Hi all,
Long time listener, first time caller. I am trying to replace the Uni joint in my drive shaft. The manual is not very helpful as simply says to undo the high tension bolts and remove!!! Have had a really good look through the “how to” section - so hoping this hasn’t been covered before (apologies if it has). Does anyone know of a way to remove the transmission shaft from the bike without removing the swing arm? The yoke of the universal joint is too large to fit through the hole in the swing arm - so you cant pull it down far enough to clear the gearbox shaft. I also considered taking the uni joint apart - but you also cant get to the clips on the uni joint. Any ideas?
