Scud
    247
Everything posted by Scud
  1. No... showing you this snowy single-track is teasing... But I cut my ride short after the bike went right and I went left for a swim. Wet underwear, boot full of water and freezing temperatures are a bad combo... And Baja - that's a special place. If you've never been and you want to go offroad, it's probably a good idea to spend for a tour guide. It IS a different country with different ideas about laws, healthcare, foodservice, etc. Many of the differences are refreshingly pure and simple, some of the differences can get you killed.
  2. Truck or motorcycle tour? I don't know anybody, but I could ask around. If motorcycle there's a San Diego Adventure Rider Forum - I'm not active on it, but I bet those guys would know who does tours.
  3. SNOW RIDE!!!
  4. I'd say a lot of the wear is due to how the bike is used. I'm getting the idea that Andy doesn't sit still long - and looks for long rides with minimal stop-and-go. That would let a clutch last for many more miles than an urban commuter.
  5. Those parts look to be in a little better condition than the ones from my Champagne LeMans project at 50,000 miles. Flowing rides, smooth shifting, high idle speed, and pure thoughts make for a long clutch life I guess. On the other end of the spectrum we would have stop-and-go, engine-braking, throttle-whackers who hold the lever in at low-RPM idle.
  6. Scud
    Brand-new Scura
    That is sort of funny that this obsessively dark thread has eluded your detection. Hello darkness my old friend... I've come to talk to you again...
  7. Yes, that is clearly my fault. As restitution, I will send you the brake reservoir from Joe's bike. I might have a brake lever too - let me dig around. Yeah, fire is bad. I happened to drive by Moto Forza today, the Ducati/Husqvarna dealer where I got my Ohlins forks and shocks rebuilt recently. It was all fenced off. As I drove by, it was clear there had been a fire. Just looked up the news... http://www.sandiegouniontribune.com/communities/north-county/sd-me-escondido-fire-update-20170212-story.html There were some very special motorcycles in there (including a MH900e), not just the new inventory. So... we DO all have fire extinguishers in our workshops... right?
  8. No pressure - I was just curious.
  9. When my LeMans clutch started slipping, I replaced the 2 friction discs and the intermediate plate. Upon removal and inspection it seemed that the plates still had some life left in them. I also noticed that the old springs were much weaker than the new springs I installed. I think I could have gotten more life out of the clutch just by installing new springs. They are $2.00 each at MG Cycle. Since you have it out, you might think about some new springs. BTW - I used aftermarket friction discs, also from MG Cycle, which apparently are a bit thicker than stock. This has caused a clutch-release problem - but more on that later when I am ready to attack it.
  10. ...and how were the steering bearings? My Scura's bearings were almost dry. Did you find whatever was causing the little problem in your steering? Careful on that slope...
  11. Noble... That sounds like a good decision. For future reference, the injectors can be very difficult to remove. I destroyed 3 of 4 screws taking them out of my Scura. The injectors can be cleaned while still in the throttle bodies. If you pull the tank, you can disconnect the fuel lines from the injectors and pull the TBs off the head. Then you can attach the cleaner spray to the inlet and stuff a towel in the TB to absorb the spray-through. On the seafoam - in addition to running some in the tank, I also let the engine suck some seafoam through the vacuum ports (where you connect to check the balance). You do this when the engine is hot. It supposed to clean out the valves and combustion chamber. There are lots of videos on YouTube about it. I made a T out of plastic hose and added a little valve so I could control how much was getting sucked into the ports.
  12. I agree with checking/replacing relays as a first step to address the stalling issue. A problem will often have multiple small factors that contribute to it. One thing that hasn't been mentioned for Owen's problem is the rear brake. Do you use the rear brake when you downshift? Have you cleaned the rear caliper or flushed the fluid recently? If you are applying pressure to a sticky rear brake while downshifting and losing engine power it could contribute to a temporary wheel lock. And how about the rear wheel bearings? Are they in good condition?
  13. Throwout bearing is cheap - it's just that little roller bearing in my picture. You can get at it when the clutch slave is out. New clutch... well... is it slipping? If not, why replace it?
  14. Those and the D-type jags are so awesome. Nice little rip around Mulholland Drive and Pacific Coast Highway too. Which Guzzi is in the garage? It's next to a Ducati PS1000LE, and an adventure bike.
  15. Most motorcycle dealers are closed Sunday and Monday here. Tomorrow is Valentines Day. Go get your sweetie something special at the Ducati dealer. Oh... and maybe get something for you wife too.
  16. Fabulous Chuck. FWIW - I bought 2 liters of that oil. Then when I decided to have a shop do the work I gave them all my supplies. They returned my 2nd liter with about 900ml remaining. That's why I had a bottle handy to take a picture for you earlier.
  17. The top one is this photo is the one I mentioned - it sat idle for a few years too. You can see the rust on the piston and small chrome part it touches. The bottom one was salvaged from my parts bike - and I plan to use that one. I can probably pop the pistons out of both on Wednesday evening - and we'll see if something can work for you. You gonna put in a new throwout bearing while you're there?
  18. This is essentially my point as well. The major wheel alignment is done be the frame and how all the big pieces bolt up. By the time you install the swingarm, there is only a small amount of free play between the porkchops - not nearly enough to alter alignment. IMO, the process of measuring how far the pivot pins stick out of the porkchops is an unnecessary step that produces no perceptible benefit, but also does no harm (unless it was poorly installed at first, then the measurements would replicate the original error).
  19. Andy - I have the one my champagne project available. It had 50,000 miles, but the piston surface got corroded. I haven't disassembled it, but maybe the seals are still good. I'll be home Wednesday and can take a look if you haven't found new seals by then. If I recall correctly, Dangerous had to replace those seals - you might search his threads.
  20. It does look like a puzzle. Since you're so far in, you could remove the engine and transmission and give everything a good inspection. That looks like a lot of old oil behind the right cylinder. If it's leaking out of the base gaskets, you might need to re-torque the cylinder heads. It's least likely to be something major like a rear main seal. And more likely to be something simple that you will discover as you go through it. On the swingarm alignment... we were just discussing that on another thread. I have offered a contrarian opinion. All the same, you may as well measure it before you take it out. You're so far in that you should at least inspect the swingarm bearings - and replace if needed. And pop the driveshaft off and give it thorough clean and lube. You'll just have to ride the BMW for a while...
  21. That one's "the bomb."
  22. A friend of mine told me about him, so I started listening on YouTube. When I noticed that he had a new album coming out, I pre-ordered it. He has such a fabulous, powerful voice. A baritone, I think, maybe a tenor. Have another:
  23. Try browsing through the gallery. I don't think there have been many repaints. I was just thinking that the Tenni fairing would probably look good on the silver bike. Maybe no re-paint needed. Break out the tools and let's see how she looks.
  24. An alternative TPS would make a good entry for our burgeoning encyclopedia of compatible parts - by somebody who has actually done it.
  25. I have no insider information... but I did happen across this picture... The only things that appear to be missing are: turn signals, license plate, me.
