Everything posted by 4corsa
Mine is the same 64mm (2.5") Sent from my Pixel 4a using Tapatalk
Just a straight tip Docc Sent from my Pixel 4a using Tapatalk
I was able to get a standard grease gun fitting on the front nipple on my '03 Le Mans. Was not able to bend the hose successfully through the obvious direct path, but when I routed it through a crevice over the top it was easier. I had to use a pair of pliers to push it down onto the nipple once aligned. Sent from my Pixel 4a using Tapatalk
Andy, did you ever get the chance to take a better photo to share? Thanks. Sent from my Pixel 4a using Tapatalk
Finished the Mistral headers and crossovers install (already had the carbon slip-ons). Was a bit more involved than expected, but not too bad. Had to destroy the stock headers to remove the flanges [emoji3525], so one less OEM part available for those in need. But I have the stock cross-overs if anyone is interested. I was surprised with how much it changed the sound. Sounded good before, but magnificent now! [emoji854] Sent from my Pixel 4a using Tapatalk
But this was a surprise. The header flange is installed before welding the pipe together. Need to cut the pipe to remove it. One would think MG Cycle would mention this and suggest purchasing an extra pair. Sent from my Pixel 4a using Tapatalk
Doh! Nevermind. It was coming loose but not rising up and out. Need to pry apart. Sorry for the false alarm. Sent from my Pixel 4a using Tapatalk
Ok, so both the top and bottom bolt here turn counterclockwise independently, but go nowhere. Trying to remove crossover to swap for Mistrals. Did this on my Scura a few years ago and don't recall this one. Any suggestions would be appreciated. Thanks Sent from my Pixel 4a using Tapatalk
Did a compression test today (warm engine, wot) on my '03 Le Mans 15.5k miles. Looks like I'm a lucky guy: 158 and 160 psi. [emoji16] Sent from my Pixel 4a using Tapatalk
I can also attest for Seal Mate. Fixed fork leaks on my VFR and Monster S4R in the past 3 years. Seems to be true that most fork leaks are caused by small debris that gets up in your seal. Sent from my Pixel 4a using Tapatalk
Apologies if this was already posted elsewhere. Nice 20 minute documentary on YouTube. It's in Italian, but you can turn on english closed captioning in the upper right corner on YouTube. Sent from my Pixel 4a using Tapatalk
Mine arrived today as well - great stuff! Sent from my Pixel 4a using Tapatalk
I ordered a few of these today - nicest design I've seen so far. They have 80 other items with this design, from sweatshirts to duvet covers (surprise the wife!): https://www.redbubble.com/i/sticker/Moto-Guzzi-100-Years-by-GuzzistaVikings/69960271.JCQM3?ref=product-title&utm_campaign=2019_orderconfirmation_transactional_en&utm_medium=email&utm_source=RB&utm_term=44567697
So do you notice any differences with the new downpipes? Sound, responsiveness, etc?
