mikethebike
Everything posted by mikethebike
Hi, I’m not new to the forum but it has been many years since I have participated – I was pleased to find that my user name and password still worked. I have been suffering from “startus interruptus” for years now and I have finally got to the point where I have to fix it. Usual trouble – press the starter and the bike starts and other times just the familiar click sometimes several times in a row but it always eventually starts. There has never been any consistent pattern to the press-click problem. The bike can sit for a couple of months and fire up first press or after a 100 mile run and stop for petrol it can then click-click-click-fire. Worst occasion was getting off the ferry in Holland when it took about 10 presses of the start button and a squirt of WD40 into the starter switch and a serious talking to before it started and then it behaved for the rest of the tour. I have checked and cleaned terminals, earths etc and fitted new relays, starter solenoid, complete starter and new battery but still the problem returns. So now when I finally get round to looking to sort it out once and for all I consulted this forum and found recent threads which at last makes things clear. My bike is a V11 Sport which I bought new in 2002. The owner’s manual wiring diagram shows the "sensible" wiring for the starter circuit so I believed the problem did not lie here – or so I thought…. Finding Stewgnu’s colour wiring diagram has been a revelation – my bike is wired up exactly as this shows which is the “weak” circuitry. Kiwi_Roy’s voltage test confirms this – I get 12.2V at relay contact 30 with the ignition switched on. (and 0V with ignition off) So it looks like the additional relay in the starter circuit will be the answer but before I begin to do this work I need to clarify what I am going to do to make sure I get it right first time. From previous threads, Kiwi_Roy’s sketch above has been translated in Stewgnu’s colour wiring diagram. My interpretation is – Remove the cable from existing starter relay contact 87 and insulate the cable terminal and secure it out of the way. Make a new cable and connect existing relay contact 87 to additional relay contact 85. Make a new cable and connect additional relay contact 86 to earth. Make a new cable and connect additional relay contact 87 to the spade connection on the starter solenoid. Make a new cable including a 20A fuse and connect additional relay contact 30 to the battery positive terminal or the ring terminal stud on the starter motor. Which would be best? New cables will be heavier gauge than current wiring. Stewgnu’s diagram shows 15A and 30A fuses – I propose to use only one 20A fuse? New additional relay can be either 4 pin or 5 pin? Here is my plan in diagram form ---- Comments and advice would be gratefully received. Thanks
It's been a bit cool here in Scotland of late and starting the bike from cold has started to become a bit of a worry. Press the starter button and it grunts a couple of times and then bursts into life but doesn't spin freely the same way it does when the weather is warmer or after the bike is up to running temperature. I can start the bike after work - grunt, grunt, vroom and then ride to the local petrol station about 100 yards away, stop and gas up and then the bike fires up like it should - whirr, vroom. Bike is a V11 Sport 2002. Battery has 12.6V available (it's the original one - now 5 years old) after an all night rest or after a couple days inactivity so it seems to holding its charge OK. Electrical connections are good and tight. Could the battery be on the way out - despite regularly showing 12.6V or could there be a starter motor or relay problem developing or some other weakness in the system? Don't recall it being so sluggish in the even cooler Spring. Give me a nuts and bolts problem and I'll sort it but mention electrons and my eyes glaze over and I'll start to think of football, beer, sausages, naked ladies, bikes, anything other than electrons...... I'm starting to get a bit paranoid about it - anyone out there had any similar experiences or clues as to what is happening?
I was converted to Redline Shockproof Heavy some time ago and wondered how long it would last between oil changes. There was talk about it lasting 2-3 times longer than regular 80W/90 and even that it would never need changing. 10000 miles on however and being a stickler for regular maintenance I decided that I should change it. At £25 a US quart (direct from Redline UK inc carriage) it is around 3 times more expensive than Castrol. Anyway the oil was drained and what came out was a murky pink colour but it still felt like oil and had much the same sticky consistency as the new stuff. I reckon it would be OK for another couple of thousand miles so I'll set a limit of 12000 miles between changes from now on. I feel better for doing it. Just thought I'd share that with you.
thanks Edge, didn't so much get them as got them made (in the machine shop at work). I'll be in touch.
Forgot to mention last time - my neutral light has always been a bit hit or miss, sometimes it works sometimes not. But since using Heavy it comes on every time without fail and the light has never been brighter. So this amazing stuff cures electrical problems as well. Is there no end to its talents? I'm going to start carrying some in a wee bottle and next time I've got a problem I'll just rub the offending part with the elixer and the Redline genie will fix it.
