Hansson
    2
Everything posted by Hansson
  1. Hi Bob Maybe this thread can give you tips on possible cause of the noise (tapping) in your bike. I think your bike sounds the same as my did. The solution to my problem can be read on page three in the thread. Good luck! // Jörgen
  2. Hansson
    Hansson
  3. Hansson
    V11 Misano
  4. I highly recommend the "stahlbus" bleeder valve. Works absolutely amazing! High quality. If you use these valves together with stahlbus "auxilary vacuum filling and bleeding device", bleeding will go very easily. Without spilling and messing up. On my bike: Front - M8x1,25x16mm Rear - M10x1,0x16mm https://drive.google.com/open?id=0B1cTu58Dx28vX1owTVNnMU1ucWs Take a look at their website! http://www.stahlbus.com/products/en/bleeding-system/index.php https://www.stahlbus.de/lng/en/bleeding-system/bleeder-valve/conical-sealing-standardtype/ http://www.stahlbus.com/info/en/products/product-overview Cheers
  5. Thanks guys for a positive respons Here's a simple snapshot for you Scud, taken two days ago. Chuck, you have to wait until it gets warmer outside..
  6. I've now managed to silence the clattering noise! The reason was as I suspected.. Too big backlash at the center of the (new!) friction plates. I decided to order new plates made by "Newfren", in the hope that they would be tight in the splines, but not even these were as tight as the old "AP". Now there are new clutch facing, taken from the new "Newfren" plates, mounted on the old AP clutch plates. The Newfren plates are 8,3 millimeters thick so I've let grind the plates to 8,0 millimeters. Yesterday I started the motorcycle for the first time after working on it, and found to my great delight the silence !! Today I did the first test trip and everything sounds and works perfect! Welcome, this year's season! It's time for many amazing miles on the road
  7. I'm not so sure about this anymore.. I had a conversation with the gearbox guru Rolf Halvorsen, and he says that the movements and sounds of the gearbox is normal. In the search for the cause of the noise, I found another backlash. It's in the splines of the clutch friction plate. And there is more backlash in the newer replaced plates than in the old original plates, which have been running around 30,000 kilometers. It seems that the new plates are not as precisely produced, with accurate tolerance, as the original AP plates. Take a look at yet another video (Full Screen). Perhaps it's difficult to see how much difference the backlash between the plates is, but I see it as substantial. https://drive.google.com/open?id=0B1cTu58Dx28vbmlYN1QyVlJUSjA Thanks Lucky Phil, for your positive response. Just what I want to hear.. You confirm in a good way my own thoughts about aluminum flywheels for Guzzis (as thoughts of other manufacturers clutch baskets, and the toothed surface). Pete Roper has valuable references that should puncture discussions about the unsuitability of using aftermarket aluminum flywheels
  8. If you are referring to this footgoose.. The TB balance, AFR balance, valve clearance and idle speed is super tuned. Recently run in bench. The compression is perfect and in balance. Can't you see Pete Ropers explanation "Any 'Knock' will most likely be the primaries in the gearbox flogging to and fro as the input shaft accelerates and decelerates with the crank." ?
  9. Update. I think I've found the cause, from where the noise comes. There is backlash between the gears of first gear. There is also a small backlash between the gears of the second gear. https://drive.google.com/open?id=0B1cTu58Dx28vTmFlY2lkVEl0aFE This, I think, may be due to worn gear and/or worn needle bearings. There is no visible wear on the gears, but tolerance is perhaps small. I suppose it's difficult to measure the wear on the gears. I don't think the gears should be worn after just 34000 kilometers (21250 miles). The gearbox oil has been changed regularly every year. If I want to replace gears and needle bearings, it will be costly. Around 1200 euros. If I'm right, you can't buy gear for the first gear on the input shaft itself, so you have to buy a complete primary gear shaft assembly. This shaft will cost 680 euros. But I might take a chance on, only replace needle bearings. The flywheel, I will probably replace with a beautiful Ergal aluminum flywheel. Price about 500 euros. Of course I will also replace the clutch gear, although it is not particularly worn. I must admit that I'm little about to lose hope of this bike/make. Bad quality of parts and/or poor construction? Having to dismantle half the bike just to get access to the clutch or gear box is not fun... Don't try to come up with "there's no need to do that often." But yes, I also love the bike !! Ciao
  10. I suppose it's the T-shaped part with Guzzi Code GU 02766300 you're talking about? You can buy it at Stein-Dinse for € 17.18. http://www.stein-dinse.biz/Complete-partlist/Unsorted/Indicator-light-box-Cal-EV::2463.html
  11. I replaced the output shaft seal on my Ballabio -04 preventively when I did work on the gearbox. There was no leakage in the stock seal at 30000 kilometers. Make sure you get a seal with dust lip! HMB Germany, sell the right seal. It's not a directional seal. And I think it's a Viton seal. http://hmb-guzzi.de/Seal-Ring-gearbox-output-shaft-V11 Cheers
  12. Yes, it is exactly as you say Scud. I also hate those situations!! I did the work to replace the clutch at the start of the season and made the decision to ride the bike. I actually rode to the end of the season. The knocking noise has not changed over time, and yes it started after the clutch job. I also replaced the springs with new ones at the clutch replacement. I'm pretty sure that the springs are correctly fitted and that everything is properly tightened. I have done the "put your ear to a dowel trick" without success to locate the noise. The noise goes through gear one to six, and in neutral. There is one point (in addition to the clutch is pulled in) when the noise is silenced, and that's when the bike is driving. Or when the bike is lifted on the paddock stand, engine run in gear and I brakes lightly. I think that exclude faulty throwout bearing. I told about the worn flywheel, and here is a pic of it. There was no noise before I replaced the clutch even though the flywheel was worn, but maybe the changed position of the intermediate plate and the clutch pressure plate due to new thicker friction plates has something to do with the noise problem? .
