4corsa
    13
Everything posted by 4corsa
  1. Awesome kit!
  2. ...exactly what I did a couple weeks ago. When i did the first dry run, they were off by just an 1/8" or so and needed a little adjusting and refitting. Glad I didn't have the sealant on at that point.
  3. You mean besides making sure the forks have enough clearance when steering?
  4. Has anyone else ever wished Guzzi made storage pods in the big empty space on the inside of both fairings? I swear you could get nearly a half gallon of storage on both sides and still have plenty of clearance for the fork rotation. So just curious if anyone in the past 20 years has made an attempt at having something custom made. I'm imaging how nice it would be to carry my fix a flat kit with air pump on one side, and sunglasses/shield spray and cloth on the other side. All without ruining the beautiful lines of the bike like tank bags do.
  5. Great! And the more you start consciously squeezing the tank with your knees, you'll be taking some weight off your wrists and using your core muscles more as well. Beautiful bike!
  6. Looks great, and anxious to hear how you like the grip and control after you've put in some spirited riding miles with them.
  7. I just shipped a pair of OEM aluminum oval slip-ons from my '03 Le Mans. The actual weight per the UPS digital scale was 23.72 lbs. I figure the box and packing material was maybe 1.5 - 2lbs max. So the stock cans weigh 11 lbs each (+ or - a few ounces). I wish I had an accurate method to weigh my oval carbon Mistrals before installing them, but they certainly are a lot lighter. My best guess is they weigh between 4 and 5lbs each. So total weight saved should be 12lbs.
  8. SOLD
  9. Two very different products. The 3m film is flat, ultra-clear, and less than 1mm thick. Stompgrip and Techspec are probably 3 or 4mm thick with intentionally uneven surfaces or "cleats" that are another 3mm long. The paint underneath will not be the same after a few years. Certainly won't be as bad as with a solid color, but you will see a difference from the surrounding paint.
  10. ...also depends on how many hours per year the bike is left in the sun, how often it's waxed, etc. Not to mention, even with clear tank grip, the paint will age differently under the grip pad than the surrounding paint that is exposed to the elements.
  11. From what I see on their website, they have two versions. Yours is the CF / Fiberglass composite. The purely CF version is $99. Let us know how the install and fit goes. Thinking of ordering one as well 😁
  12. TLM responded to my email that they are no longer making the V11 rear hugger, and are out of stock [emoji22] Let me know if anyone wants to part with theirs!
  13. Any idea if the Teo Lamers version is still available? Is it best to contact them at www.tlm.nl , or are there other distributors (anyone in the US)? Thanks!
  14. Awesome - thanks Docc. I will be unapologetically plagiarizing your labels!
  15. Guzzi no longer supplies the V11 Fuse Block. Luckily I found the OEM ATC & ATO block offered for $11 at Del City. I've also added this under the Forum's Encyclopedia of Compatible parts.
  16. OEM Part Name: Fuse Block Moto Guzzi Part Number: GU01743030 Replacement Part Brand or Source: ATC & ATO available at Del City (see attached photo) $11 Part number or other identifier: "ATC & ATO Block - 8 way" Comments:. This is the exact OEM fuse block that Guzzi used in my 03 Le Mans
  17. ...and if there are two available out there, I'll take the second one!
  18. My newly acquired '03 Le Mans arrived without a fuse box cover. Looking to buy a used one. Thanks!
  19. Ohlins are really worth it if you're an advanced track day rider (which I really wouldn't recommend with a V11).
  20. ...having owned a Scura with Ohlins, and now a Le Man's with Marzocchis, I can say they are both very good when properly set up. The Ohlins are maybe marginally more compliant over bumps while remaining firm under braking and cornering.
  21. There's a great video on YouTube that compares an Aprilia RS V-Twin to a Rosso Corsa "it's Monica Belluci vs Sophia Loren". Very funny and well done - one of the best quotes is "the Ohlins on the Guzzi is like paying for breast implants for your granny". That said, both guys picked the Guzzi over the Aprilia in the end!
  22. You are too kind docc, and you have awesome emojis! I have no excuse, I lived in Florence for 2 years where I contracted this terrible disease that makes me love everything Italian (Guzzis, Ducatis, Alfa Romeos, Sofia Loren, Prosecco...), and speak Italian reasonably well. I should cross-checked with the original Italian instructions 🤪 Anyway, filled it up to .850 and the good ol Redline is right in the middle of the glass. Glad the Pawl Spring job is done, and can't wait to ride her tomorrow!
  23. Thanks guys, .850 liters is what I thought I recalled from my old Scura. So here's where I got the info in the manual. On this page it says "transmission box" at 0.37 liters. Then I flipped to the previous page where it of course states "Rear transmission box". Doh!
  24. ...I rotated that plate fully counter-clockwise and re-assembled everything. Bike seems to shift well (at least 1st, neutral, and 2nd gear in the garage). Raining so will test ride tomorrow. One odd thing, I filled the gear oil with 0.37 liters as prescribed in the manual, and not showing up in the site glass (yes, drain plug in and bike vertical. I put in a little bit more, and still nothing, even after tilting the bike to the right of vertical. Will take it for a ride around the block and check the site glass tomorrow.
