Solar
    2
Solar last won the day on June 9 2013
Solar had the most liked content!
About Solar
  • Birthday 02/13/1980
    V11sport 2002
1,272 profile views
Solar's Achievements
Guzzisti
Guzzisti (2/5)
6
  1. Solar
    Remove gear box.
    Yes its My Guzzi!
  2. It seems to me a normal thing that when the bike is on the stand you need to turn a rear wheel to change gear,. I had that all my bikes,and while ride there was no problems with the changeing.
  3. Solar
    Remove gear box.
    Thank You I use Heavy one.
  4. Solar
    Remove gear box.
    And so I ride 200 miles after repair and everything works great!!! What more it seems to me that using shockproof gear oil, gear changes smoother!
  5. Solar
    Remove gear box.
    Hello boys and girls! On Tuesday, back to me shaft whit new gear!It looks great!!!Today after work, bike should be ready for a test ride!Also I bought Redline shockproof heavy oil
  6. Solar
    Remove gear box.
    There was no other since except missing teeth,and I never was rude, event more I was always gently.I thing You probably right, gear could be over hardened?My F/F after cutting new gear He gone send it to induction hardening
  7. Solar
    Remove gear box.
    For me yes,Im come from Poland and my Friend Father gone make it for me.
  8. Solar
    Remove gear box.
    Miles is only 19,800 I do it everything by myself so no labor cost,Gear whit broken tooth is part of Primary gear shaft assy and cost £577.70 inc. VAT But I have other plan I send shaft to Poland where engineering co. Make new gear and fit back on shaft.
  9. Solar
    Remove gear box.
    Some photo updates.
  10. Solar
    Remove gear box.
    Hallo Guys!Easiest half job done-transmission off!Is anybody taken gear box aparts?
  11. Hallo Everyone!I have big problem from Yesterday,bike start ratting on 4th gear.After remove selector cover and inspect springs I find nothing wrong,until I see one loose tooth on bottom of gear box!I don't now is it from bottom or top gear.My question is possible to take off gear box without moving engine?(after taking off wheel,shaft,swing arm etc)?Did someone do it?(maybe photos)Any tips to move or take apart box?Thx for any help and sorry for my English!Karol.
  12. No its different bike look on cans this one have factory optional titans.
  13. Yes I file the inside edge of the axle bolt not mutch but all 6 side.
  14. Hi Unkept!I have very same problem,I bay 14/17( http://www.ebay.co.uk/itm/OIL-Drain-Plug-Key-Sizes-14-17mm-Hex-ALLEN-BIT-SOCKET-/181052332449?pt=UK_Hand_Tools_Equipment&hash=item2a278f59a1) hex and its fit perfect on front axel but wont fit on rear ,problem was on edge so I take little fill and grinded edge now fit ok.