I’ve got the “drawings” on my PC at work (they’re actually CAD files) so I’ll get the info converted into a word doc that I can email to you on Monday/Tuesday. The parts are made in aluminium alloy but they've survived around 7000 miles with Mrs mtb on the back and they’re still rock solid. You could hang the whole bike from them and they wouldn’t bend. I think the design is a wee bit utilitarian but they look OK in the flesh. I wouldn’t have left them on this long otherwise. The only reason I didn’t utilise the folding Guzzi pegs was simply time – I had to do a quick design that could be knocked up the next day at work and I didn’t have time for the added complexity needed to use the originals. It would be "fairly" straightforward to change the mounting blocks to take the folding pegs. The only reason I haven’t come up with the new improved design is laziness (and these ones work) ps 1 coincidently, we passed through Saverne during Eurotour 2004 so next year watch out… Col du Bonhomme - execellent ps 2 Mrs mtb really appreciated being referred to as a “young lady"........she’s certainly young at heart.
I’ve carried out several oil changes and I’ve never yet managed to remove the filter through the access hole. I’ve tried a variety of home-made tools and even bought a special tool just the right size for the filter but no luck. I always tighten the filter to the specified torque but once it’s been there for a while it seems to get a great grip and won’t budge. Each time I’ve had to remove the sump and use a strap wrench like you’d use on your car. But there has always been enough crud or sludge in the sump to warrant a good clean. There is also a mesh filter in there that needs a periodic clean. With care the old gasket comes away cleanly and can be re-used - the current gasket has survived the last three changes. You also have to disconnect an oil feed pipe at the rear of the sump - this gets tightened up again nice and tight by feel but not too tight! The job appears a bit daunting for the first timer but it's probably quicker to drop the sump than buggering about trying to get the filter out. Anyway I always feel better afterwards knowing that the innards of the sump are nice and clean. Make sure to tighten the sump screws progressively and evenly and apply the correct torque. Good luck.
I have fitted a forward-set rear footpeg mod to my V11. I bought a set of Hepco & Becker hard luggage (similar to the cases fitted to Calis) which is excellent kit but it severely restricted access to the pegs and Mrs mtb couldn’t tuck the heels of her boots behind the pegs which left her feeling a bit insecure. So I designed a new peg arrangement which moved the pegs forward by an inch and a half. Far enough forward for her to get her feet on comfortably but not so far forward for her toes to interfere with my heels. I have said before on these pages that Mrs mtb reckons this is our comfiest ever bike - due in part to the new peg position. Less bending of ze knees you see. This peg design was rustled up in an evening, parts were made at work the next day and fitted that night. We were heading off on our first Guzzi Eurotour a couple of days later – so the design had to be kept quick and simple. I had planned to make a more sophisticated set-up later using the folding Guzzi pegs but the “temporary” fixed position pegs have stayed on ever since. If you want a copy of the drawings get in touch. I could look into having a few sets made if there is any interest. It would probably cost a bit though. Don’t think I could swing a batch being made at work. I might even be encouraged to design the new improved model at last.
I've done 700 plus miles in the past couple of weeks since changing to Heavy, including a couple of early morning starts when the temp has been 5 or 6 C. Haven't noticed any negative effects at these lower temps. Still enjoying the slicker shifting. I'm a believer.
On the subject of workshop manuals, there’s a guy in the UK who can supply CDs of the V11 manual (’99 – ’03) and also the Guzzi training CD which has film clips of engine and transmission stripdowns complete with narrative. They are excellent and if I remember right only cost about £4 for the shop manual and £6 for the training CD plus p&p. You can also listen to the training CD in several languages so you can learn Guzzi in Italian or whatever. Very educational. Contact
When I read the good words about SPH I immediately ordered some from Redline UK which for £24.76 inc carriage for 946cc must be brilliant stuff. (This was cheaper than Demon Tweeks). The package came two days later and went in the g'box yesterday. Now, my real interest in this oil is as a result of a whirr from the gearbox which is evident at all speeds in all gears and developed about 200 miles after I bought the bike. It’s a bit like an electric milk-float noise and has bugged me for a long time. On a trip to Italy I asked Agostini’s for their opinion but they thought it sounded OK. The noise is definitely there though. I’ve experimented with other oils with no improvement but the SPH claims it has much thicker oil-film properties and is like a 250 grade oil at working temperature, with noise reduction properties. So, sounds like this has to be the stuff I’ve been looking for to get rid of the dreaded whirr. Well, a test run today showed that the noise has been reduced (some) and I definitely have a slicker shift. So thumbs up for Redline. I don’t plan to leave it in there forever but I should get 2 or 3 times the life of dinograde which will reduce the effect on my wallet. The oil itself is red and thick – like a raspberry milkshake. There was about 100cc left in the bottle. I couldn’t resist it – a good dollop of whipped cream on top – mmm, deelishus.