  13. After I changed the friction plates and the steel intermediate plate and sealed the leaking gearbox, there are a tapping sound somewhere around the gearbox and clutch. I can't locate the noise. It's possible to silence the noise, if you quickly engage the clutch. But after a while occur the tapping sound again. The splines on flywheel is a bit worn. Could that be the reason? Maybe the intermediate plate and the clutch pressure plate strikes the flywheel in it's worn splines and make the noise? The clutch gear is in good condition. Or is the sound coming from the gearbox? Please tell me if you have experience of that sound, or an idea to the cause. Open the link and listen! (You hear when I engage the clutch) https://drive.google.com/open?id=0B1cTu58Dx28vVFIyS0hkejdqYlU Ciao Jörgen
  14. Some tips.. 1: Don't lose the small washer that will sit at the end of the odometer transmission shaft. The arrow indicates where it should be, but you can't see it because it will probably remain in the gearbox housing. And don't forget to reassemble it! 2: Try to get the same (or similar) rotary shaft seals that sits originally fitted to the main shaft and the transmission shaft. I recommend (Corteco) Viton rotary shaft seals with a dust lip. Viton seals withstands high temperatures and will hopefully last longer. 3: When mounting the rotary shaft seal for the main shaft, be careful not to press it too deep, because then maybe it doesn't seal against the shaft. Note how the old it sits before you remove it! In my opinion, ThreeBond 1215 is the best sealant for works like this.
  15. Hi Anders I suggest you contact Tom Stålebrant at Italia Bike Center, in Arboga. He is capable of doing miracles with the power curve on a Guzzi, by remapping the ECU and correct the AFR. So you don't have to use an Power Commander. Thus, less equipment that may @#!#$# up . Of course, you need to run the bike on their Dyno during remap.
  16. Could this post be helpful for your choice? www.v11lemans.com/forums/index.php?showtopic=11564#entry122911 "Posted 12 June 2007 - 06:08 AM My wife's out of town, and we had both the Stucchi and Mistral crossovers in stock, so I took the set home to try for the weekend and gather some impressions. Previously, I had had an FBF crossover on my bike and had liked the top-end rush it facitlitated. Then, because the FBF crackes, I switched back to the stock crossover for 6 monthes. First, I tried the Stucchi. It's a really nice piece. Heavy construction, much of it double-wall. The design is the same as that of the FBF I had mounted previously, but the Stucchi is built like a tank in comparison. The FBF lasted me about 2 months and then cracked along the weld. Despite the signifiacant fact that I am a seller of those things, FBF has yet to warranty it, though I have been trying since last fall/ Screw 'em; six months of trying is too much. About half of them I have sold have cracked, as well. Avoid FBF crossovers like the plague. Sound: The Stucchi sounded really deep and mellow, like the FBF. Performance: Like the FBF, it was a top-end crossover, not really adding much on my '04 until 6,000 rpm and up. It may have reduced the torque hole from 3,000-4,0000 rpm on my bike, but not by much. There's no way to use it with a centerstand without ballpeaning big divots in the crossover. This would not be easy in such a stoutly constructed piece. Overall impression was nice construction but not suited to my needs. Then, I tried the Mistral crossover. Like the Stucchi, it is built very stoutly. The stainless is thick, and the welds are nice. It has less "crossover' (shared piping) than the FBF or Stucchi. This might make a big differeence on the earlier bikes without a crossover in front of the engine. Who knows? On the '04 Billy Bob it fit nicely. Best of all, I only had to knock a little divet into the right leg of the centerstand to make it work with the centerstand. Then, it fit like the stock crossover, but what a difference in performance and sound compare d to the stock crossover. Soundwise, it snaaaaarrllss, by comparison. In fact, it's right on the cusp of being too loud when you really get on it. This crossover is all about low- to mid-repm throttle response. From 1,500 rpm to 3,000 rpm, it jets forward, by comprison. I f you ride in trafffic, this is the one you need. From 5,500 or maybe 5,000 rpm on, the Stucchi feel stronger; below that, the Mistral stomps it. By feel, thoroughly. I'm keeping the Mistral because it just suits my riding style better, plus, then I can keep my lovely centerstand." If you want to invest in a top-notch system, this is it: "DÄS-Auspuffanlage konisch D50x1" http://www.daes-mototec.de/index.php/shop.html I don't know if it's available in the US but you could order it from Germany.
