no ability to adjust for different fuels. Thats a few generations on from the V11 15M ecu. Ciao -
Tunerpro is used to edit .bin files or "the maps" if you like not to download and upload the .bin file. That is done by the Guzzidiag reader and writer programs. So Guzzidiag allows you to view your bikes injection system in real time while it's running and see all the Parameters etc like throttle position and various environmental sensor outputs. It also allows you to adjust the CO setting and on some bikes reset the TPS reference point and turn the LAMBDA on or off. The reader and writer programs allow you to download the .bin file (or maps) from your ecu and save them on your computer and then the Tunerpro programme allows you view the .bin file in human understandable form and to edit the .bin files to create whatever changes to the file/maps you want and save them to your computer and then use the Guzzidiag writer programme to upload the modified map into your bikes ecu. The .bin file is a computer geek file in Hex and computer language, Tunerpro turns that into something that is layman understandable and simple to edit. What map do you load? Any map someone emails you or you find on this forum via a .bin file. Simply download the file onto your computer open the reader select the map and with your laptop connected to the bikes ecu simply write the new map. Or take your original map open it in tunerpro and make changes or edit the maps yourself. Save the map on your computer and then load it into your bikes ecu with the writer programme. It's identical to tuning a carburettor just via a laptop. So you think your bike is running badly at a certain point, look at the fuel map at that point ( so throttle angle and rpm) and lets say richen it up 3% in that area. Save the new map file and name it on your laptop and use the writer to load it to the ecu. Take the bike for a ride and see if it's an improvement. Yes then add another 2% and try again. No lean it off again. OR if it runs worse on the initial change then go back 6% from your new map ( 3% leaner than stock map) and see how that goes. Pretty simple and you can't hurt anything with small changes like 3-5%. Then the same for ignition if you like and start enrichment the list goes on. If you have a few maps to look at you can look at them on tunerpro and see where the differences are between the maps and if your bike is not running as well as it should and you have another map thats different in that area then edit the map thats in your bike and use those values from the other map and see what the result is. This is how bikes were tuned when they had carbs. making changes via jets, throttle slides etc then riding them and seeing what the result is. For most people this will be good enough. A bike that starts well, warms up well, idles well, responds to the throttle well, doesn't use too much fuel and is nice to ride. If you want something closer to perfection then you can hire some dyno time and an operator or get into the world of data logging engine lambda. Ciao -
back from powder coater...what have I done?
Lucky Phil replied to Cold Desert Rat's topic in 24/7 V11
God I'm even less confident now. Next it'll be ditching the airbox. Ciao -
Take your pick. Anything from pauldaytona will be first class as he's one of the people behind it in the first place. How much is an old giveaway winows 8 laptop? probably a Giveaway, ie nothing. People use Guzzidiag on apple products. Also look at Tunerpro. Tunerpro is what you use to modify the .bin file you download with the Guzzidiag "reader". It's seriously NOT rocket surgery:) Believe me if I can get my head around it anyone can. https://www.google.com/search?q=youtube+Guzzidiag&rlz=1C1CHBD_en-GBAU863AU863&oq=youtube+Guzzidiag&aqs=chrome..69i57j0i546l2j69i64.7419j0j7&sourceid=chrome&ie=UTF-8 Ciao -
My suggestion to you is to spend some time learning about the system on the V11 and Guzzidiag, there's plenty of detailed information out there going back about 12 years since Guzzidiag was invented. You will then realise that this add on box is a waste of money because Guzzidiag in conjunction with Tunerpro will do everything it does without being an add on and for free. But as a start here's some information. You totally misunderstand how the 15M system works on the Guzzi. Basically it has base fuel and ignition maps ( as well as start enrichment and a few others) as all systems do and it adds trim values to the base maps dependent on atmospheric and operating conditions. So engine temp, Baro pressure, inlet air temp etc. It also takes commands from your right wrist via the TPS and the known engine rpm looks at what the base map is saying and all the environmental trims and injects the appropriate amount of fuel and applies the appropriate amount of ignition advance. As environmental conditions change such as Inlet air temp, engine temp, baro pressure so does the amount of fuel injected and the amount of ignition advance. It's all done in "real time". It's a very capable system and doesn't need any do dads and hang ons to do it job. It can be easily tuned via Guzzidiag and Tunerpro even for people with very basic computer skills like me. Ciao -
We will indeed. I'm not feeling too confident myself though. Ciao -
Triumph Speed RR versus Ducati Panigale V2?
