Bugtarget
Everything posted by Bugtarget
Sweater in great used condition. Made in Italy. 80% wool, 20% poly. European XL/US Large. Cool old school embroidered Guzzi logos on the shoulders, front and a large oval Moto Guzzi on the back. I've got more pictures. $50 with free shipping to lower 48. From Olympia WA Please use PM with any inquiries.
Read both once and done. No rips, tears, dog ears or markings. Both in like new condition. Chase the winter blues away! No Thru Road Confessions Of A Traveling Man by Clement Salvadori Finding Cannon Ball's Trail by Don Emde Both books $40 including shipping to lower 48 From Olympia WA
Yup, got the $. Thanks, I'll ship it today.
Yea, my bad. Thanks for doing that!
Hey gstallons! I've PM'd you, replied to you PM to me and sent you two emails using- g stallons . . . ack hotmail >dot
Everything for $95 plus shipping to USA. Spares for 2002 LeMans. PayPal okay. From Olympia, WA 2 pair valve cover gaskets 2 sump gaskets 1 oil filter 2 shift lever return springs 1 throttle cable 1 Brembo 11mm rear master cylinder rebuild kit 1 Brembo rear caliper rebuild kit (for P32B) 2 exhaust gaskets 2 NGK spark plug caps 1 set rear brake pads 2 fork seal washers 2 transmission/bevel drive plug washers 3 transmission output shaft O rings 2002 LeMans parts book
SOLD, THANKS! Hepco&Becker Rack for V11 Sport Variants
Bugtarget replied to Bugtarget's topic in Personal Ads
No, it's this one- https://www.motomachines.com/Complete-Rack--Moto-Guzzi-V-11-Sport-Naked-Le-Mans-from-01-Cafe-Sport-Ballbio-Scura-Coppa-Italia_p_1016.html -
Complete Rack - Moto Guzzi V11 Sport, Le Mans from 01', Cafe Sport, Ballbio, Scura, Coppa Italia, etc. Rack in great condition. Usual wear. Never down or bent. The Complete Rack is a combined side carrier and rear rack that accepts any hard side case or top case from Hepco & Becker. The design of the complete rack gets its overall strength from being installed as a unit to the strong points of the bike’s frame. For this reason, it cannot be separated to use individually as a rear or side rack.These racks are made of high quality steel tubing finished in black. More pictures available on request Shipping from Olympia, WA to USA only. $295 plus shipping.
UPDATE- Took the dash apart to get to the idiot bulbs but all LOOKS okay. But, I found out that the #5 fuse doesn't pop when the #1 relay is removed but the #2 relay stays in place. Not being a sparky, does this help in isolating the problem?
I first noticed the problem when the bike was running and I hit the horn button. The fuse popped then. I hadn't ridden the bike in a while and thought I'd be okay for a spin through the neighborhood. Well, a half mile from the house and the reg/rec started smoking. I pushed the bike home. Replaced the reg/rec and the bike runs great but the problem remains with the blown fuse.
Thanks for the suggestions! I now have renewed motivation and will go out and try the headlight and idiot bulbs.
Hi All! When I turn the ignition key on the F5 15amp fuse immediately melts. This controls the headlight, horns, etc. Any tips on a place to start or a common issue in this circuit. Thanks for any help! 2002 V11 LeMans
Hi All! This bike had been ridden, loved and maintained by enthusiasts. Fuel Injection tune by Moto International last year. Michelin Road Pilot 4 GT tires with decent life left. 54,200 miles. Clean title. The odometer is broken as is the case with a lot of these bikes. I have been fastidious at keeping proper mileage records with the trip meter. I can show you the records. There are external and internal oil leaks. The external is very mild. The internal leak is most likely the clutch push rod seal. This is a typical Guzzi problem. The clutch has slipped on me twice. Both times under HARD power getting on the freeway. I've ridden the bike quite a bit since the slippage without issue. The bike has many upgrades and after market goodies- Moto Guzzi brand tank bag, K&N air filter, Power Commander III, MPH bar risers, heated grips w/thermostat, center stand, up graded fork springs and fuel pump, Hepco and Becker rack, 30 liter Jr. Flash bags and 48 liter Journey top case with optional back pad, Guzziology 8.0 and factory parts manual. Extra's include a spare throttle cable, misc. gaskets, Brembo caliper kits, brake pads, oil filter, etc. Pictures available on CL post- https://seattle.craigslist.org/oly/mcy/6087534627.html Thanks for looking!
Hi All, Does anyone know if a FBF cross over is compatible with an after market Teo Lamers V11 Sport/LeMans center stand? Thanks!
I'm still looking for a used cross over for my V11 LeMans. Thanks.
Still looking for a Mistral cross over and a center stand for my V11. Center stand needs to be the second generation for the 180 tires. Thanks!
Any unusual precautions to swapping the ECU on my V11 LeMans? Disconnect the battery first? Or just unhook the wiring harness and ground wires and remove? Thanks! Doug
Seeking a Mistral cross over for my LeMans. Thanks, Doug
All parts used. Add shipping. Pix and details upon request. Misc. Guzzi Parts- Dyna D37-1 ignition with 3 ohm(green) coils, $175, Shipping from Olympia, WA. USA
Hoping to purchase a complete center stand for my 2002 V11 LeMans. Must be the second generation stand for the 180 rear tire. Thanks. Doug Olympia, Washington USA
The DynoJet web site doesn't show a PCIII for a 2002 LeMans. What model are people using for the LeMans? Thanks!
Permanent fit.
