Errr..............
As I stated in the previous message, that was posted to the COG list - the Centauro and Daytona use the PF09 NOT the PF3C.
GJ
Errr......Thanks.
Yah, I read what was stated in the previous message.
But what is interchangeable remains unclear.
Although Guzzi2Go's post cleared up the temperature sensor number, and dashed away hopes that there would be a temerature sensor that properly fit the sensor housing.
Thanks Guzzi2Go!
  • 2 months later...
Based on 3 fill-ups (20.9 l in 283.9km), around-town fuel-consumption has improved from 12.5 to 13.6 km per litre (35.4 to 38.4 mpg) or an increase of 8.8% - not as much as I had hoped for but I'll take it.
Bike runs great - some evidence of running leaner (a little cough and splutter after decelerating from speed to tick-over eg at lights) and hope to fix that at next tune-up. Plugs look fine.
Gio
Update - In cooler weather (5 to 10c ambient) I have experienced some popping/spluttering at low engine speed.
Removing the Copaslip from the gap between sensor and holder (ie restoring the original "air gap" seems to have cured this. I'm speculating that with the Copaslip sensor was reading hotter than intended and removing it causes the engine to run richer/better ..?
Gio
Gio
Maybe so. The original fitting on my bike was copper where it screwed into the cylinder, but plastic for the sensor holder. This construction indicates an attempt to get good thermal conduction to the cylinder, while insulating from the cooler air around it.
It makes sense that the cooler the sensor is, the richer the ECU would go to compensate.
Are you still using the original fitting, or the brass replacement?
I recently added some silver conductive goop and have noticed no change in MPG or drivability.
Maybe I need to add more?
Changed to brass replacement with a dab of copper-coat, and temp has gone from 70c to 90c @ 100kmph.on a 25 to30 deg c day,Fully warmed up @ the lights @ idle,seeing changes from 75 to 115 deg c.
Brass replacement. Original fitting disintegrated upon removal.
Gio
That's a substantial difference. I'm glad to hear that. In my opinion, the ECU should have the most consistent reading of cylinder temperature possible and any problems with mixture should be dealt with in the mapping. How did you measure the temperature?
I have the brass insert as well, with copper anti seize paste inside. The brass insert I received had several machined grooves in it. It looked like it was intended to increase heat transfer to the air. Since that is exactly the opposite of my plan, I first wrapped it with aluminum foil tape. It's the kind used on flue pipe ducting for furnaces. Pretty neat stuff, and it looks good, too.
Yes, mine has the grooves in it also,they are little fin's, I would not cover them up,Ask Pete R why as he will explain better than I can.
I can read my temp through Cliff's optimiser @ any time I like,you can check everything on that unit.Worth it's weight in gold. I run closed loop so it did'nt realy make a difference when I changed to the new brass unit.
Sounds neat. Where can I get one?
Guest
This topic is now closed to further replies.
