rioeni486
Everything posted by rioeni486
  1. rioeni486
    rioeni486
  2. Thanks all above reply. Finally, all my lamps of dash working properly. 1.Oil check lamp : replace oil pressure switch(sender) - Trofom TF-3-008 (you can buy it www.aliexpress.com) - $7~8 2.Charing lamp(battery0 : Replace regulator(ESR515) - also overcharge(14~17volt) problem is fixed ^^
  3. hi. I am onwer of v11 lemans 2002 in south korea.^^ I am sorry to say I am not that good in english. plz understand. I have a question. When the ignition on(not running engine), which lamp of instrument should be light on? Of mine, only neutral lamp on. Thanks.
  4. Thanks for prompt reply. I will try simple things which you recommended.
  5. Other shiftingsm is ok(1st.neutral.2nd.5th.6th) Are you suspecting clutch fluid or adjustment? Could u tell me more details which you are suspecting? I wanna do anything for repair. thanks in advance
  6. hi, everyone, I am v11 lemans owner in south korea. Just 1month ago, I bought this beautiful v11 lemans 2002y. Everything was good at that time. But now, I heard and felt something like metal gear griding sound or vibration when I shift up (2nd to 3rd) & (3rd to 4th), especially 2nd to 3rd. I have read many thread but I am still confused what am I supposed to do for adjustment or repair. This morning, I removed starter and check some bolts but I could not verify which one is eccentric adjust(=need to adjust) - no.1 or no.2(refer to attached file) when I turn no.2 bolt (counter clockwise or clockwise), the shift rod move upward and backward but still heard and felt grinding noise and vibration. -> I could not find any differences when I rode it. when I turn no.1 bolt, I could not find any differences. What should I do? it is necessary to open gearshift box? T.T thanks.
