Search the Community
Showing results for tags 'reaction rod'.
  • Search By Tags
    Type tags separated by commas.
  • Search By Author
  • Nuts and Bolts: technical questions and topics
    • Technical Topics
  • Reference Section: techniques, procedures and FAQs explained
    • Frequently Asked Questions
    • How to...
  • Moto Guzzi V11 Le Mans: the ride starts here
    • 24/7 V11
    • Special place for banter and conversation
    • Meetings, Clubs & Events
    • Travel & dealers
    • V11 Registries
  • Other Moto Guzzi Models: current bikes and pre-V11 models
    • Newer models
    • Older models
  • About This Site: adverts, housekeeping and site development
    • Classifieds
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Location
My bike(s)
Found 1 result
  1. Hello all, I have what I hope is a simple question: under acceleration, is the rear end rotating towards the front of the bike, compressing the reaction rod, or is it rotating towards the rear, stretching the reaction rod? My semi-familiarity with suspension engineering tells me that since shaft-driven bikes want to raise the rear of the body under acceleration, the pinion is trying to "climb" the ring gear, forcing the swing arm down while rotating the rear end housing forward, which would put the reaction rod into compression. If that is indeed the case, would the stretching (tensile) forces be marginal under braking as I suspect? I would greatly appreciate any and all input. Thanks. P.S. I'm sure most of you know that the drive shaft turns CCW, but I just want to add that.