  17. Do not give up Scud! Could this tip be something for you? Gawa Guzzi is a serious company. Further down the page is a kit for single-plate clutch (GG2193300 - V11 6 Gang €580). http://www.gawa-guzzi.de/antrieb.html
  18. AGM batteries have battery acid bound in a fiberglass mat between the lead plates, it does. that there is a slightly smaller amount of sulfuric acid and therefore these batteries often need slightly higher charging voltage to become fully charged. I'd chosen a smart charger for a AGM battery. As a suggestion, a CTEK XS 3600 charger. http://www.ctek.com/se/en/chargers/XS%203600 Or a CTEK Multi US 4.3, about $85 http://smartercharger.com/battery-chargers/ There are different compatible chargers to Aliant batteries, but the best choice is probably Aliants own charger, model CB1210. http://www.go-aliant.com/web/battery/index.php?option=com_content&view=article&id=259&Itemid=822&lang=it-IT In Europe I can get a CB1210 for €78 ($85) CTEK have a special charger for LIFEPO4 batteries, "CTEK LITHIUM US". Costs about $120.
  19. If you want to mount a modern battery in your bike, you can for example select an Aliant LIFEPO4 battery. Aliant recommend types YLP14 or X4 for the V11. The characteristics of these batteries is much better than the old batteries of AGM type. YLP14 weighs 0.76 kg (1.68 Lbs.) compared to, for example, Odyssey PC545 5.2 kg (11.46 Lbs). Significant lightening of the bike with Aliant battery! Aliant YLP14: CCA 245 Amp v.s ODYSSEY PC545: CCA 185 Amp. 100% charge in under 30 minutes with a Aliant CB1210 charger is not bad. YLP14: Lx114mm Wx69mm Hx90mm. And Aliant batteries have more good qualities.. There is a Spark 500, factory fitted, battery in my Ballabio -04 and it still works!! That battery I give the highest rating for function! But for next season I will, as a preventive measure, change to a Aliant battery http://www.go-aliant.com/web/battery/index.php?option=com_content&view=article&id=157&Itemid=760&lang=it-IT
  20. I had similar problems with my Ballabio -04. The clutch worked but didn't disengage completely. It worked so much that the fault wasn't noticeable when shifting gears while driving. It was trouble getting out of number one's gear when the bike was stationary with the engine running. It was right on the edge that it would drive (and make it a little sometime) whith engaged clutch, detached in gear, when stationary. When I search pull mode, it hack / grab a little. The bike had rolled around 16000 kilometers. I avoided the problem in a very simple manner by adjusting the clutch lever with the ring-nut to position 1. This position gives the clutch piston maximum stroke. I know that this wasn't a way to solve the cause of the problem but it meant I didn't have to disassemble the clutch. Now I have done it anyway because of leaking gearbox. The reason for the the problem may be due to several causes, but the most likely is worn splines (grooves) on the clutch gear or/and flywheel. I think you can read about it in this forum. Cheers
  21. Hansson
    V11 Misano
    Hi Craig! The bike is basically a Ballabio. I have had problems with heavy turbulence around the helmet with the Ballabio bikini fairing. It has been created loudly, and very irritating noise. So loud that I didn't hear the sound of the engine at speeds over 70 km/h (44 mph). Catastrophe! Of course, I have tried different helmets, but without success. I have now solved the problem by installing a fairing, designed by Pierre Terblance, for the 900 SS. I almost think Pierre Terblance designed this fairing just for the V11, considering the design and fit. The lines of the fairing match other details on the bike extremely well. The fairing works super on this bike. Turbulence is gone and I can now hear the engine at speeds over 150 km/h (94 mph). I have of course also changed to clip ons. Now I have a happy ride! Cheers
  22. Hansson
    V11 Misano
    From the album: V11 Misano
  23. Hansson
    V11 Misano
