Recently, riding on a highway, by my mistake, started wobbling and I crashed. As it turned out later, damper was not working properly. I will not refuse it anyway, furthermore it can be relieved when riding in town.
My dampher (Bitubo) is out of use and I am looking to replace it. What will fit better for my V11'02: A used one by Öhlins from eBay or a new one by Shindy (although I have not found anywhere to buy it with delivery to Belarus)? Can you recommend anything?
Hello!!!
I have a question
The oil started to leak from the generator cover. When I dismantled the motor, I replaced the oil seal which stands in front of a generator, and put a new one instead. What could have caused to oil leak? Will it be possible replace it without removing the front cover of the motor frame? And how critical is that, since I'm planning to do this sometime before the winter ...
Roy,
I have a link to the "Maxi" fuse.
I delivered to myself "Superseal Fuse-Holder", contact piece seems dense and good, but it didn't help. strange.
Well, I will deliver to MAXI holder.
Hi, everybody! It appeared that I broke the generator (after crankshaft breakage by a rotor beat about a stator) and it didn't give tension. Today I changed the generator. But the bike very weak charge of the accumulator. I changed the relay regulator, thought a problem in it, but it not helped. And all the time are heated fuss for accumulator and it's body melts (Replacement of a safety lock by MAX the version will help only?). In what there can be a problem?
I got it! And there is a complete list of TIGHTENING TORQUES? In Workshop manual it seems not all bolts are specified. For example Cap (12 02 26 00 - A6 page in parts catalog) in head. I hardly turned off it and with what we will strengthen to twist, I don't see.
I think acquire and polish under repair size. with replacement rod bearings. Normal variant?
http://www.ebay.com/itm/MOTO-GUZZI-V-11-ALBERO-MOTORE-ORIGINALE-COD-GU01064131-/230724052132?pt=Ricambi_e_Accessori_Moto&hash=item35b839a4a4&vxp=mtr
By the way, you were right. o-rings under the rocker arm were worn. Just in the beginning I gave the bike a person who is engaged in repair of motorcycles and asked them to replace, it was my fault because he or did not change them, or those O-rings
2002
Does anybody know what is the difference between crankshafts No 37064106 and No 01064131. They are both mentioned in catalogue 99-01, but in catalogue 02-07 only No 01064131 is mentioned. (My Guzzi seems to be a transitional model)
