The fuel circuit should go tank - pump - filter - both injectors - pressure relief valve - back to tank
On some models the pump and maybe the filter is inside the tank, on others it's bolted on under the tank.
The pressure relief valve on mine is a small unit about 1-1/2" diameter fitted to the return connection of the tank
on other bikes the relief valve somewhere in the hose between the injectors and tank.
The relief valve setting is 34 - 40 PSI
The pump circulates the fuel around as long as the engine is running
No, you can't just run one hose to each injector they can be connected Y fashion or with a hose that passes by one then the other.
Hi, thanks very much for that.That is pretty much what i expected as it is a similar principle to my Cali that has a fuel return pipe on the underside of the tank at the front and only one outlet from the tank.
I didn't buy the Le Mans new so just want to be certain that the fuel lines have previously been put back on the correct tank nozzle.
My Le Mans has an in tank fuel pump/filter assembly and two L shaped plastic outlets, one of which is White and marked IN and a Red one marked OUT. I can see from that that the Red outlet supplies the fuel but what i am trying to determine is which is DEFINITELY the correct pipe to go to each respective nozzle. The coupling on the injectors themselves appear identical with a Link/Balance pipe connecting them as well.
Does the RED OUTLET pipe go to the left hand throttle body or the right hand throttle body.
Cheers Darryl