Lucky Phil replied to p6x's topic in Special place for banter and conversation
You don't need to worry about this as the piston is at TDC when you do the clearances and the valve can only drop a few more mm than opening and it hits the piston. Ciao -
Yea I had to buy it specially on the "net" Ciao
As weegie mentioned an extra deep 32mm impact socket. The torque figures are in the Shop manual. Crank Nut 110-120nm, alternator nut 80nm, cam gear 150nm. If you look in my "how to" for this task you will get some hints on holding tools etc. https://www.abc.se/~rasmus/1100Sport-torque.html Ciao
Not saying the world is going to remain static with regards to motorcycles but I live with the electric scooter and public electric pushbike bullshit in my city. Electric pushbikes available to the public to rent and transit to wherever they want is a total failure with bikes dumped anywhere and the helmets they come with littering the streets. So many dickheads here it's pointless. Personally I believe the future will be a mix of ICE and EV's. Porsche is already building a synthetic fuel manufacturing facility as we speak. Currently there is a thread on wild Guzzi asking what you'd ride if you couldn't ride a Guzzi and nobody has mentioned wanting an EV, even the EV fanboys that jumped on the woke train 6 months ago. Personally I'm a recalcitrant and will not succeed to the big brother mentality which I already do. Ciao
I would just use a blind bearing puller and failing that disassemble the bearing until all thats left is the outer race and then collapse that. I'm remembering the outer race on these is a formed sheet style and not a machined cage, is that right? If it's a machined outer ring I'd do the same then if I couldn't grab it with the puller I'd run a light bead of weld around the inside of the outer race and it will fall out. Ciao
Interesting on both counts. Puig is still blaming Michelin and all the teams want the front ride height adjuster banned except for Ducati of course. This is pretty typical from teams that don't innovate much because they are caught behind the curve and are lacking a little in speed until they catch up. MotoGP is getting too much like F1 for my liking. Ciao
I think it's the common std 1x1 weave. I'll let you know in a few days time. Ciao
Stock V11 Sport clip ons and headlight brackets vs Magni Fairing
Lucky Phil replied to MadMike's topic in Technical Topics
Headlight brackets are expensive even used. You can still get the top triple and brackets used but I'd estimate the cost the be around $400usd these days. Ciao -
Good luck with the Covid Pete. Ciao
Loctite on the oil pump nut only, red. Ciao
The TPS output is non linier on the V11. The linier version of the same TPS has fixed mounting screw ferrules without slots. Ciao
Someone has spent some money on that bike. The carbon rocker covers are silly idea as the carbon resin isn't heat tolerant enough for the purpose. Note on the high res image of the l/h cylinder head over the exhaust port the carbon cover is starting to take on a Copper colour, that's the resin becoming heat affected. I had carbon heat shields on my race Ducati's headers and currently have carbon muffler end caps on my Titanium Akra system on the 1198. They eventually go brittle and fail. On race bike exhausts it's weight over practicality but road bike rocker covers, no. Add to that the difficulty in keeping aluminium ones sealed and it's a classic style over function scenario. Ciao
No docc their std airmail service hasn't been operating to here for probably a year due Covid. To the UK is still ok though and I think AU post to the states is still ok. Just no USPS from the states. Scud posted me a top triple clamp about 3 months ago via his work courier service on corporate rate and it was $75US if I recall. So around 100AU. Ciao
I had better pass esp considering there is still no USPS postage available and other methods are outrageously expensive. Ciao
I'd be interested in a seat cover but any I'd need to see some examples of the quality of their work. Any chance of some detailed images of the stuff they do? The side covers will need separate moulds for each side. Ciao
Well reading Joes email and what Peter mentioned it seemed to be the other way around. I'm not familiar with the round engines crankcases docc. BTW the "sludge" issue is another overblow thing as well. Just because areas of the engine hide a bit of oil that eventually ends up black is of no immediate concern. If you can wipe away the oil with your finger and see the crankcase metal this isn't sludge. Sludge is stuff you need to scrape off with mechanical means. It may eventually get there one day if you're slack with your oil changes but black stained oil isn't sludge. I've seen a bit of this sludge silliness on youtube lately by supposed experts. Ciao
