Don G
Everything posted by Don G
It's for old guys who can't keep it up anymore! DonG
The cost of oil has doubled, year on year?
Don G replied to p6x's topic in Special place for banter and conversation
Lots of things have gone up 75% or more, why I wonder? DonG -
Check the valve lash, if you find it larger than normal perhaps a cam lobe is going round. DonG
So sad, that was a party I was wanting to attend. DonG
I shod mine with some kind of Shinko sport bike tyre, 90% of my riding is pavement. DonG
About the only month that you can count out snow happening is July, perhaps riding across Canada should be left until a little later in the season like late May or June.... DonG
Depending on the spring, you may or may not freeze your nuts off crossing the prairies, the mountain passes are a whole other story, perhaps swinging south would be a good idea. Good luck! DonG
Best textured black paint recommendation
Don G replied to al_roethlisberger's topic in Technical Topics
Automotive trim paint works well also, sticks real good, can be had in satin black. DonG -
Don G replied to sign216's topic in Special place for banter and conversation
She is posed in front of an oil pump jack. DonG -
Does the odometer need to be working? I have one my 2004 Café Sport, speedo reads fine just wont add up mileage, I have a new speedo to replace it. Let me know. DonG
I have found that the fuel nowadays has no shelf life, it could be as simple as that, the shite wont ignite. DonG
Finally Bit The Bullet and Purchased A Lift
Don G replied to Mike Stewart's topic in Technical Topics
The lifts from Princess Auto are good quality, used to have two choices, foot pump or pneumatic. I took the clamp system off and installed a chock, much better now. DonG -
Bring on that pie! I have one similar on my Cafe Sport, different muffler. I run it with out the DB killer, sounds good, dont know if it affected HP or not, give it a try whats to loose? DonG
Looks like GPR. DonG
Changing out the washers will not even be noticed, they will have no descernable effect on anything. I would just flip them over and carry on. Oil pessure relief valve should be inspected as well as sump gaskets as there may be a leak there which could be the culprit(cavitation). DonG
I never bother to check the level in any of my Guzzi,s between changes, what for? DonG
OOOpppsss! If it is not I meant, Sorry DonG
- 72 replies
- engine knock
- knock
(and 1 more)
Tagged with:
Pull the alternator cover and see if your rotor is loose, if it is , pull the oil sump and drop the rod caps and check the rod bearings. DonG
- 72 replies
- engine knock
- knock
(and 1 more)
Tagged with:
Bring Beer!! DonG
Motrhead: No problem, I am working on getting them all under one roof! That Helicopter Jim dude wanted to see the collection too, hopefuly we can start a Guzzi get together out on the bald arse praries sometime next summer, what would be the interest in that I wonder? DonG
Yeah! Nothing better to do, we get approx. 6 or so months of winter here, need an indoor hobby! I buy and restore them, also have quite a few modern ones as well, even bought a couple new. Was heavy into Brit bikes and 1940's HD. Cleared that stuff out during a divorce and started anew with Moto Guzzi, nothing else like them. DonG
At the risk of being called a Horder again and having an intervention, I will say that other than the 21 Guzzis I posess, I do have an 1967 BSA Lightning and a Triumph Tina T10 scooter. DonG
Screws for Lafranconi silencers on my Rosso Corsa
Don G replied to Pi31478's topic in Technical Topics
If you want the shiny stainless fasteners a gold colour, just warm them up with a propane torch! Use pliers to hold them of course! DonG -
Really? Just hop on and go? Better look it over first, I bought a1978 G5 a couple of years ago, did a bunch of service work to it, supposedly was just built, did not bother checking the wheel bearings. BIG mistake! Buddy who ever did the wire wheel conversion did not install the bearing spacer! 80MPH failure of the front wheel bearing one day! I even take brand new from the store Guzzis apart and go over everything before using them, who knows who did what or didnt do what? I wont risk my life and happiness on trusting someone elses word on its ok its only got 6000 miles or its new what can go wrong? DONG
