Hello all.
Been a while since I posted.... Came home from a fishing expedition, went into the garage and was greeted by the smell of gas. The two allen screws that hold the fuel solenoid valve onto the tank are wet. Checked them and they are both snug. It may have something to do with the lack of clearance between the fuel solenoid and the intake boot. It seems as though a washer that goes under the rear tank mount was left out at some point in the past, allowing the solenoid to rub against the boot. The solenoid itself doesn't seem to be leaking, it looks like it coming from where it attaches to the tank. Anyway, I know the answer is to drain the tank, remove it, and figure out why its leaking..... but, I thought I would see if anyone has had a similar situation. Anything to look out for? My parts book doesn't show (or I can't find) the solenoid and I'm wondering if it's a gasket or an O-ring that seals the solenoid to the tank.
