Hi All,
I'm having a problem with my 2001 V11 Sport, hoping someone can help?
After removing and replacing the tank the bike would only fire up on the right cylinder. Having noticed a broken cable on the solenoid valve I replaced it with a manual petcock (just in case) but still only firing on the right.
After checking there was a spark on the left I took the plug cap off the right side and finally got the left to fire up. I let it run for a few minutes, then replaced the right plug cap to fire both up together, but again only the right cylinder would fire. The left cylinder will only fire when the right is not firing.
I'm new to fuel injection, but guessing the problem may be there?
Suggestions appreciated! Thanks
Roy
