nuevototem Posted May 15, 2007 Posted May 15, 2007 Hi to all, I have break down my standard xover!!! Now is making a horrible noise, some kind of metal is making noise inside! I don’t know what to do... I am thinking to buy a new one... standard, mistral, stucchi??? Any one in europe whant to sell one? Any ideas? Thanks in advance
JoeV11 Posted May 15, 2007 Posted May 15, 2007 I used a Stucci crossover on my otherwise stock V11 sport - it now runs and sounds fantastic! Highly recommended first mod. Just need to make sure the computer is adjusted properly - mine was off even from new. Joe
jrt Posted May 15, 2007 Posted May 15, 2007 I used a Stucci crossover on my otherwise stock V11 sport - it now runs and sounds fantastic! Highly recommended first mod. Just need to make sure the computer is adjusted properly - mine was off even from new. Joe +1
nuevototem Posted May 15, 2007 Author Posted May 15, 2007 Hi to all, Thanks for your answer. JoeV11 & jrt: u use the stucchi with standard cans? Noise better??? Paul: Yes I welded but something inside is making a horrible noise! Don’t know if open it and take that out or buy a new one. To everyone: What about the mistral xover + cans??? price??? Where I can find a cheap stucchi in europe? Thanks in advance!
Admin Jaap Posted May 15, 2007 Posted May 15, 2007 Don't buy a new one!!! My guess there are plenty of hardly used OEM X-overs on this forum.
wheelsucker Posted May 15, 2007 Posted May 15, 2007 if swapping out the stock x-over for an aftermarket like the stucci or fbf, do you need the power commander? Does power change at all?
jrt Posted May 15, 2007 Posted May 15, 2007 you can fit either aftermarket or stock mufflers to the Stucchi crossover. My guess is that the exhaust note will be louder even with stock mufflers, but I can't really say from experience- just from knowing that the Stucchi doesn't have any internal baffling (vs. the stock item). I'm running Mistral pipes right now. Can't really say if makes any more power, but it does sound better and that gives me the impression of more power. I am not running a PCIII.
stormsedge Posted May 15, 2007 Posted May 15, 2007 I have Stucchi with stock cans. Do not remember there being much difference in sound level when I changed. It did help with the midrange flat spot. Power commander added later for finer tune, which seems to have made bit of diff in riding feel as well. Open air filter mod has turned out to be biggest noise maker mod so far. k
Alex-Corsa Posted May 15, 2007 Posted May 15, 2007 What about the mistral xover + cans??? price??? Where I can find a cheap stucchi in europe? Thanks in advance! Try This clasified ad on the forum
JoeV11 Posted May 16, 2007 Posted May 16, 2007 JoeV11 & jrt: u use the stucchi with standard cans? Noise better??? The stucchi with standard cans isn't any louder than stock, just allows more of the low frequency to come through, especially when decellerating. It sounds sweet, and doesn't annoy the neighbors. It also does't require any computer changes. Joe
