4corsa
    13
Everything posted by 4corsa
  1. Absolutely - thanks!
  2. This Post is an attempt to make rational sense of the various reports of premature Scura OEM single disc clutch & aluminum flywheel failures, to try to establish accurate numbers and mileage at failures, AND current mileage on OEM clutch and flywheels that have not failed. Over the past decade there have been numerous theories and perhaps 20 or so confirmed reports of failures. Some have said the US models are free of these problems. There were approximately 700 Scuras produced in 2002 - 2003, each with a number plate. I'm thinking if everyone who owns a Scura could provide: # of their Scura; country of purchase; approximate date and mileage of failure (if occurred); and current mileage - we might be able to eventually establish a pattern and a range of Scura production that was most susceptible. Perhaps there were a couple months where there was an unknown production problem such as incorrect torque spec used on the center bolts, or a run of substandard flywheels. Hopefully, we will also establish a range of Scuras that have little chance of premature failure. Please forward this post to anyone you know who owns (or owned) a Scura. Thanks! I'll start the list: 2002 Scura #599, purchased in the US, NO FAILURES, current mileage 22,500 miles.
  3. Due to weight transfer to the front under braking, your front brakes do 80-90% of the work. You should only use your rear brake very lightly. The rear of the bike gets very light under heavy braking and can lock up the wheel very easily, which you never want. This is especially true when going downhill. But don't take it from me, take it from AMA champion Kevin Schwantz who said "I used the rear brake exactly once in my career - I'll never forget it because I crashed!"
  4. In case this hasn't already been covered, I was having trouble bleeding my rear under-mount Brembo caliper on my Scura. No matter how many times I bled it, I just couldn't get a firm pedal. Then I realized the problem is the bleeding nipple is located on the bottom. Air bubbles rise to the top and are trapped. So I unbolted the caliper and rotated it so the nipple was at the top and connected a tube. After just 3 bleeding cycles, all the air was pumped out and I got my firm pedal back.
  5. Almost forgot, one great unexpected plus to the Mistral Crossovers - I've got no more pinging under heavy acceleration in high gears in the mid rpm range! Not sure why or if it also may have to do with the fuel remapping, but finally no more pinging.
  6. Yes, I can confirm that the Mistral Crossovers fit nicely, very little wrestling to install.
  7. Update: I bought the Mistral crossovers from MG Cycle a few weeks ago and installed. Love them! I have to say, i'm surprised how much louder the exhaust is now. I replaced my stock mufflers Mistral straight-through cf mufflers last year (without the included db killers) and it made far less of a difference than the crossovers. Not sure why that is. I would say it is now about twice as loud as stock now. Before adjusting the Power Commander fuel mapping, It was hard to tell if there is a performance difference - the sound alone makes you feel like you're accelerating faster - lol! After loading the updated Power Commander fuel map for Mistral mufflers and crossover, it really does feel like its pulling harder and reaching redline quicker now - highly recommend this modification!
  8. Thanks all. I think I'll just go with the Mistrals from MG Cycle, that is unless someone has a used one they need to unload...
  9. Thanks for the info Guzzisti!
  10. Anyone know who carries Stucchi Crossovers for V11s in the US these days? Thanks.
  11. 4corsa
    My 02 Scura
  12. From the album: My 02 Scura
    stopping for lunch in Andes, NY
  13. 4corsa
    rps20150515 234313
    after installation of the Ghezzi Brian carbon fiber chin spoiler
  14. Thanks for your replies gents. I ordered my GEI Relays from Pyro Dan (Design Tech Engineering) last night - five for $16.50 including shipping. The GEI AR4-012-C11 number is correct and Dan confirmed it will work for all five plugs. I will report back if there are any issues with them
  15. Dumb question - assuming I purchase a few of the GEI AR4-012-C11 Relays as suggested above, will it work for all 5 Relays on the bike? That's what seems to be implied, but I read on another thread where someone temporarily messed up their electrics because they inadvertently mixed up the order of their Relays when they removed and re-installed them. Thanks for the help.
  16. Was just told by Yuasa not to use their battery since ours is installed horizontally. They said it must be a factory sealed battery, and their YTX15L for V11s is NOT.
  17. Awesome! Thanks so much.
  18. Found this image on Pintrest - the owner calls his bike "Tokyo Short Trip". Love the fairing and want one for my Scura. Please let me know if you know where it can be bought - thanks!
  19. Just discovered this very helpful topic because my rear caliper blew a piston seal and leaked all over my rear tire while riding this morning. I removed the caliper (20k miles, always garaged) this afternoon and discovered it was full of crap as predicted above. Luckily MG Cycles has brand new replacement calipers including pads for $122 in stock, not too bad. So if you're reading this and your rear caliper hasn't yet crapped out, now is the time to remove it and fully clean and service it!
  20. Thanks for the input, and that Tank Off Maintenance Checklist is great!
  21. I noticed a small puddle of oil under my '02 Scura after a 50 mile ride yesterday. Turns out the crank case breather hose split just above the lower connection point. It sure couldn't be any more buried behind everything else, but it looks like I might have a decent chance at accessing it with the gas tank (and possibly air box?) removed. Any suggestions from those who have already enjoyed this task would be greatly appreciated. Thank you.
  22. Just received and installed a carbon fiber chin spoiler from Ghezzi Brian (Bruno) on my '02 Scura. See attached. Some nice projects and after market bits on his website - nice guy to do business with.
  23. If your stock damper is an Ohlins like the one that came with my Scura, its the highest quality damper you can buy. If so, I recommend contacting Ohlins and sending to them for a rebuild. You're actually supposed to do this every year or two depending on use. If I recall correctly, it costs around $50.
