stewgnu
    12
Everything posted by stewgnu
  1. yes i checked them twice previously as i was going thru it, but didn’t identify the problem, missed it. i was doing the old yank all the cables routine and that did it
  2. Hey man I have a set of the Rossopuro ones with the crash mushrooms attached- is that what you’re after?
  3. Well, like a blind hedgehog shuffling about in a sack, I’ve finally found the light… Problem traced to one of the two bullet connectors by the headstock. I got stranded far from home yesterday and after checking over all the usual suspects I poked a finger down the front of the tank to wiggle the cables and boom baby! Repeated and got the same result- had to start the bike a few times during the journey and it worked every time, fired up strong and instantly. At this stage I haven’t had the tank off for a closer look so I can’t say whether it’s the black or grey, or both, wires that’s causing the problem. But I’m going to cut and replace with spades when I do. So, long story short: It was a knackered starter and bad bullets. But I’ve been thru everything and so the starter system should be 👍 from now on 😀
  4. Ok, i think the issue is somewhere around the wiring past the headstock. i thought i’d cleaned out the connectors but maybe i didn’t. If i did then there’s still a loose connection or maybe a tortured wire there- some of the loom looked very sharply bent about. There’s nowt else left to fix at this stage 😀
  5. That 87 and 30? I’m fair baffled with the issue- wondering whether there’s some weak connection or stressed bit of wiring somewhere in the loom that’s been bent about too much.
  6. What ho, I have some oe clip-ons going spare if anyone’s interested? I’m keeping the bars so it’s just the clips available. Great condition. Dunno what they’re worth- does £180 plus postage seem reasonable?
  7. i took the start button apart too to see whether there was any obvious problem there. Seemed fine, so i cleaned it thoroughly and checked the wires too.
  8. kill switch functions as it should yar
  9. well i checked the ignition switch and it isn’t the problem as far as i can tell. still getting intermittent cranking.
  10. But i’ll try again, heating with a torch, tomo evening
  11. I had a quick bash with an extractor but as there isn’t any depth it just chewed it out
  12. Nice tip about de-stressing the solder joints Roy- ta. They look good so will try to keep em that way. Those ignition switch clips are fun if you are evolutionarily retarded with only two hands 😀 I had various bits removed earlier, ig switch, tank, airbox, breather hose, speedo cable, removed the damn hotgrips wiring that’s been bugging me for a time: couldn’t identify exactly where my oil leak was coming from, but i replaced the breather hose anyway… possibly the oil ‘y’ hose from the pots, but could be mistaken. Quite a puddle of nastiness in the airbox mind. Someone’s done a lot of pissing about with the wiring, and not in a nice way 😠 The middle grease nip snapped off on the drive shaft, which was ace, any tips for removing the leftover thread would be appreciated as it’s almost blind. This should be in ‘wot i did to my v11 today’
  13. I’d pay money to see anyone do that in 15 minutes
  14. Dunno details man, it came up on the faceache page, folks heading to a cafe at Fradley. I was toying with the idea of going myself but after riding today i have an oily left boot 😠. So poss got a loose oil line or split breather hose to investigate. Still need to clean out the ignition too so tomo will be a spannerin day i’m thinking.
  15. Nice. You taking her out on the staffies rideout tomo grim?
  16. Are the higher current relays recommended for all points? I’m aware that the fuel relay does get very warm, but is the starter, and other relays, likely to be of benefit?
  17. if the starter current doesn’t route thru the wheel bearings it’s not a guzzi.
  18. Thanks Roy (sorry for going over all this well-worn ground! I ran my ballabio for years with no issues-she always cranked good + strong but the current machine is proving to be less reliable). When you say to clean the ignition switch is that more involved than squirting a shot of wd down the slot? So can i set a direct feed into the system as per this video:
  19. Yes I didn’t have a dedicated charger for my odyssey, so ill grab one at the earliest opportunity. I checked the ignition switch and all the wiring looked fine. I’ve managed to acquire loads of spare relays but none are the high current badgers- i recall searching for some but they weren’t available in the uk. When you mention adding a relay, where would that be?
  20. Well I fitted a new starter today and it cranks the engine fine now. However it’s still sometimes just clicking without cranking…. sounds like the solenoid is firing but can take a few presses of the button to actually spin up. Could it just be a low battery? Or some crud in the button i’m thinking… Hmm
  21. Hello mate yes I have the screen
  22. i had an odd moment today where i could not find the 13mm socket… but in scrabblin about found 3, yes 3, 10mm sockets. All of which will no doubt go on a quest together over winter
  23. i thought it was a drop in current- almost started to check/pull apart/adjust/butcher the wiring system. doccs suggestion to check the starter magnets was champion- un-doing a few nuts+bolts revealed the issue.
  24. It was the starter magnets. 2 of them had come loose and were jammed up against the casing. Of course, I had checked the main earth point, forward bullet connectors and ignition switch first, naturally…. but yeah the starter was proper mullered! Got a dessert spoons worth of rust and magnetic debris when i opened it. No wonder it was getting hot. Thanks again docc!
  25. Right o. If, when i pulled the starter, and bridged the contacts to check it, it seemed to fire and spin normally, would that rule out magnet problems?
