Lucky Phil
    268
  1. Yes that's true John along with the exhaust gas velocity which was calculated to be the equivalent of 150 hp from memory. The Germans also used to calculate the exhaust velocity and convert to a HP number as well. Hives did a deal with the head or Rover to do the overhaul of the Meteor engine in exchange for the contract to build the whittle gas turbine which the war department in their wisdom had given Rover the contract to build. They did the deal over dinner at "the club" RR gave Rover the factory and overhaul business and RR got the jet engine to build and develop. Ciao
  2. Thicker paint doesn't necessarily mean better. I have another late tank here (same colour in fact) that's "taken a hit". The tank itself is fine but the paint has delaminated in large pieces back to the plastic. I had a Ducati 1098 tank ( on a bike that I'd owned from brand new) repainted about 10 years ago and when the painter went to sand it back he found it had been fully painted at least 3 times. He called me up and I had the tank stripped back to the plastic and then he painted it. Seems at the factory they were having some automated paint problems and they just kept feeding this tank back through until it's quality of finish was acceptable. So it had paint about 1mm thick which the painter wouldn't paint over. Ciao
  3. Yes you're right. I was thinking of the Meteor engine but that was sans supercharger. As for the Messerschmitts supercharger being better well as Greg points out in his excellent video (along with all his other stuff which is great) their "drive" was superior but holistically their supercharger system wasn't necessarily. Ciao
  4. I've got a brand new never had fuel in it identical one if anyone needs it. Not that cheap though. Ciao
  5. Well I'm not prosecuting a case that the new bikes deflectors are the last word in aerodynamic efficiency or functionality but I can see aerodynamic logic and function there although a better view up close would be nice. Time will tell I guess. BTW a header shaped like this doesn't need any mechanical support, it's a pretty basic header in the scheme of things really and not even very long. A std v11 header is considerably longer than this one and so less supported. Ciao
  6. Well I won't. I always let the "first adopters" "must have the latest and greatest" "everyone look at me and my new model bike" crowd finish off the R&D for the factory, iron out the production issues and let the dealership mechanics use their bikes as a learning tool first. I usually slide in after a couple of years when the design has had a bit of time to "mature" Ciao
  7. Umm, I think you're taking the opinion of a non technical, "social media commentator", millennial a little to seriously. As an aircraft engineer I figure I know something about aerodynamics and as opposed to a previous poster that proffered the idea it's a mechanical support of the header I actually think its an aerodynamic guide/redirector/deflector for hot air from the back of the header away from the foot peg area and riders feet. If you look closely it appears the deflectors forward edge is a little bit inside the line of the inside of the header pipe and captures the the trailing hot air from that area and redirects it back outboard across the lower part of the header pipe and heat shield and away from the riders foot and lower leg. Guzzi have a fairly proud history with regards to aerodynamics which guarantees nothing but it seems to be functional to me. Ciao
  8. What makes you think a fights going to start, but since you mentioned it. I know pete had in his mind the context of modified automotive/motorcycle engines here but because I'm a front bottom I'll remind him anyway that without the Supercharged/turbocharger spark ignition engine we'd all be speaking German now, lol. Mind you without it there probably wouldn't have been WW2 to start with. The supercharged spark engine was fitted to aircraft, tanks, patrol boats plus probably other stuff I can't recall. Ciao
  9. Yes unless they are designed for it from the drawing board. Both my cars are Turbos but they are designed for torque not top end like days gone by. It's quite amazing when you drive a new 3.8 litre V6 and it feels like you need to rev the tits off it compared to your 2.0 litre turbo SUV daily driver which thoroughly out grunts it. Ciao
  10. Well either way, I guess. There is the "nobody else's got one like this" factor which I don't get either personally. It's a big deal for some apparently and for those that it is rationality doesn't seem to come into it. Being "different" overrides everything else. Maybe I'm just weird. Ciao
  11. Your new fitting will need std 5/16 or 8mm injector hose. The female hose QD fitting is a std type I believe. Pretty sure I've seen them advertised around. Ciao
  12. My bike has a very low set toe piece on the shift lever, that's why the stand is an issue with the lever still fitted. YMMV. Ciao
  13. If you mean the air temp trim then it's influence isn't massive. When the sensors fail the ecu generally has a "default" or std setting so the engine will run pretty decent on a std day. May be harder to start and/or warm up but unless it's particularly hot or cold it should run fine. So a std V11 air temp trim only varies about 3% from 0 deg C to 40 deg C. The engine temp trim about 18% from O deg C to 90 deg C operating temp. Same for the baro sense. The original baro sensor in my bike had failed and I rode around for years no knowing because all my riding is at sea level. On a std V11 map you'd need to ride at an elevation of more than about 2500 feet before the baro trim would affect running to any appreciable degree. Ciao
  14. But why? I can understand people wanting to give expression to their mechanical/design skills but surely that needs to be tempered by some rationality. So you add weight and complexity to an already overweight combination and introduce extra heat and cooling issues to an engine that already suffers in that regard. The compromises made are pretty outrageous. I haven't even sat down and looked at it in real detail but the air filter mounted where it is and the acute bends in the pressure ducting makes me not bother continuing any further examination. Modifications need to have a little more to offer than the "look at me" factor in my view. Irrational engineering is a pointless exercise. Ciao
  15. Guzzidiag isn't designed to work with the MYecu as far as I know. Have you contacted Cliff Jeffries? I have a Myecu and it has it's own stand alone communications system. Ciao
  16. The ultrasonic cleaner. Pull the entire brakes assembly off including the hoses and master then run the callipers only in the cleaning rig. Ciao
  17. I've never found anything that will remove the yellowish oil stain from silver engine paint after long exposure. Ciao
  18. That's a question for the factory cause that's what they did and the answer is a simple one. It's more in their interest the bolts never come out unintentionally than it is to make any replacement/maintenance straight forward. Future maintenance years or miles down the track is of zero concern to the factory. As a matter of fact if components get damaged during future maintenance then they make money out of spares. Witness the Weber throttle bodies 5mm screws fitted with green Loctite for goodness sake. Weber have zero concern for anyone disassembling them in years to come but are quite interested that screws dont loosen any time in the near future which may bite them. Blue Loctite would be understandable but Green just says "we have zero regard for future maintenance" Ciao
  19. Lovely. You know docc for me the sound and "feel" of a vehicle are massively important and why if I'm forced into a situation where every vehicle I own has to be an EV I'll just find another hobby/interest. Don't mind an EV Daily Driver in the slightest as a conveyance to get me from A to B but I could never become an EV "enthusiast". Too much character missing. As an aside my car has FENG ( fake engine noise generator) which is fake exhaust sound through the audio system, totally pathetic and it doesn't really need it anyway. That's maybe the EV future, a fake " emotional" system. You'll be taking your car to the mechanic because it "doesn't feel good" and he'll reboot the "emotion" generator. God help us all. Ciao
  20. Sounds feasible. Something like this may work but why not buy an original Ohlins and do as I suggested. Take the guess work out of it. https://www.suspension.com/9.9149
  21. Sound more like an opportunity than a shame. Ciao
  22. Top is rebound bottom is compression. Guzzi manuals are riddled with mistakes some of which are translation related and some because they obviously get the girl in the office fresh out of he Literature degree to create them. "Hey, isa justa words and pictures for the anglo's" Ciao
  23. It's about the "look" docc. That's the real reason mine has one. Ciao
  24. Yep, but the important thing is to apply equal opposing force to the plastic fitting when you are pushing and pulling on the hose during the process. Ciao
