Karl Von Posted May 7, 2007 Share Posted May 7, 2007 Hi All Does anyone know the torque specs to bolt the ring gear to the flywheel. I can find the flywheel specs but nothing for the ring gear. If it matters it is a 1100 sport. thanks Link to comment Share on other sites More sharing options...
raz Posted May 9, 2007 Share Posted May 9, 2007 Hi All Does anyone know the torque specs to bolt the ring gear to the flywheel. I can find the flywheel specs but nothing for the ring gear. If it matters it is a 1100 sport. thanks Can't find it either. Generally they say if it's not speced go for the standard values. If it's M8 that is just below 30 Nm. Link to comment Share on other sites More sharing options...
pete roper Posted May 9, 2007 Share Posted May 9, 2007 Can't find it either. Generally they say if it's not speced go for the standard values. If it's M8 that is just below 30 Nm. The V11's and 1100 Sports etc. use M6 high tensile bolts to retain the ring gear and from memory there are ten of 'em rather than the earlier eight used on the flywheels with 8mm bolts. The bolts themselves use Schnoore washers and I just install 'em with a blob of 243 on 'em and do 'em up until the washers flatten. I've never used a torque wrench on such fasteners in my life but if you feel the need I'd suggest that you use whatever the recommended torque is for M6 HT. Pete Link to comment Share on other sites More sharing options...
