Jetdoc
    V11, Norge, Centauro, Griso
684 profile views
Jetdoc's Achievements
Rookie
Rookie (1/5)
0
  1. Thanks Pete for clearing the air on the question!
  2. Kostarika: Based on your response and your listed bikes, am assuming you have plates for both your V11 and Centauro? Did you get both of these plates from Pete or another source? Was betting on them being the same, shows what I know.
  3. Is the Roper Plate for the V11 a direct fit to the Centauro or are there different models of the plate? Can Pete or someone out there please set me straight? Thanks, Jetdoc
  4. Anyone have a source for the improved shift kit for the early models (#973260900017). Tried Harpers and Teo L. and neither had any. Harpers shows them on the website, but they are out. Just wondering if anyone knows of a cache of NOS somewhere since Guzzi is no longer making them? If they are now unobtanium, has anyone figured a way around this other than finding a later model box that would in most cases be very cost prohibitive? Thanks
  5. Chuck, if you get enough other interest, you can put me down for two pieces to help the cause. Appreciate you even considering another run. Thanks
  6. As usual I am late to the party. Are there any extenders to be found? Any chance of another run? Know it's a long shot. Thanks
  7. Thanks footgoose, will do.
  8. Any chance there are any springs left. Came late to the party. Thanks
  9. Jetdoc
    Jetdoc
  10. It's a 2001, with white Veglia faces, got out the epoxy since the parts were still all there, looked like it never got crimped correctly. Must me a Veglia part, but have had no luck finding them. Scrud thanks for the offer but think the fix will work fine. Appreciate the help.
  11. Anyone have a part number for the metal/plastic lamp holder that slips into the back of the speedo & tach (not the idiot lamps). Had one come apart and it would intermittently blow the fuse for that circuit. Once the gauge cover was pulled you could see the little arc indications on the internal of the lamp holder. Has a male spade connector. Guzzi parts listing shows the lamp but not the holder, unless I am missing it which is entirely possible. Any help would be appreciated. Thanks Jetdoc
  12. The supplied clip ons drop things about 2", although the supplied bars will work just fine, been trying to adapt some billet Apex adjustible bars, jury is still out due to clerance issues with top triple clamp will have to see if they can be adapted with some machining work. Apex are first rate kit and give some adjustiblity. JetDoc 2001 V11 1998 Centauro Sport 2007 Norge
  13. Nils: Thanks for the direction, obvious once you know where to look. Greatly appreciated. Jetdoc
  14. Just received a Magni fairing in slime green. Mounting instructions are pretty limited. Got it all figured out with the following exception. For anyone that has mounted one of these, what are the two @ 2.5" long x .5" square aluminum blocks for, that have the 3@ 6mm holes, two of which are tapped, the other drilled through and countersunk? Any help would be appreciated. Thanks Jetdoc 2005 V11 Sport 1998 Centauro Sport
