sam30328
    2001 V11 Sport
374 profile views
sam30328's Achievements
Rookie
Rookie (1/5)
0
  1. sam30328
    sam30328
  2. SUCCESS !!! Got it running on BOTH cylinders !! With injector detached and laying on throttle body, got fuel spray. With injector plugged into throttle body but mounting screws only halfway in, got no spray.With injector fully mounted,got spray and running.Son suggested it might be a grounding issue.? Beginning problem was a clogged injector from old fuel residue.
  3. Left side refuses to run even with spark,fuel spray and fresh fuel.Wonder if valves out of adjustment could cause the problem?. Right side runs just fine as a single.
  4. This AM I pulled the left injector but left the fuel end connected--got good spray so maybe the carb cleaner finally did its work.Tonight I will reattach injector and see if the left side will run.It has spark and fuel spray so unless the spark timing is off,should see some progress.
  5. Thanks Hubert, I'll try the voltage test.If I don't get 12 volts,where do I go from there?
  6. 2001 V11 has been sitting for 1 1/2 yrs.Right side will run,not the left.Has spark so I removed tank,air box,left side fuel injector.Used a syringe filled with carb cleaner and wires to a small battery---got clicking and cleaner spray.Put everything back together--no improvement. Wondering if signal is not getting to the left injector? Any help would be greatly appreciated.
