Roycam
Everything posted by Roycam
  1. Roycam
    Roycam
  2. Thanks for the responses. Yes, I have a spark, but the idle speed is way higher on the right side (too high). I have checked again and can't see anything disturbed by the tank removal. I'm thinking now that I'd never properly started the bike since September / October, only turned the engine over until it fired, then switched it off. It's possible the problem existed before I removed the tank then, but probably less likely since it ran fine last summer and tank removal was the only thing I did to the bike after the summer. I'm thinking of the fuel injection now. I've been using last year's petrol. Is it possible one of the injectors has got gummed up? I found something on the forum about cleaning the injectors in situ (workshop manual tells me to remove the engine..!) worth a try?
  3. Hi, I just took the tank off and checked nothing's in the way of anything else. No problems as far as I can see. Started it up again, same story. Right side starts at a high idle speed, if I blip the throttle the idle speed starts to climb.. again, right side hotter than left. A long way from a Guzzi dealer here, may have to try the local bike shop, see what they say. Thanks Roy
  4. Marty, Thanks for the advice. I've ordered up a manometer so will balance the throttle bodies when I get it. I just took the bike up the road, half a mile at most. It was firing on both, but seemed to idle on the right only. The idle speed was racing (don't know how high, rev clock packed up) but very fast, on the right only. Not surprisingly the right cylinder was way hotter than the left when I stopped. Strange, nothing has been tinkered with except for removal of the tank. Thanks again. Roy
  5. Hi All, I'm having a problem with my 2001 V11 Sport, hoping someone can help? After removing and replacing the tank the bike would only fire up on the right cylinder. Having noticed a broken cable on the solenoid valve I replaced it with a manual petcock (just in case) but still only firing on the right. After checking there was a spark on the left I took the plug cap off the right side and finally got the left to fire up. I let it run for a few minutes, then replaced the right plug cap to fire both up together, but again only the right cylinder would fire. The left cylinder will only fire when the right is not firing. I'm new to fuel injection, but guessing the problem may be there? Suggestions appreciated! Thanks Roy
