Vladimír64
Everything posted by Vladimír64
  1. last year I found an oil leak from this sensor on my Scura and found that the sensor was touching the timing wheel and causing the sensor flange to lift slightly and leak oil and stall the engine. after mounting the limiting washer and the ring, everything is fine. translated by google translator.
  2. After removing the cotter pin, it is necessary to remove the lower part by force. Nothing holds it in, only sealing o-rings. There is a filter, I recommend cleaning it.
  3. Vladimír64
    Vladimír64
