Guest VMoto Posted March 12, 2007 Posted March 12, 2007 Hi all, as a new kid on this block excuse me if this one has already been sorted........I want to charge the battery but the seat refuses to lift. I place key in lock and turn but the seat refuses to budge. How can I get at the latch otherwise ? Your views will be most welcome................aaargh!.
stormsedge Posted March 12, 2007 Posted March 12, 2007 V, mine has occassionaly stuck, but jiggling the key and seat has always worked it loose. Failing that, the latch mechanism works on a cable pull arrangement from the keylock...maybe you can get on it near the key and work a pulling force? k
Guest VMoto Posted March 12, 2007 Posted March 12, 2007 V, mine has occassionaly stuck, but jiggling the key and seat has always worked it loose. Failing that, the latch mechanism works on a cable pull arrangement from the keylock...maybe you can get on it near the key and work a pulling force? k Thanks Storm, as always it worked when I went back to it !.........basically there was a small piece of plastic caught in the latch mechanism. Now sorted.
