joe camarda Posted May 16, 2007 Posted May 16, 2007 Does any onyone know if these can be mounted in the same position (lower with less "tuck") as the stock cans so as to allow the use of side bags, probably HB Journeys?
Greg Field Posted May 16, 2007 Posted May 16, 2007 Yes, you can do this. The inlet pipe is not welded to the muffler, so you can rotate the relative positions of the two to mount them with the lower stock brackets.
Crooz Posted May 16, 2007 Posted May 16, 2007 Does any onyone know if these can be mounted in the same position (lower with less "tuck") as the stock cans so as to allow the use of side bags, probably HB Journeys? My opinion is NO. ....therefore you must sell them (TO ME).
John in Leeds Posted May 16, 2007 Posted May 16, 2007 Does any onyone know if these can be mounted in the same position (lower with less "tuck") as the stock cans so as to allow the use of side bags, probably HB Journeys? picture of both high and low position here http://www.v11lemans.com/forums/index.php?...c=97&st=150
waspp Posted May 16, 2007 Posted May 16, 2007 Yes they can, I have the teckno bags on mine and run the pipes lower much like the stock set up. hal