Set to work with a Dremel and small grinder and cut a slot in the outer race which then lifted out easily – excellent. New bearing was obviously going to be a tight fit so I heated the bevel box bearing bore with a blow torch and the new race drifted in – again easily. There is no shoulder in this bore to set the position of the bearing so I used the large outer washer to set the bearing flush with the recessed face the washer sits in. So far so good. Next came the matter of the oil seal. This is fitted below the large expensive looking needle roller. Much examination and measuring of the parts showed that the old seal sealing diameter was 36.9mm. New seal is 36.4mm. Shaft is 38.0mm. The old seal surface looked OK – no nicks or rough areas so I concluded that the old seal is a wee bit worn but should still seal. But since I had the whole thing apart (and there was a leak after all ) I decided to attempt removal of needle roller. There is a small land of the outer race accessible between bearing and seal to get a puller onto to haul it out. Heated the casing, but not too much for fear of melting the seal and leaving me totally stuck if I couldn’t shift the bearing which in the end proved to be way too tight for my home-made puller. More heat and a much more sturdy puller is required. Having measured all the parts I know what is needed and have a good design in mind to make one if I can’t locate a suitable ready-made puller. Needing the bike back on the road I decided to put it all back together and leave the seal for another day – next new rear tyre fitting time. The seal should hold out til then. The oil level plug hole is about level with the lowest point of the seal sealing diameter so if I don’t overfill the box that should help. (Confession time – I think I did overfill it last oil change) A good dod of grease was applied all around the washer/spacer/bearing/inner race/swing arm to try to keep water out. This will be regular maintenance task from now on. Anyway – new needle roller fitted, bevelbox wobble cured. Old bearing part number – Torrington HK 2516 2RS New bearing part number – NTN (japan) HK 2516 LL If there’s a next time I’ll check out if a bearing factor can supply it cheaper than the £34 I paid. 25 mile test run – no leak. (so far, fingers crossed, touch wood, etc) Celebratory beer called for. Thanks again chaps for the help and support. It’s good to know you’re not alone.
Yep, I had cracks in all four boots. replaced them at about 20000 miles. Simple enough job and able to be done without separating throttle body linkage.
Received new outboard needle roller bearing and spacer (inner race) – next day delivery from the good folk at Motomecca – at a cost of £34. Note these are sold as two separate parts. Also got an oil seal (only £2) and a cover o-ring seal (£1). Stripped off bevel box and yes the needle roller was well and truly goosed. Needle bearing is a very tight fit in casing (fitted from the outside) and will need some fancy extractor tool to remove it…..unless of course I try my usual cunning and a bit of brute force to drift it out. So off with the cover/crown wheel assembly to get better access – this came off relatively easily – remove the 8 very tight loctited (why???) bolts and apply a little leverage with a couple of tyre levers. The bearing outer race has folded over ends which retain sealing rubbers and which would provide an edge for a small diameter drift. Prised out the cage and seals to get at the flange and gave it a good whack – only to knock off a piece of aforementioned flange. Had a fag and considered the options – special puller – obvious choice but don’t have one heat up casing in oven – fill kitchen with delightful aroma of hot gear oil, possibly wreck seals, spoil cakes and pies for weeks to come heat casing with blow torch – burn off casing paint and possibly damage oil seal attack bearing with small grinding tool and collapse it inwards – successfully did this before on a car gearbox take bevel box to nearest dealer - 80 miles away but I'm not beaten yet have some beer and go to bed and sleep on it – sounds like best idea The next problem is the swing arm side oil seal which is located below the large needle roller bearing which I would not attempt to shift without a special extractor which of course I don’t have. Tomorrow’s another day. More beer please.
Thanks for that guys. The complete bevel box is moving relative to the wheel/swing arm and from pete roper's (and Colin's) excellent stripdown pics it looks like the outer needle roller could be the culprit. I will attack it first - it may be possible to extract it without major surgery. The seal might be a different matter though, but with the whole thing running true maybe the seal will seal again. ever hopeful....
