Search the Community
Showing results for tags 'sound rattle V11 Sport'.
  • Search By Tags
    Type tags separated by commas.
  • Search By Author
  • Nuts and Bolts: technical questions and topics
    • Technical Topics
  • Reference Section: techniques, procedures and FAQs explained
    • Frequently Asked Questions
    • How to...
  • Moto Guzzi V11 Le Mans: the ride starts here
    • 24/7 V11
    • Special place for banter and conversation
    • Meetings, Clubs & Events
    • Travel & dealers
    • V11 Registries
  • Other Moto Guzzi Models: current bikes and pre-V11 models
    • Newer models
    • Older models
  • About This Site: adverts, housekeeping and site development
    • Classifieds
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Location
My bike(s)
Found 1 result
  1. Hey all, After lurking here for a while, let's introduce myself: Martijn, 27, from the Netherlands. I own a V11 Sport Mandello Rosso since a year. Since a number of weeks, the bike has developed a strange metallic rattle from the engine under idle and load. Sometimes only when hot, but sometimes also when cold. It has been quiet while being hot recently again as well. Done so far in order to find the issue: - Adjust valves to 0.15mm and 0.20mm. The intake valves had VERY tight clearance, the exhoust was around 0.10mm. Sound, idle and low rev pickup improved significantly, rattle remained though. - Replaced cam chain and tensioner for the Stucci type with spring. Cold idle improved again, no change. Rattle remained. - A local dealer suspected a pushrod had a separated end. Checked all those last night, all fine. No excessive wear on valve ends and rockers. The bike runs and drives great. It has done 34.000km. Fresh 20W50 from Castrol. Edit; it is not the single plate clutch, as I replaced that one last year for a dual plate version. A video of the sound can be found here: https://vimeo.com/183857762 Guys and girls, I'm hopeless. What do you suspect and should I still drive it or not? Kind regards, Martijn
