badmotogoozer Posted March 26, 2007 Share Posted March 26, 2007 Forget the green paint! I want to know more about those Heads!! They look wicked evil. How did the Tenni gals get out again? Rj Link to comment Share on other sites More sharing options...
Paul Minnaert Posted March 27, 2007 Author Share Posted March 27, 2007 that is the 4v watercooled engine, that was last year in the mas12: http://www.gg2.it/Italiano/guzzi_1.htm Link to comment Share on other sites More sharing options...
richard100t Posted March 27, 2007 Share Posted March 27, 2007 Do they actually sell that engine? I cant read the language but it looks like a lot of fun. Link to comment Share on other sites More sharing options...
Paul Minnaert Posted March 27, 2007 Author Share Posted March 27, 2007 yes they sell it, are you ready to get the fastest v11? I supposed that the millepercenyto team was using one G&G powerded bike because thaty presented it like that, but the pictures show they used 2 mgs01 with 4V engine Link to comment Share on other sites More sharing options...
big J Posted March 28, 2007 Share Posted March 28, 2007 that is the 4v watercooled engine, that was last year in the mas12: http://www.gg2.it/Italiano/guzzi_1.htm Can anybody translate the engine details?I bought an Italian/English dictionary,but it doesnt have technical terms in it. In one pic,it looks aircooled but there's a radiator on the new racebike.There's no way it would fit a V11 without some surgery,but it looks bloody good. Link to comment Share on other sites More sharing options...
Paul Minnaert Posted March 28, 2007 Author Share Posted March 28, 2007 So is this enough, or you need other parts? Testate e cilindri raffreddati a liquido. heads and cilinders watercooled Doppio albero a cammes in testa double overhead cams 4 valvole per cilindro 4 valves per cilinder distribuzione a cinghia dentata belt driven cams realizzabile con diversi valori di alesaggio e corsa made with different bore and stroke alesaggio da 95 a 98 mm bore 95 to 98 mm corsa 70 - 78 - 80 mm. stroke 70 - 78 - 80 mm. Alimentazione: the juice: a carburatori (Keihn fcr41) with carbs a iniezione injection Prestazioni della versione 1000 cc, albero corsa 70, alesaggio 95mm what a 1000 cc 70x 95 does: potenza 118,2 CV alla ruota a 10500 giri/min 118.2 hp at the rear wheel coppia 11,2 kgm a 8000 giri/min. torque 11.2 kgm @ 8000 rpm E' applicabile sui motori Guzzi Sport 1100, Le Mans3 e simili. it can be build on engines from Guzzi Sport 1100, Le Mans3 and equivallent E' composto da: What you get: Teste complete (Valvole in nimonic, molle, scodellini in titanio, bicchierini, alberi a cammes, pulegge e cinghie di distribuzione) heads complete( valves nimonic treated, cams, distibution parts, all small parts in the head. ) Cilindri raffreddati ad acqua con camicia in umido in ghisa speciale cilinders watercooled with cast iron liners Pistoni completi stampati forged pistons Carter anteriore in fusione d'alluminio completo di albero ausiliario per la distribuzione e terna di ingranaggi. the front engine cover, with distribution parts. Si possono aggiungere: what you also can get: Scarico completo complete silencer Corpi farfallati diametro 60 injection body 60mm for a v11, the tank might need some changes, while it is now an airbox. So make a new tank where the airbox is now. And the radiator needs some space. I don't see a real problem. :-) The engine will just mount, its the ancilaries that need some work. Looks like a fun job to me. Or the big bore engine:-) Link to comment Share on other sites More sharing options...
big J Posted March 28, 2007 Share Posted March 28, 2007 Wow,thanks Paul. I'm going to sell some of the children. Maybe all of them. Does it say how much?Or the Big Bore? Link to comment Share on other sites More sharing options...
Paul Minnaert Posted March 28, 2007 Author Share Posted March 28, 2007 no it doesn't tell that, depends if you take the parts, and build the engine yourself, or let them do it, lots of possibilitys, depending on how much children you have. Maybe Madonna wants one more? But I have heard once 4-5000 euro, but can't remember for what. If you are curiuos, send them a mail. my 4v engine makes the same power, but isn't cheap either. But there is a used 4v 1225 engine for sale at 3000 euro in germany. find someone that takes your engine for 1500 euro, and only 1500 to go. Link to comment Share on other sites More sharing options...
big J Posted March 29, 2007 Share Posted March 29, 2007 Thanks Paul.The children are suspiciously absent,I wonder if they've been reading over my shoulder. E4000 is good value for the amount of time and effort these guys have put in.Better than tubeless spoked wheels for E2000! I,ve mailed them,will see what they say. Link to comment Share on other sites More sharing options...