Those of you who followed my ramblings a few weeks ago on my timing cover oil leak saga will recall that no sooner than I’d finished the job that I spotted a leak from the bevel drive. I put up with a slight seep for several hundred miles until today when I felt some play in the bevel drive. In fact I can wiggle it back and fore about a couple of millimetres top and bottom and a very small gap has appeared between bevel drive and swing arm. The rear wheel spindle nut is still tight. Looks like a bearing has given up the ghost. As I’ve mopped up the seep (only a drip or so) every 30 odd miles I’m certain that the play was not there until now. Would any kind person who reads this try to wiggle their bevel drive and confirm that play should not be there before I strip the back end apart. (I know it shouldn’t be but doubts creep in when you’re desperate) Also, I’m confused about the rear spindle nut tightening torque. The owner’s manual and the workshop manual (in the list of torque values) both say that this should be 120Nm, but the shop manual also has a picture that says it’s 28/30Nm which seems far too low and must be a typo. Why must they confuse us so? I’ve always used 120. Also, has anyone stripped a bevel drive without using the special tools mentioned in the manual? Don't want to wreck anything by battering hell out of it with a hammer and drift. She's a 2002 V11 Sport. Still love her though.
I’ve had my V11 for 3 years and 27000 miles which has included four trips to Europe with Mrs mikethebike on the back. She reckons it’s the most comfortable bike we’ve had and has been happy to cover fairly large distances (290 miles/day) on our travels. Our previous bike was a Triumph Sprint ST which is regarded as one of the best sports tourers around – certainly faster, better handling, and generally a great all-rounder - but Mrs mtb gives the Guzzi saddle the “pillion in a million” vote of confidence and if she’s happy it must be good. Many of these miles have been ridden in heavy rain and the only problem with the electrics has been after a two hour ride in monsoon conditions after which the ignition light came on at tickover. A couple of squirts of WD40 on the voltage regulator leads cured this…until the next next trip in heavy rain, and so on. It never got any worse than this but after a few months I replaced the reg (£80!!!!) and that fixed it. Switch gear and other exposed lectrics have been fine. After 32 years of riding a wide variety of bikes the V11 is our all-time favourite. Full of character, great to ride, with that fantastic v-twin throb as you thud along the road. Great. Buy a Guzzi – you know it makes sense (that last bit is debatable)
Bike is now back on the road and 100 plus miles ridden and oil is staying in the engine. So far so good. I had a Victor Meldrew “I don’t belieeeeve it” moment at the final stage of the rebuild when I discovered an oil slick coming from the rear transmission box. Oil was leaking from between the box and the swinging arm. There was definitely no leak before I started the timing cover job. The bike was supported by a paddock stand during the timing cover work so maybe it had something to do with the bike being raised at the back end for a week?. It’s a seep rather than a leak now that the bike is back in action – a couple of drops can be collected on a cloth stuffed under the swing-arm after 25/30 miles. I’ll monitor this and hope it clears up (wishful thinking) or at least doesn’t get any worse until it’s time for a new back tyre when I’ll investigate further. Still love my Guzzi though.
The Guzzi manual says to use Agip racing 4T 20W50 which is a synthetic oil. Agip seems to be unobtainable in the UK so I use Motul 300V 15W50 synthetic which you can get from Hein Gericke. Blooming expensive though. Mobil 1 15W50 is cheaper and more readily available (Halfords etc) so I might change to that next time. I’m sure an unsophisticated engine like the V11 could run on multigrade but if Guzzi recommend synthetic then that’s what I’ll use. Good oil is key to engine longevity so I think it’s worth the money. I’ve never managed to remove the filter through the access hole despite trying bought and home-made filter tools so I drop the sump and use a strap-wrench. The sump usually needs a clean up anyway so it’s worth the extra bit of effort. The current gasket has been reused twice so far with no leaks. I've followed the recommended 6000 mile change frequency so far but with 27000 miles on the clock I'll be reducing this to 5000 for the next couple of changes.
Latest news of the rebuild plus my theory on what causes the leak....... Most parts now reassembled, just got to make final connections and refit tank etc. When I wiggled the sub-frame back into position the holes would not line up with the frame. After much head scratching and trying to fit the screws in different orders I put a jack under the sump and to my relief the holes came into alignment. Phew. I had placed blocks under the sump before I removed the sub-frame but the engine still dropped by about 1mm. I’ll make sure the other engine mounts are tight. Anyway, everyone who has had a timing cover leak reports that it occurs in the same position – beside the right engine mount. You’ve heard about the infamous Japanese water torture where water drips onto someone’s head and eventually wears through the skull and into the brain and the guy goes mad or something like that? Also water erosion on stone etc... Anyway, my theory…… instead of water dripping, imagine boiling oil droplets being fired at high velocity – that’s what happens when the timing chain is thrashing round. The chain makes a sudden change of direction round the camshaft chainwheel right at the point where the leaks happen and the oil is flung off. The cover joint is right in line with the chain. The spray of hot oil droplets then eats away at the gasket until it gives up the ghost and pops out – hey presto a leak. When I checked out the source of the leak when it started I was surprised that oil started to emerge immediately I fired up the engine. That’s why I thought there must be an oil way inside the cover but it was just the force of the oil thrown from the chain oozing through the tear in the gasket. If that’s the cause I don’t know why it’s not more common. Anyone got any other ideas?
