Steve S
    14
Everything posted by Steve S
      • 3
      • Like
  1. The diameter of the forks at the yokes are all 54mm Stew
  2. All V11s have 54mm forks
  3. https://www.ebay.co.uk/itm/254927488092
  4. https://www.ebay.co.uk/itm/Moto-Guzzi-V11-Sachs-Shock/254911144797
  5. No problem, I’m not far away if you need any parts or help
  6. Remove the clip on tube from the fork clamp then the throttle tube will slide off the other end, best to get some bar ends to fit your renthals
  7. https://www.ebay.co.uk/itm/10x30x30mm-Engine-Mounting-Bush-Silent-Block-for-Mopeds-and-others/372978587957?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Found a cheap replacement bush for the reaction rod, just had to file off 1mm from the inner sleeve length
      • 3
      • Like
  8. Okay I’ll swap my washers around then
  9. Steve S
    Shock
    Could be Stu how much?
  10. Do you still have the reaction arm ?
  11. Steve S
    Shock
    Sorted now
  12. Tennis were made in 2002 as far as I know and all had the single plate clutch unless converted to twin plate, the failing flywheel isn't the only problem, the single plate will wear out and they are made of unobtainium
  13. That’s the one I bought yes but any 7” light will fit , make sure it’s a complete headlight with 8mm bolt holes, my Ballabio is the same setup as the cafe Sport
  14. Ventura every time for me
  15. I’m just 8 miles from streffords went to see the bike a few weeks ago and they said nothing about the tank bubbles, never seen one that bad, made an offer on the bike but they turned it down, if I bought it my plan was to have the decals removed and just paint it red, apart from the tank it’s a really nice bike
  16. Have you bought the Rosso from Worcester UK near me ?
  17. I did this as I had a spare mudguard so got rid of the number plate lamp, the LED lamp has one built in
  18. https://www.ebay.co.uk/itm/133573248578
  19. Easy swap with the stock lamp
  20. Mine is a one piece item, the Ballabio one I took off was two pieces
  21. You’re right it can only be for a Rosso Mandello the cost was £99 and from On yer Bike but think they only had the one
  22. Don’t know the maker I bought it from Alchemy parts in London mounts the same as stock but needed spacers on the m8 bolts
