I've noticed that the 'paint' on my 2000 V11 Sport pork chops is actually a plastic coat which is probably why it's not so durable. And yes, it's sunbleached to a girly pink, both sides, which makes it look like it's by design. I'm not too concerned about the match to the rest of the red bits, 'cos you can't really see much red apart from the chops. So the frame at the front doesn't match the chops, but that pink has to go...
Removing pork chops? If youre going to the trouble to remove them you might as well hoik the wheel, shaft and swingarm off and do a proper job (on all of them). After all it'll cost more to treat (blast Paint, powder coat, anodise) the chops one at a time. I was worried that removing them would cause a critical collapse of the bike but it seems the engine holds the rest of it together. When you support the bike in the proper place - i.e. the lower rear engine mounting stud, and of course, remove the wheel, shaft and swingarm, the whole shooting match doesn't in fact collapse when you take off the chops.
This is where I'm up to now. I've degreased and scrubbed them down: so will spray paint stick to the plastic coating or will it crinkle up and drop off? I'll let you know. It's winter and I've got a month or so to experiment.
BTW, to support the bike, well, I'm stingey/broke so bought some cheepo ratchet axlestands from the local auto store and put rubber mats on the cups to protect the frame paint.
Wife understandably wouldn't help support a 500lb bike while jacking it up so... using a trolley jack under the sump with a piece of ply to protect it, lifted the bike up gradually on the side away from the kickstand and ratcheted the opposite axlestand up one notch into position and lowered that side. And then changed sides. Takes time but perfectly safe as long as you crank it up swapping sides, notch by notch. Lower it by the reverse process - don't hurry it up or down because it will topple.
However I will shell out the hundred quid for the proper stand one day, if it gives me an easier life.