Strip-down now complete with only one or two minor troubles. I don’t think paint overspill was the cause of my gasket failure. There was some paint on the timing cover surface but not where the leak was. Dodgy/damaged original gasket I reckon. I had to remove the front sub-frame to get the timing cover off. Earlier bikes have two horizontal cross-tubes on the sub-frame which would allow enough clearance for the cover to come off. My sub-frame has a third diagonal tube running from the lower horizontal tube down to the left engine mount. This prevents the cover from coming far enough forward to clear the crankshaft. Made the job a bit longer. If anyone is going to carry out a timing cover gasket replacement get a new crankshaft oil-seal and four M6 x 30mm long socket head screws as well as a new gasket. I decided that replacing the oil-seal would prevent me worrying about a leak developing there having disturbed it – it looked OK but better safe than sorry. New seal only cost a couple of quid and looks better than the 27000 mile job it's replacing. The four generator cross-head screws did not survive the strip-down as they are made from low-grade steel and were well and truly seized in the cover – two heads rounded and only just came loose with some serious mole-grip action. Also, be sure to remove the sub-frame before tackling the generator and timing cover screws – access is much better and you will save a lot of time. Don’t forget to remove the side-stand as it is attached to both the crankcase and the timing cover. Generator rotor slipped off with a bit of gentle persuasion with a couple of tyre-levers. Actually, it took quite a bit of persuasion, and the rotor came loose with a mighty crack. All parts are now cleaned up and ready for reassembly. Stuck-on gasket bits were removed using my trusty credit card scraper – tough enough to scrape off the gasket but soft enough not to scratch the aluminium casings. Only other problem I discovered was the three rubber bushes that support the ignition coils had parted company with their threaded studs so the coils were only supported by the HT leads and other cables. They wouldn’t go far but I’ll rig something up to lash them in securely. (Too mean to buy new bushes) I don’t have a garage so I’ve been relying on the good Scottish summer weather –HA HA HA – to find time between the rain to get the job done. Amused the neighbours by climbing under the bike cover to do one or two jobs with just my legs sticking out. With all the sub-frame malarkey I reckon the whole job could be done in a day. How many pints is that? I’ll let you know when I’m back on the road.
thanks you guys for the words of wisdom. It's a big relief not to have to drop the motor. A new gasket is in the post so the spanners will be out this weekend. Cheers! Mike
My 3 year old V11 has just sprung an oil leak - a week after our third trip to Italy (Mandello, of course) from Scotland and having just clocked up mile 27,000 – I suppose the timing could have been a lot worse – on top of one of the many Alpine passes we crossed for instance. Today, as I walked towards the bike for my 30 mile ride home from work I spotted a damp patch under the sump. As I got closer I could see an oil slick down the side of the engine block but could not tell where it was coming from. I cleaned up the oil, checked that the oil level was OK and decided to proceed homeward, stopping every few miles to clean up the leakage and check that it had not got bad enough to risk running too low. Got home, cleaned up the engine and fired her up. A leak immediately started from the right side of the timing cover beside the frame mounting. A piece of gasket was sticking out at this point which, having consulted the workshop manual, looks to be beside an oil-way running from the block into the timing cover. (Is there an oil-way here or is it just a dowel? If it’s not an oil-way then the timing chest must be full of oil but there’s still plenty in the sump so I don’t think this is likely. Must be an oil-way?) Looks like an engine-out job to fix. Sat down, had a smoke and a think. If I remove the oil cooler etc I should get access to all the timing cover screws. But I would only be able to move the timing cover forward by about an inch before it hits the frame. If I cut the new gasket at the top I could fit it in the inch gap and apply gasket cement at the top split (this has worked on other jobs before). If it doesn’t work I’m no worse off because I will have to strip all this area to get the engine out anyway. Worth a try? Has anyone had a similar problem? Has anyone got a better fix? Any words of encouragement would be appreciated. cheers, Mike
I'm the guy Baldini refers to regarding UK recall of V11 for my 2002 V11 Sport which lists possible problems concerning - "connecting rods", "gear internal spring drive", and "double moveable hose". I'm sure my bike is a 2002 model. 16500 miles so far with no trouble. Frame number is ZGUKS00001M111147. I'm going to contact Guzzi UK Customer Services for advice. I'll let you all know what I find out. Mike
