mznyc Posted March 16, 2007 Share Posted March 16, 2007 Has anyone replaced their starter solenoid,or rebuilt their starter,that would know if I should grease the brass/copper plunger that engages/disengages the starter gear?It seems like there was grease on it at one time but a bit tacky now.If so,should I use dielectric ,lithium or any ole monkey grease? Thanks, Michael Link to comment Share on other sites More sharing options...
Francis Chartier Posted March 16, 2007 Share Posted March 16, 2007 Has anyone replaced their starter solenoid,or rebuilt their starter,that would know if I should grease the brass/copper plunger that engages/disengages the starter gear?It seems like there was grease on it at one time but a bit tacky now.If so,should I use dielectric ,lithium or any ole monkey grease? Thanks, Michael Hello. Last time I rebuild my Valeo starter I tried using grease on the plunger and it don't work anymore. I open it, remove any trace of grease and yo, up and running... Link to comment Share on other sites More sharing options...
big J Posted March 16, 2007 Share Posted March 16, 2007 I used a spray dry lube silicon stuff.Seems to work ok. Link to comment Share on other sites More sharing options...
mznyc Posted March 21, 2007 Author Share Posted March 21, 2007 I talked to local auto parts store and they said that a some type of thin coat of protective anti-corrosive is applied to plunger at the factory and that it's not necessary to add any lubricant.I didn't ,put it together and everythings workin perfect. Link to comment Share on other sites More sharing options...
raz Posted March 28, 2007 Share Posted March 28, 2007 Another starter question... what about the gear itself? I removed the starter for cleaning and having a look. Should I put a little grease on the gear? Chain lube? Nothing? It's not engaged much and excess grease would of course make a mess inside. But it seems so unhealthy dry now. Link to comment Share on other sites More sharing options...
