Everything posted by LowRyter
It's not one thing it's another...........
I wouldn't mind having the RC8. It's very comfortable, perhaps more so than my Sport. And man, it's a Superbike with some real midrange.
when mine is vertical, it definitely shows full. I might dump it and remeasure in a marked cup. I've just been eyeballing it out of the site line on the side of the bottle.
my dream bike would be my Greenie done up with a Mike Rich engine and Guzzitech Suspension.
Oh the tranny has a site glass not an overflow plug. Gees forgot that. Anyway it's full when upright vs on the sidestand. I am guessing that it might be pretty easy to overfill it.
Well I was finally able to trace it. Unfortunately, It's the transmission that is leaking. Not sure where or how. I switched to a red gear oil and found a few drips and lots of smear on the bottom. First thing I'll check is if it's overfilled (I fill it on the sidestand) and check if it needs a crush washer. Next I'll look for cracks,
But silver ones are slower than Greenies.
Docc- Best I can tell my bike is 6-2000 build. S/N 1132xx Looks like mine is a later build than your
I think the Sport will be a sportier ride than the Beemer. Hopefully, given it's age and mileage it's been sorted out. One thing that might be a difference is riding a traditional fork on the Sport vs the Telelever Beemer. I really like the feel and handling of the Sport (other than highway weave issue) and didn't get used to the "power steering" that some Beemers have. It might be the opposite for you.
That doesn't look fun at all. When in a fast sweeper and I hit a bump my Sport will sometimes give 1 or 2 wiggles and settle immediately. Looking at the film. I wonder if the sitting upright acts as a spoiler and unloads the front wheel, increasing the wobble, and lying down loads it back up by eliminating the spoiler effect and also shifting some weight forward. I didn't see the "lying down" test with any of the faired bikes. I wonder if it would work as well, (or at all), as the naked bikes. Interesting film that shows the need for attention to tire condition and pressure. For sure, weighting the front improves weave (mis)behavior, as does attention to tire condition and pressure. Regarding RedFrames, they are certainly shorter than later (2002 on) long-frames while the fork rake remains the same. Except (reportedly) the earliest RedFrames with the notable triple clamp numbers. LowRyter: look up under your upper triple clamp with a light and find the part number . . . . ? Docc, Not sure I follow. My front axle is screwed to my fork leg? I'd certainly hope so. Not getting what you mean. I'll see if I can check for a part number soon.
well Phil, There are 3 shops in the USA that will do this work. Joel got it done on time and on cost and talked to me about it on the phone. You know I didn't even think about the needle until I got it back. But yeah, maybe he should've caught it. And I should've told him about it. On the other hand it doesn't look discolored, only white.
for us red framers, the film is probably most relevant.
a film about motorcycle weave and wobble.
SD. He did not. I should've mentioned it him. The face was fine but the red needle was faded and he didn't paint it or replace it. I think he probably would paint the needle- I've done it myself fixing the tach on my EV. I would guess the face might be another issue since it would require much more work or a replacement. I would call him and ask.
A Racetech tech told me that single rate springs work best on front forks. I am not sure for the reason. Also, someone on the board here had found a Racetech Gold Valve kit that fits the V11 although no kit was listed by Racetech. You might search the board.
MF- looks like a nice flyscreen. Good job. I didn't new years got up to about 40. I rode the day after and got about 5 miles and determined that it's nuts.
Happy New Year !
LowRyter replied to nobleswood's topic in Special place for banter and conversation
woke up to a 4.2 tremor at 5:40 am. day before yesterday it was a 4.3 at 5:30 happy new year -
I have a similar Guzzi fly screen on my Greenie. First, does it mounting holes on the sides to match the bolt ears on the headlight? If you have that, then it's just a matter of bracing the top half to the bars or triple clamp. You might find a local welder or machine shop to fab some mounts.
Sitka? Road Kill (Wild Guzzi board) is in Sitka.
http://www.mgcycle.com/index.php?main_page=product_info&products_id=1687 the headers look fine from the photo
we'll see how long it holds up. But it is all original.
The Veglia Whiteface Speedometer on my 2001 Sport has been jumpy since I bought it with 12k miles on it a few years ago. The trip odo stem fell out a few months ago and was epoxied back in. I have 34k miles on it now and the Speedo finally packed it in and froze at 85 mph. It unfroze and finally froze again forever. I shopped around and got it repaired by Joel Levine in Lafayette Ga. He turned it around in a week and charged me $294 incl shipping. Got it back and reinstalled it and it works fine for the brief ride I took (in the rain). Speedo is steady and trip odo is turning. I think this is cheaper than getting a Speedhut replacement or from the two other repair shops in the US. The turn around was definitely quicker than anyone else. A couple of notes. I broke the light socket unawares. Got another one from Harpers and replaced both lamps 3V (for Speedo and Tach). I also notched the dash housing so I could install and remove the housing without taking the trip odo stem out. I couldn't get the housing to match up when I was trying to screw the stem back in in the first place. It was much easier just to screw the stem in and put the housing on. So far, so good. Joel tells me that Veglia weren't really good in the first place and the quality only got worse. For now, I recommend him.
Roy set me straight.
I have the identical stem. How do you unscrew it? And if yours unscrews, what prevents you from unscrewing when you use it when you happen to twist it the opposite way?
I got it fixed by Joel Levine. He's online. Since I haven't installed it yet, I can only say it looks clean and the price and delivery were reasonable. Until I actually install it and use it, I can't make any determination. I am awaiting a 3v light socket that I damaged when I took it out. If I had known that I broke the socket at the time, I would've ordered one at the same time. BTW- I wrote him specifically about the stem and asked him not to install it because of the cover. He sent this note: "Hi, the Reset Knob is a LEFT HAND thread. After it is screwed in it will NOT unscrew, If any questions, please call. Thanks, Joel"
