emry
    3
Everything posted by emry
  1. I drilled a small hole on the tapered end of the retaining pin so that a small R-clip could be used. Between that and the tension of the internal locking clip the pin it will not go anywhere. Thanks for your concern.
  2. I found that removing the pad tension spring, (the small spring with two pins attached that rides under the retaining pin,) solved almost all of the noise. The springs pins are tapered on my scura and were causing the pads to pinch the rotor at the base of the pad.
