Search the Community
Showing results for tags 'false neutrals'.
Hello All, So, after reading through this site and others, and riding my bike and experiencing some weird shifting behavior such as missed up-shifts, difficulty shifting down into 1st gear out of neutral, neutral light not coming on when in neutral, and false neutrals (which may explain the light not coming on when I think it should) I've decided to open up the gear box to look around, and to preemptively replace the pawl arm ratchet (04235101), the selector spring (04238300), as well as the lever spring (04239200) and the push spring (04238200). I've got some Red Line gear oil, as well as moly additive, with which to replace the gearbox oil after I'm done. I have the official service manual, which I find very unhelpful... The images are small and dark, and the accompanying instructions are an exercise in minimalism. I was hoping you guys could point me towards more explicit step by step instructions, which I'm sure exist somewhere on this site, but I'm having a hard time sorting through it all. What are specific things to look out for, are there any little tricks or tips I should keep in mind? Also, will I be needing and specific proprietary Moto Guzzi service tools, or can this job be done entirely with standard tools? Thank you very much for your help, and sorry if this is a redundant post. If it is, I'd be happy to be redirected to the appropriate articles. Thanks again, -Simon
- 48 replies
- 1
- false neutrals
- gearbox
(and 2 more)
Tagged with:
