Lucky Phil
    268
  1. No to the later type 501452's. Those are the ones that are supposedly "canted". The earlier ones would be parallel same as the late one I have from Scud. Ciao
  2. No looked previously docc, nothing. Thats why I assumes Tenni but no other Tenni stuff in there. Btw Tenni's also had gold fork caps as well. Ciao
  3. Here docc. This was the link which doesn't work anymore. For V11 Corse-Le mans 03-04. http://sparts.aprilia.it/stampatav.asp?w=&ntav=Front wheel&tav=34&ye=-&cou=-&ve...
  4. I agree with the "short on detail" docc. The RE uses these as well but the ignition coils don't go through a relay so one of the biggest current drawers is isolated from the relays. Ciao
  5. Mines "nutted". They went from Nutted to screwed and back to Nutted again during the life of the bike and 25/20 axles to 30/25 and 40mm forks to 43mm forks both with 54mm uppers. What do you think T5 and T6 are docc? ciao
  6. Hey docc your opinion on this? https://www.jaycar.us/spdt-30a-horn-relay-12v/p/SY4046 https://www.jaycar.us/medias/sys_master/images/images/9590139322398/SY4046-dataSheetMain.pdf Ciao
  7. Thats what I'm thinking docc. The 2 upper clams I have, one a late model and the other my supposed "canted" one on my bike look identical dimensionally. Ciao
  8. Interesting docc. I'm used to Italian parts manuals but the Guzzi v11 manuals are extra confusing. I was trying to decipher front axle variations yesterday because from the first v11 to the final v11 there were at least 5 variations in forks and 3 different axles and spacers. In one manual the model applicability was listed as LM-S then another variant was NC-RC-T6 and the last RC-T5. I assume Nero Corse, Rosso Corse Le Mans and Sport and Tenni 5 and 6. I wasn't aware of a Tenni 5 or 6 and couldn't find any differences in Tenni models across time? It also means a Tenni has the same axle as a Ohlins equipped bike although it uses Marzocchi forks? The Tenni forks were also Ti coated which I didn't realise until looking at images. Ciao
  9. My original triple has 501452 (so later "supposed relaxed angle I assume) on it docc and I haven't measured it as it's on the bike. The triple Scud sent me is 501486 however it is the latest type with the clip ons mounted on top of the triple clamp and therefor it has bolt holes for the clipon lugs and a different relief cast into the face. Both are 40mm offset. My reading of the triple clamp theory and correct me if I'm wrong was that the earlier bikes had a particular type inherited from the 1100 Sport possibly? (@ 45mm offset) then pretty early they "relaxed" the angle and that was what they stuck with for all later iterations? That was the "theory" anyway from what I can deduce? If that's correct I'd expect to see the triple Scud sent me show that slightly canted angle between the stem bore and the fork bore which it doesn't have. I actually suspect that the triple clamp differences was that they simply used the 45mm offset 1100 Sport clamps on the earlier bikes then pretty quickly decided to reduce the offset to 40mm to increase the trail and give it some more stability. I've never thought that the 1/2 degree canting of the fork bores was a realistic situation but I'm open to be corrected. Re reading doccs link Greg Field says that the later bikes from Le mans onwards went back to the "non canted clamps" which is what Scud sent me. Looks like I need to pull my top triple and measure it as well. Bugger. Ciao
  10. Yes they are. Ciao
  11. Sorry Scud I meant to PM you but had to step away for a from the computer. Truly amazing speed for this to arrive from the US, thanks again, much appreciated. I'll get the package in the post first thing Monday and I have southern hemisphere spring and detent bearing supplies for anyone thats in need. Yes for my bike. I have some late 43mm forks for it with Andreani cartridges and I'll machine up a Titanium axle. Then a set of PVM wheels and a machined rear bevel box like this and the MGS-01. That's the plan. Ciao
  12. After years of discussion about the supposed change in fork angles via the triple clamps for later V11 Sports (post early 99 models) I took the opportunity to measure the top triple Scudd sent to me and I received today. If the fork angle had been changed by machining the clamps there's no evidence of it that I can see. On the granite surface plate the upper clamp fork bores are perpendicular to the stem bore so there's not angle change there. Another V11 myth debunked? Ciao
  13. I used to get around in one in my late teens, a Mk3A. This one broke on a very leasurely 2nd to 3rd shift with no clunk or bang just zero drive when the clutch was eased out. Changing the axle was a nightmare as the splines had distorted when the axle sheared and I needed to remove the other side and drive out the broken piece with a long steel drift. Clutches were also hard to replace as the gearbox tunnel is enclosed so the engine and gearbox need to come out as a unit. Getting the front tailshaft joint to align with the gearbox output shaft going back in was also not a lot of fun. Ciao
  14. Except for the fragile rear axles. The only car I've known to break a rear axle shifting between gears with the clutch in. Ciao
  15. A "certified brake technician" I've never met one of those. I've met technicians that are certified in breaking things though. Ciao
  16. You can usually just carefully rotate the fitting to the angle you want. I've made tons of brake lines in the past and it's not an issue. Ciao
  17. I seem to recall Brembo stopped selling rebuild kits for everything some time ago due to litigation issues and not being able to control the competency of the workmanship. I know I couldn't get one for the front master on my 1198 and had to buy a complete new assy. I "think" it affects our bikes also.Somebody had issues getting a rear master kit from memory although the rear is available new and fairly inexpensive. Earlier seals are still around for stuff from the 80's and early 90's I think. Ciao
  18. Hey Scud seeing you have the wave front disk and you need to replace the rear why not use one of these. Galfer P/N DF005W https://www.vividracing.com/galfer-front-brake-disc-honda-silverwing-400-p-152495773.html Ciao
  19. The truth is docc a lot of this political correctness/prudishness we live with these days is an Anglo/Protestant rooted and propagated thing. So a US, Australian and British thing. The Europeans are a little more liberal with this sort of stuff. That wonderful Fiat add would generate public outrage from certain quarters here and not last on air. Ciao
  20. I'm just a conduit for info docc. The most unfunny person I know. Ciao
