dbarb3
  • Location
    Coats NC
    2002 Lemans
dbarb3's Achievements
Guzzisti
Guzzisti (2/5)
74
  1. YES Fuse looked fine Problem solved and I am thankful for the help No other group like this one
  2. Thank you everyone After Gene talked me into using a test light I'm embarrassed to say 2 perfectly good looking fuses were the culprit
  3. I have a feeling gonna have to pull tank and start looking Really good charge none of the lights we discussed are working
  4. Charged battery for a few Battery 13.1 Fuses 6 12.2 Fues 7 12.3
  5. dont have a test light unfortunatly I will test battery and check voltage
  6. 6 11.6 7 11.8
  7. Well I can tell I dont ride much at night I am not very observant Tail light, tag light, city light, intrument lights are all out Good grief
  8. Will check other lights referenced
  9. 2002 external fuel pump it starts up when key is turned on
  10. Switch key on main headlight comes on
  11. Front 7 have 12 V last fuse (rear) has none I will check my headlight
  12. Headlights dimmer horn work brake light works How do I check the ignition swith ? Come in from under it? Talk to me like a 3rd grader on testing the voltage I have a multimeter but thats about it.
  13. Well not surpised new flasher did not fix it Also noticed my tail light isnt lit but the brake light comes on when applied
  14. Found it Round metal one says Wagner 552 12 V Seems Auto Parts has these Gonna replace and see whats up
  15. Thank you gentlemen back to the garage I go. Appreciate the help.
